Quote:
... Sayjac your mind is made up, but ironically the Napa Gold you keep holding up as a better example of Wix's design DOES NOT WORK for me yet the Silver does. If my Jeep was oil starved in any way believe me it would let me know..
Your specific noise anecdote could have little or nothing to do with the bypass function of the combo valve opening and closing at it's specified psi. Again, the rubber adbv portion could by functioning but either be incurring more frequent or longer bypass events without your knowledge, and be completely unrelated to oil starvation. And your specific vehicle as you admit, seems to have issues with many filters, but there is no known or verifiable cause. So that the Silver has no 'noise' in your anecdote really can't be attributed to any specific cause one way or the other including the combo valve.
You are correct though, my mind is made up that the combo valve is primarily a cost saving design. And to this point, has not been adopted by the majority of oil filter manufacturers including Fram, Purolator and even Wix for there own filters. The only other filter that uses a combo valve is the ecore, and the general opinion of that filter speaks for itself.
While pics will be nice, it will not change the facts of the main reason for the use of a rubber combo valve, and that rubber is determining the bypass function. Unless there is some kind of unlikely media deformation or similar I would not expect to be able to determine much regarding the bypass's overall reliability and durability by the viewing filter pics of a 4k oci. As linked on previous page there is an AE using a combo valve that looks ok.
Thats said, there's enough information in this thread regarding the 'combo valve' design that others can make up there own mind regarding whether to use a filter with one, or not. I agree with Jim's previous comments, and not being a beta tester for the design.
