'91 Mazda B2600i transfer case and trans oil?
by Jason280
Today at 03:59 AM
How to cut power to breaker box ?
by Merkava_4
Today at 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
Today at 01:07 AM
OK, before I lube it ...
by BrocLuno
Today at 12:53 AM
Toyota Japan Fluid SDS
by SXE10
Yesterday at 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
Yesterday at 11:25 PM
Considering a differential swap
by buck91
Yesterday at 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
Yesterday at 09:51 PM
Car Acronyms
by Marco620
Yesterday at 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
Yesterday at 09:41 PM
Carpet cleaning methods.
by Run
Yesterday at 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
43 registered (B320i, alarmguy, 2015_PSD, AZjeff, AirgunSavant, Bandito440, 5 invisible), 1079 Guests and 13 Spiders online.
58295 Members
66 Forums
250918 Topics
Page 1 of 2 1 2 >
#3213234 - 12/11/13 09:28 AM DIY oil change for Maserati 2002 Coupe.
fullthrottle Offline
Loc: PA
I have a 2002 Coupe, and the specs on the oil are out of date. Oils have improved since then, and there is no more CMCC spec. It has been replaced by ASEA.
My manual says: "Use SAE 5W/40 API SG/CD - CCMC G5". That's impossible to find. SG/CD has also been superceded by letters further down the alphabet, as well.
see:
http://www.kuttenkeuler.de/kkweb/En/infoLubrAcea
This is what I'm going to use for my next DIY oil change:
http://www.specialtylubes.com/pennzoil-ultra-euro-5w-40-6-quarts.html
The specs on Pennzoil read:
Exceeds the requirements of ACEA A3/B3/B4.
Exceeds the requirements of API SM/CF and previous categories.
Ferrari Exclusive to Pennzoil UltraTM in the USA
(Maserati Coupe engine is essentially a Ferrari 4.2L V8, made in the same Ferrari factory.)
Pennzoil synthetic is better than what the auto came with from the factory. Of course I'll use an OEM filter. I don't think an aftermarket filter even exists.
Edited by fullthrottle (12/11/13 09:31 AM)
"I have a fear of speed bumps. But, I'm slowly getting over it."
#3213240 - 12/11/13 09:32 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: fullthrottle]
Turk Offline
Loc: MN
First of all: welcome
The Pennzoil Ultra (PU as it's called here...) is a very good choice, but for further analysis, we'll need to see a pic. thumbsup
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
#3213260 - 12/11/13 09:45 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: Turk]
Loc: PA
See the link I posted above about Pennzoil Ultra Euro 5w/40 synthetic.
#3213269 - 12/11/13 09:52 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: fullthrottle]
chubbs1 Offline
Loc: Merritt Island FL, USA
I think he meant a picture of your car, not the oil. I want to see the car too!! Pennzoil Ultra 5w40 is a great oil and may I suggest Mobil 1 0w40 or Castrol 5w40/0w40 which are all oils that can be had for a much better price when on sale. Obviously your car does not ask you to meet very stringent spec's and the oils named above all meet highly regarded spec's.
Welcome to BITOG!
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#3213276 - 12/11/13 09:58 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: chubbs1]
Loc: PA
I found what appears to be the best deal on the Pennzoil:
http://www.kellerheartt.com/Pennzoil-Ultra-Euro-5W-40-Full-Synthetic-Motor-Oil-p/550023653.htm
That's enough for 3 oil changes on the Maserati. It takes 2 gallons to fill it. It's what my Maserati dealer uses.
I don't know how upload an image, but here's a linked image to the photo on my Facebook page. I don't know if you can see it unless you're my "Friend". If not I'll put it on Photobucket or something:
Edited by fullthrottle (12/11/13 10:00 AM)
#3213279 - 12/11/13 10:00 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: fullthrottle]
dparm Offline
Loc: Chicago, IL
Awesome car!
The Pennzoil Ultra 5w40 will work quite well, as it's become Ferrari's go-to oil in the past few years.
Alternatively, you could use Mobil 1 0w40, Valvoline SynPower 5w40, or Castrol Edge 0w40. All are readily available at your local auto parts stores.
2011 BMW M3 sedan ZCP
#3213289 - 12/11/13 10:07 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: fullthrottle]
chubbs1 Offline
Beautiful Car!!!!
'12 Charger SXT
'12 Charger SXT
#3213292 - 12/11/13 10:09 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: dparm]
Loc: PA
It is awesome. I bought it from a friend of mine for $30k. Had to get a new clutch. $5k.
It had only 22k miles on the odometer, but the clutch needs to be replaced every 20-30k miles.
That's the only repair I've had to do. Other than that it's in mint condition.
It has a Formula 1 type 6 speed paddle shift transmission called "Cambiocorsa". Also an automatic mode. ASR traction control and an active suspension called "Skyhook". It has a "Sport" mode which enables faster shifting, stiffer suspension, and opens up the exhaust more. It sounds like a big cat roaring. I've had a lot of fun with it.
It is a 4.2L DOHC, 32 valve, 390 hp, V8. My friend calls it The Beast. Top speed is around 180 m.p.h., but I've only been brave enough to hit 130.
The interior is completely leather. I mean entirely leather except for the carpets. The color is light tan, called "Tobacco".
I would never have bought one except for the great deal I got, and a dealer, Maserati of the Main Line in PA is only 12 miles away from me.
Edited by fullthrottle (12/11/13 10:20 AM)
#3213294 - 12/11/13 10:13 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: fullthrottle]
Turk Offline
Loc: MN
Beautiful Car & quality oil choice!
Mobil 1 0w-40 Euro Formula is great as well and as I posted in the deals/rebates forum, you can get 6 quarts of it + a Mobil 1 oil filter (not sure about your car though...) shipped free w/Amazon Prime all for $37.06.
It's another option for you... smile
#3213295 - 12/11/13 10:14 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: Turk]
Loc: PA
Thank you. I'll check it out.
I don't think an aftermarket filter even exists for this car.
I can get an OEM Maserati filter from my dealer for $28.
#3213303 - 12/11/13 10:18 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: fullthrottle]
Turk Offline
Loc: MN
Ok, just pick an oil filter for another of your cars! thumbsup
#3213310 - 12/11/13 10:23 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: Turk]
Loc: PA
I was looking at the K&N oil filters and air filters for my other car and truck. Especially the air filter, since you only ever need to buy one. You can clean and re-oil them.
http://www.knfilters.com/
BMC makes a reusable performance air filter for the Maserati.
Edited by fullthrottle (12/11/13 10:26 AM)
#3213315 - 12/11/13 10:45 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: fullthrottle]
Loc: PA
Another good, economical option for 5w/40 synthetic oil is LiquiMoly from Germany.
The specs are right on for Maserati as well as every other European car.
Synthoil Premium - Full Synthetic - API SM/CF, ACEA A3/A4/B4. MB 229.3 OEM APPROVED. BMW Longlife-98 OEM APPROVED. Porsche A40 OEM APPROVED. VW 502.00 / 505.00 OEM APPROVED. Case = (4) 5 Liter Bottles
LiquiMoly Synthoil Premium 5W-40 Engine Oil: Fully synthetic, energy conserving (fuel economy) SAE 5W-40 motor oil for the latest engine concepts (both gas and diesel), such as multi-valve arrangements, variable cam and timing configurations, turbocharging, supercharging, intercooling, etc. Saves fuel, provides instant lubrication after a cold start. Good for extended oil change intervals and highest demands.
long service life for the engine due to very high level of protection against wear
Miscible and compatible with commercially-available engine oils
Rapid oil delivery at low temperatures
Very high lubrication reliability at high and low temperatures
Very high shear and ageing stability
Outstanding engine cleanliness
Smooth engine running
Saves petrol and reduces pollutant emission
Optimum oil pressure at all engine speeds
Tested with catalytic converters and proven performance with turbochargers
Extremely low evaporation losses
__________________________________________________ ______________
Edited by fullthrottle (12/11/13 10:47 AM)
#3213358 - 12/11/13 11:46 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: fullthrottle]
dparm Offline
Loc: Chicago, IL
Except that it's rather expensive in the US for what you get. M1 is about $5/qt 365 days a year and has equal or better specs. Note that LM oil carries older specs like MB 229.3 and BMW LL-98, both of which were superseded a while ago.
It will work just fine, but for the same (or less) money, why not just get the better product?
#3213364 - 12/11/13 11:50 AM Re: DIY oil change for Maserati 2002 Coupe. [Re: dparm]
Loc: PA
I think I may have found a great deal on the LiquiMoly for a 4x 5 Liter case for about the same price as the Mobil. I don't know about the specs you mention, but the specs I need for the Maserati are right on. I might even get the Pennzoil Euro 24 quart case and blend them. I'd have enough for 5 oil changes.
But, thanks. I want to know all my options.
Edited by fullthrottle (12/11/13 11:54 AM)
Page 1 of 2 1 2 >
