Signature Limits?
by 2015_PSD
05/25/16 04:48 PM
pistol grip shotgun wanted
by FirstNissan
05/25/16 04:14 PM
microGreen Memorial Day Sale
by DBMaster
05/25/16 03:18 PM
Biomed Tech internship - Osceola, FL
by Mr Nice
05/25/16 03:06 PM
New Car - First OCI Subaru Outback
by Oldswagon
05/25/16 02:43 PM
using many cans of crc intake cleaner good?
by ziggy
05/25/16 02:37 PM
Mazda's RX Vision with rotary engine won't happen
by HTSS_TR
05/25/16 01:45 PM
Oil shearing vs fuel dilution
by Popsy
05/25/16 01:31 PM
Told SiriusXM to Pound Sand
by Garak
05/25/16 01:22 PM
CB install '98 F250ld
by asand1
05/25/16 12:53 PM
Kohler K532 Engine John Deere 400
by Bighorn2500
05/25/16 12:41 PM
Champion C165 cut open, 9000km
by turboseize
05/25/16 12:30 PM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
85 registered (AlaskaMike, asand1, 1JZ_E46, Atesz792, albertdi, 10 invisible), 1811 Guests and 349 Spiders online.
57973 Members
66 Forums
249396 Topics
#3211762 - 12/09/13 09:55 PM Any value in getting TBN + TAN of trans oil?
dparm Offline
Loc: Chicago, IL
I am getting my car's dual-clutch fluid changed this Friday. The factory fill will have around 52k on the clock; it is Pentosin FFL-4, and is actually very similar to a Dexron/Mercon ATF, but with GL-4 protection.
Is there any value in getting the TBN and/or TAN measured?
FWIW, BMW classifies it as a lifetime fluid (yeah right).
2011 BMW M3 sedan ZCP
#3211771 - 12/09/13 10:04 PM Re: Any value in getting TBN + TAN of trans oil? [Re: dparm]
chubbs1 Offline
Loc: Merritt Island FL, USA
It would be nice to see how this "lifetime" fluid is holding up and TBN/TAN would be one of the only reasonable ways to check that. It is your money so it is easy for me to say. You are changing it anyway so it doesnt really benefit you to fork out the extra money.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#3211792 - 12/09/13 10:30 PM Re: Any value in getting TBN + TAN of trans oil? [Re: dparm]
Raybo Offline
Loc: Clearwater ,Florida
Huge value. TAN is very important to see how hard the trans is on the fluid. Tell's you exactly how long that type fluid should stay in the trans before it gets acidic.
I like and have used many times:
wearcheck.com
There the big boys in the UOA business and TAN is always included in there UOA. $25.
#3211857 - 12/09/13 11:50 PM Re: Any value in getting TBN + TAN of trans oil? [Re: dparm]
daves87rs Offline
Loc: Michigan
Would be good to learn....
“Never argue with an idiot. They bring you down to their level and beat you with experience.”
#3212005 - 12/10/13 07:23 AM Re: Any value in getting TBN + TAN of trans oil? [Re: dparm]
Donald Offline
Loc: Upstate NY
You should get TAN for non engine lubricants.
Its included with tests from Polaris that are around $18.50 when you buy 10.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3212011 - 12/10/13 07:27 AM Re: Any value in getting TBN + TAN of trans oil? [Re: dparm]
btanchors Offline
Loc: Herndon, VA
TAN would be very valuable, but TBN not valuable. The reason is that a transmission is a "closed" environment. In an engine, one of the oil's jobs is to neutralize the acids that form as a result of combustion gasses "leaking" past piston rings into the oil. In a transmission or differential, the lubricant does not have this function as nothing "leaks in" that causes acid to form - so the lubricant doesn't need to neutralize acids.
However, if a lubricant is stressed due to being overheated, its acid level will rise. This is what TAN is designed to indicate.
So - you want TAN, but not TBN. TBN would be a waste of money.
Others more knowledgeable than I - did I get this right? I think I am on target but I defer to the experts out there...
#3213567 - 12/11/13 03:37 PM Re: Any value in getting TBN + TAN of trans oil? [Re: dparm]
MolaKule Offline
Loc: Iowegia - USA
Being it is factory fluid left in that long, I doubt you are going to discover anything useful, except once you see the analysis, you may want to change the OCI.
For FF fluids, I would want to compare the UOA against the VOA in terms of changes in viscosity.
"You are free to choose, but you are not free from the Consequences of your choice." Dr. Laura. smile
#3213727 - 12/11/13 06:46 PM Re: Any value in getting TBN + TAN of trans oil? [Re: MolaKule]
martinq Offline
Loc: ON, Canada
+1 and +1
Can you get a VOA while you're at it?
#3214335 - 12/12/13 10:08 AM Re: Any value in getting TBN + TAN of trans oil? [Re: martinq]
dparm Offline
Loc: Chicago, IL
+1 and +1
I don't have a bottle of FFL-4. It's expensive stuff ($25/L+). I'll dig around and see if anyone has already done a VOA.
#3215937 - 12/13/13 08:57 PM Re: Any value in getting TBN + TAN of trans oil? [Re: dparm]
bruce381 Offline
Loc: Millbrae, CA
TAN and TBN can be used in ATF but you must have a base line to work from
