Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
Difference between silicone caulking ?
by Merkava_4
05/29/16 06:15 PM
The Top Dexos2 Oil Available in the USA is What?
by Best F100
05/29/16 05:24 PM
Virgin Puro L14006 [Cut open]
by Run
05/29/16 05:13 PM
The 17 year cicada is here. (locust) PIC HEAVY.
by Rand
05/29/16 04:23 PM
How long is sealed coolant good for?
by addyguy
05/29/16 04:08 PM
4T65E 2006 Buick Lucerne Normal decel gear banging
by deanm11
05/29/16 03:41 PM
California drought and 3" fish delta smelt
by HTSS_TR
05/29/16 03:18 PM
High SAPS & DPF Re-Gen
by userfriendly
05/29/16 02:50 PM
Decent little string trimmer
by Papa Bear
05/29/16 02:24 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
92 registered (901Memphis, 04SE, 29662, 2015_PSD, 2002 Maxima SE, 4WD, 6 invisible), 1412 Guests and 312 Spiders online.
58013 Members
66 Forums
249575 Topics
Page 1 of 4 1 2 3 4 >
#3214830 - 12/12/13 07:02 PM Drain Filter If I Reuse It?
JerryBob Offline
Loc: Colorado
I have been reading that some filter can do 15k, and get more efficient in that time. However 15k is at least twice the OCI that I want to do.
If I choose to reuse a filter, should I at least unscrew it and drain the old oil out?
On both my vehicles, the filter mounts mouth-up, and probably has at least 1/4 quart of oil in it. I'd like to get rid of that oil if it is advisable.
Certified Filter Cutter - License #F-23567 Expires 12/2019
#3214842 - 12/12/13 07:09 PM Re: Drain Filter If I Reuse It? [Re: JerryBob]
actionstan Offline
Loc: Ohio
I wouldn't recommend it, Id be worried the gasket wouldn't make a good seal the second time around. If you can get replacement gaskets for your size filter, AND get the filter off without denting/damaging it, i would say go for it.
Personally.. Id just switch the filter out every time, and use a cheaper filter.
Edited by actionstan (12/12/13 07:11 PM)
1999 Saturn SL1
2013 KIA Forte
#3214845 - 12/12/13 07:10 PM Re: Drain Filter If I Reuse It? [Re: JerryBob]
raytseng Offline
Loc: CA
don't unscrew. You're more likely to mess something up with the seal.
There's also more than another 1/4quart of oil hiding around in the other galleys and parts of your engine.
Plus, if the oil is so "bad" then you've already been using "bad" oil in your car for the last portion of your interval. You should be changing the oil before it gets that bad.
Edited by raytseng (12/12/13 07:11 PM)
#3214853 - 12/12/13 07:15 PM Re: Drain Filter If I Reuse It? [Re: JerryBob]
Warstud Online   content
Loc: MIchigan
True: It will be more efficient as it traps more dirt...but only to a point though and then it becomes restrictive. You could remove the oil filter and drain it but I wouldn't.
#3214879 - 12/12/13 07:36 PM Re: Drain Filter If I Reuse It? [Re: JerryBob]
Lead Shoes Offline
Loc: Mn
5 dollars or the hassle of spilling oil everywhere...
And a filter always gets more efficient the more clogged up it becomes, just switch to a cheaper filter if you are that concerned about saving money.
1992 BMW 325i 176k
Castrol 0w40/Mahle
#3214901 - 12/12/13 07:49 PM Re: Drain Filter If I Reuse It? [Re: JerryBob]
chubbs1 Offline
Loc: Merritt Island FL, USA
If it is easy to get to, I choose to drain the oil out of the filter mount. I have never had an issue getting the filter sealed back on properly. That is just the way I do it.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#3214939 - 12/12/13 08:17 PM Re: Drain Filter If I Reuse It? [Re: JerryBob]
gregk24 Offline
Loc: FL, USA
If you drain it you will be giving it another "dry start". If you going to do that, you might as well just use a new filter.
2012 Honda Accord EX-L
Taffeta White - Ivory
38,xxx miles
PPPP 0w20 / Fram Ultra
#3214964 - 12/12/13 08:35 PM Re: Drain Filter If I Reuse It? [Re: JerryBob]
widman Offline
Loc: Bolivia
Seals are made for single use, single compression. One time. You are risking your engine.
Richard's Car Restorations
#3214973 - 12/12/13 08:49 PM Re: Drain Filter If I Reuse It? [Re: JerryBob]
Rolla07 Offline
Loc: MTL, CANADA
A new filter every 7500 miles is not exactly wasteful. Id rather have clean oil and a new filter than worry about the negligable increase in efficiency of reusing an old one.
2007 Corolla Red Pearl 138k miles
Pennz Ultra 0w40 & Napa Proselect
#3214988 - 12/12/13 09:13 PM Re: Drain Filter If I Reuse It? [Re: widman]
djb Offline
Loc: Maryland
Metallic seals, yes. The soft metal used (aluminum) will work harden.
Elastomer seals... no. Most types eventually harden, but a few compressions hwile they are still flexible won't age them significantly.
#3215027 - 12/12/13 10:09 PM Re: Drain Filter If I Reuse It? [Re: raytseng]
y_p_w Offline
Loc: SF Bay Area
1/4 quart? Usually more than that. My wife's Civic owners manual says a 4.4 quart total capacity with 3.2 quarts change w/o a new filter and 3.4 quarts change with a new filter. Apparently there's a lot of space in that engine for the oil to hide, even with a tiny overall capacity.
#3215034 - 12/12/13 10:15 PM Re: Drain Filter If I Reuse It? [Re: JerryBob]
Eddie Offline
Loc: Florida, Cape Coral
I vote no because I don't want to break the seal.
CX5 Touring 2.5L :-)
#3215067 - 12/12/13 11:29 PM Re: Drain Filter If I Reuse It? [Re: JerryBob]
GMBoy Offline
Loc: Texas
New filter every oil change for me. This is like the guys who pull spark plugs to look them and reinstall. The labor to remove means new part put back on for me be it an oil filter or spark plug.
#3215070 - 12/12/13 11:42 PM Re: Drain Filter If I Reuse It? [Re: Rolla07]
demarpaint Offline
Loc: NY
That's the way I feel. Some filters hold close to a qt. of oil like my E-150. That's almost 1 qt. of dirty oil mixing with the oil that doesn't come out of the engine because of the design. That could be 20% or more of dirty oil mixing in with fresh clean oil as soon as I turn the key. I'd rather just change the oil and the filter and call it a day. Obviously opinions vary, that's mine FWIW.
God Bless Our Troops
#3215092 - 12/13/13 12:56 AM Re: Drain Filter If I Reuse It? [Re: y_p_w]
ZeeOSix Offline
Loc: PNW
That's a 0.2 qt delta, which is essentially 1/4 quart. grin
