Brakes for 2012 Subaru Legacy
by Picky1
2 minutes 20 seconds ago
Microgreen Oil Filter 50% Off Discount Code
by kohnen
7 minutes 53 seconds ago
Don't believe the hype of "never change the oil"
by Fsharp
28 minutes 5 seconds ago
tzlk to me about aeroflot
by Jetronic
Today at 12:21 PM
My extended drain OCI did not go as intended...
by firemachine69
Today at 11:10 AM
Honesty
by stockrex
Today at 11:04 AM
Valvoline's New "Cobalt" Grease availability
by EdandSherry
Today at 10:47 AM
Mobil Delvac 1 5w40: where to buy?
by car51
Today at 10:38 AM
Honda EM7000is stored too long with fuel
by henni
Today at 10:04 AM
1967 Ford F250- cooling system flush w/ Cascade??
by ryanschillinger
Today at 10:02 AM
Oil for FTO MIVEC used on track
by Spetz
Today at 09:13 AM
[Cut Open] Motorcraft FL500S - 5316mi
by DuckRyder
Today at 09:04 AM
Jennyp, dcdodge, igolfat8, makomike, Alexas
58338 Registered Users
90 registered (arob85, 13Tacoma, 1foxracing, aquariuscsm, 09_GXP, 13 invisible), 2037 Guests and 11 Spiders online.
58338 Members
66 Forums
251102 Topics
Page 1 of 2 1 2 >
#3210846 - 12/08/13 09:31 PM Oil for Civic lean-burn engine (hybrid)?
blackman777 Offline
Loc: Santa Ana, California
I had good results with Toyota and Mobil 0w-20 in my Insight. I was thinking I'd run them in the Civic hybrid too.
Trivia: The Insight uses only 2.4 quarts.
#3210883 - 12/08/13 10:20 PM Re: Oil for Civic lean-burn engine (hybrid)? [Re: blackman777]
CHARLIEBRONSON21 Offline
Loc: MEMPHIS, TN
Not a fan of M1 myself but the 0W20 AFE has some good specs. I'd go that route.
'13 Fusion Hybrid: 5w20 PUP/FU
'15 Civic Si: 0W20 PPPP/FU
'16 Fusion Hybrid: FF
'14 Odyssey: 0w20 PUP/FU
'93 Civic: 5W30 M1/TG
'99 SVT Cobra: 5W30 M1/FU
#3210895 - 12/08/13 10:40 PM Re: Oil for Civic lean-burn engine (hybrid)? [Re: CHARLIEBRONSON21]
gregk24 Offline
Loc: FL, USA
What specs might you be talking about? The add pack is pretty weak.
2012 Honda Accord EX-L
Taffeta White - Ivory
39,xxx miles
PPPP 0w20 / Fram Ultra
#3210899 - 12/08/13 10:50 PM Re: Oil for Civic lean-burn engine (hybrid)? [Re: gregk24]
Rand Offline
Loc: NE,Ohio
because all additives show in a VOA/UOA right?
2015 Forester I-Premium 6MT
#3210902 - 12/08/13 10:56 PM Re: Oil for Civic lean-burn engine (hybrid)? [Re: Rand]
2015_PSD Offline
Loc: SE Texas
Too right and actual usage never trumps a lab test, right? Way too many users of M1 products seeing good results and longevity for them to be "weak".
2015 F-250 PSD.................M1 Delvac ESP 5W-40 + CQ
2014 Explorer LTD.............M1 AFE 0W-20 + FU
2010 Kawasaki BF750 4x4....RT6 5W-40 + OEM
#3210908 - 12/08/13 11:24 PM Re: Oil for Civic lean-burn engine (hybrid)? [Re: blackman777]
901Memphis Offline
Loc: Northern Kentucky
TGMO 0w20 was designed for the start stop cycles of the prius so it should work well in your hybrid too.
2002 Buick Century 125k - Built 4T65e(Maxlife) - Syn Frankenbrew + XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3211075 - 12/09/13 09:38 AM Re: Oil for Civic lean-burn engine (hybrid)? [Re: 2015_PSD]
gregk24 Offline
Loc: FL, USA
Did I say that? NO....but he said it had good specs, Im wondering what good specs it has. I have considered using it next OCI instead of TGMO but the add pack was the only thing holding me back.
39,xxx miles
#3211321 - 12/09/13 01:53 PM Re: Oil for Civic lean-burn engine (hybrid)? [Re: gregk24]
2015_PSD Offline
Loc: SE Texas
Did you say what? The additive pack in M1 AFE 0W-20 is weak? Why yes, you did say that.
Is that not what you meant or?
#3211339 - 12/09/13 02:23 PM Re: Oil for Civic lean-burn engine (hybrid)? [Re: blackman777]
vinu_neuro Offline
Loc: Chicago / IN
I'm not one for the blind VI hype pushed on this site, but I do think hybrids are a good application for those oils. I'd use the Toyota oil.
Edited by vinu_neuro (12/09/13 02:24 PM)
04 Honda Accord Coupe V6 6MT | M1 EP 0W-20
#3211342 - 12/09/13 02:25 PM Re: Oil for Civic lean-burn engine (hybrid)? [Re: vinu_neuro]
Clevy Offline
Loc: Saskatoon canada
Agreed. That's what the high VI oils were first formulated for,the start stop run cycles.
2006 Charger RT
Miles x 2 per oil filter
#3211806 - 12/09/13 10:49 PM Re: Oil for Civic lean-burn engine (hybrid)? [Re: 2015_PSD]
gregk24 Offline
Loc: FL, USA
No, dont twist words. As far as VOA/UOA go, M1 0w20 does have a weak add pack. There may be other additives that we dont know about though. But as long as I can keep getting TGMO for $6 per quart after tax I will probably keep running that, knowing that its the thinnest oil available on start up for the price, where I live anyway.
39,xxx miles
#3211965 - 12/10/13 06:19 AM Re: Oil for Civic lean-burn engine (hybrid)? [Re: gregk24]
2015_PSD Offline
Loc: SE Texas
I do not believe that I twisted anything since it is a direct quote, but I am not going to quibble over small stuff. I think this is a good example of why VOAs are not the be-all end-all to determine if an additive pack is robust or weak since it is apparent that AFE can be ran for more than 10K with several doing it here. I ran it for more than 15K and it produced the best UOA to date in my FX4 and if it was a one-off UOA I would agree that it could be argued, but since it was #19 there is historical data that can be trended.
Out of curiosity, why would you need to be so concerned over "the thinnest oil available on start up for the price" while living in Florida? Much like Texas, Florida will never see the temperatures needed to warrant the use of the thinnest oil at start-up. Any 5W-xx or 0W-xx oil would be more than thin enough. Is this an experiment of sorts or (no sarcasm--just interested)?
#3212127 - 12/10/13 09:36 AM Re: Oil for Civic lean-burn engine (hybrid)? [Re: 2015_PSD]
gregk24 Offline
Loc: FL, USA
I use it because the driving I do involves multiple starts per day, and all of these are less than 5 mile trips. Most though are literally less than 1 mile.
39,xxx miles
#3212130 - 12/10/13 09:39 AM Re: Oil for Civic lean-burn engine (hybrid)? [Re: blackman777]
Redpatches Offline
Loc: New Jersey
I've run both M1 and TGMO 0W-20 in my Prius with no problems. I would also consider trying Pennzoil Platinum as well. grin
2013 Toyota Prius 32.000 miles
Mobil1 AFE 0W-20 / Fram ToughGuard Filter
2007 Honda Odyssey Touring 110,400
Castrol Edge 5W-20 and Honda OEM Filter
#3212319 - 12/10/13 12:57 PM Re: Oil for Civic lean-burn engine (hybrid)? [Re: blackman777]
gpshumway Offline
Loc: Minneapolis, MN
Well, Honda doesn't seem to think that hi-VI is that important given they switched from the 200 VI Idemitsu 0w20 to the P66 with ~175 VI.
If you're willing to hunt it down Kendall GT-1 should be good and amounts to using the factory oil. Otherwise M1 AFE is the most available and has great specs. Pennzoil Platinum is just slightly less available and will also do very well. I think you're over-thinking this, I believe the engine in a Civic hybrid is an L-series similar to the Fit's engine only with semi-Atkinson valve timing, they're not very picky.
Oh, and Greg- M1 AFE meeting ACEA A1/B1, Ford WSS-M2C945-A and dexos1 trumps anything you might think you can tell about the additive package from a $30 lab analysis. If there's anything weak about M1 AFE it's the shear stability.
2007 Subaru WRX
2011 Honda Civic EX
Page 1 of 2 1 2 >
