Originally Posted By: rjundi
Originally Posted By: hattaresguy
The best way to tow out a stuck vehicle is to have said stuck vehicle in neutral and the driver steer with the other vehicle that's pulling them out.
The hardest part with modern cars is finding something solid to hook onto!
I disagree with this statement. The best way is to have the stuck vehicle spin its tires a bit and straight as possible also once it gets the tug to get out also. This eliminates the stress on both vehicles and a slight tug seems all a stuck vehicle mostly needs. I pulled a F350 2wd dually off the road out with a WRX with Nokian tires this way.
The key is tugging very gently.
I don't trust the other driver not to either rear end me or get scared and jam the breaks.
Typically I'm yanking out one of my 2wd pickups that gets stuck in some mud, and the vehicle doing the yanking is usually vastly larger, ie a tri axle.
In such a case its very easy to break things on a light duty truck that's getting yanked.
