5w-40 synthetic vs 15w-40 synthetic
by mbacfp
06/27/16 01:27 PM
SCAM!Anyone renting their water heater tank?
by KrisZ
06/27/16 01:16 PM
Donaldson PowerCore as HEPA filter?
by PeterPolyol
06/27/16 01:13 PM
Clearance oversized filters for M20x1.5 w/bypass
by PeterPolyol
06/27/16 01:05 PM
Prestone vs. DEX-COOL Concentrate
by Ramblejam
06/27/16 12:54 PM
Severe service and OEM oil Filters
by Tech819
06/27/16 12:46 PM
ContiTech Pro Series timing belt kit 2009 Galant
by Ruturaj
06/27/16 12:25 PM
Bogus Coolant Test! - did Pat Goss make a mistake?
by i_hate_autofraud
06/27/16 11:57 AM
The "zero posters"
by OVERKILL
06/27/16 11:57 AM
Removing "Holder?" From Dash
by coopns
06/27/16 11:53 AM
Concrete Cleaners
by dkryan
06/27/16 11:45 AM
What makes CVTF?
by horse123
06/27/16 10:40 AM
karpouzi, Tapan, shindery, Josh_Westwood, Brogan
58283 Registered Users
89 registered (69GTX, Al, 4WD, 901Memphis, AlaskaMike, 360kid, 7 invisible), 2133 Guests and 11 Spiders online.
58283 Members
66 Forums
250883 Topics
Page 2 of 2 < 1 2
#3211444 - 12/09/13 04:01 PM Re: What oil to help quiet aan engine noise [Re: callbay]
clintonhutson Offline
Loc: Austin, TX
If it were me, I'd throw some HDEO (Delo, Delvac, Rotella) in her for a few short OCI's, then see if you've made any progress. If not, then you're looking at either fixing the cause of the problem, or just run it til' it quits. Just up to you whether its worth the time/effort/money at that point.
All IMHO of course...
2008 Dodge Ram 2500 4x4 w/Cummins
2014 Ram 1500 5.7 Hemi
98 Dodge Ram 2500 4x4 w/Cummins
#3211795 - 12/09/13 10:33 PM Re: What oil to help quiet aan engine noise [Re: callbay]
Merkava_4 Offline
Loc: Clovis, CA
20W-50 Mobil Super 5000 should quiet it down nicely.
#3212507 - 12/10/13 03:20 PM Re: What oil to help quiet aan engine noise [Re: callbay]
slug_bug Offline
Loc: Michigan
The tick at 2500rpm might be fixed with a PCV valve change. My 2007 seems to run quieter on QS Defy 5w-30. I wouldn't go thicker or spend the extra bucks for full syn.
2013 Ford Fusion 2.5l (55k)
2010 Lincoln MKX 3.5l (69k)
2007 Dodge Caravan 3.8l (145k)
2003 Merc. Mountaineer 4.6l (90k)
2011 Yamaha Vstar 650 (1k)
#3212597 - 12/10/13 05:11 PM Re: What oil to help quiet aan engine noise [Re: callbay]
andyd Offline
Loc: Marshfield , MA
The engine has been abused. If the rod bearings were showing lots of copper, chances are the mains are trashed, possibly the cam bearings too. Anti freeze will mess up bearings if there is enough of it in the sump. I would test the oil pressure with a mechanical .gauge. If the engine doesnt miss, than it cant be a very bad headgasket. What does the oil on the dipstick look like? I've had a few engines that would rap until the oil pressure came up. It was a bad thrust main in both cases. By no means an immediate death noise. Same with a bad hydraulic lifter or a wrist pin.
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3217660 - 12/15/13 06:16 PM Re: What oil to help quiet aan engine noise [Re: callbay]
Red91 Offline
Loc: Alabama, United States
If you got it for free, I'd say it's worth putting an engine in.
'15 Chevy Cruze LS
1.8 4 Cyl, 6 Speed Auto
QSUD 5/30, STP XL Filter
'92 Buick Roadmaster Wagon
5.7 V8, Auto
QS 20/50, LMMoS2, Napa Gold Filter
Page 2 of 2 < 1 2
