This forum has been so far, pretty helpful with the last couple of questions I had and I want to say keep up the good work!
Anyways back when I was in college with automotive classes I heard a comment from one of my instructors at the time. He said that some older cars (might have been Cadillac) had a special overheating protection "mode" where if it detected an overheating situation, it would switch to firing the cylinders every *other* cycle, as in firing every 1440 (four rotations) of the crank on all the cylinders. Apparently that was to help cool the engine down a bit, obviously it wouldn't run so hot, neither would power be worth writing home about but apparently at least you could limp home.
Does this sound familiar to anyone? It sounds like a good idea, if it worked, that is. Considering that I haven't heard any mention of it any other time, and the two times I nearly overheated an engine (on 4.6L V8 out of a '98 Ford van, and the other being one of my older E30s*) they never went into such a mode, so there must be a reason for it not being adopted if it did in fact work pretty well (like sticking people with $2K repair bills).
*: I had a 325e that had the 80A alternator. The bearing went out on it so I got a replacement 90A unit. Later E30s had the 90A but I thought they would work fine. Turns out they didn't because the 90A sits at a slightly different angle, causing the v-belt to flip. Literally. Flip upside down and stay on the engine. It lasted "upside down" for about 20mi/32km and then promptly broke as I got off work one day early. Limped home by running it until it would get close to the red, shut off and coast to a stop -- each stop was about 45 minutes in duration until it would get somewhere back in the middle. Effective driving time was about one minute -- and I was only about 3mi/5km from home so instead of 10 minutes driving & five stop lights it was three hours. Lesson learned.
