Windstar 2001 AC Low and High pressure reading
by pinjc
07/27/16 09:28 PM
Vacuum Pump Oil for rotary vane pumps.
by bunnspecial
07/27/16 09:22 PM
ST dino oil realistic OCI
by OILGEEK27
07/27/16 09:06 PM
Gas grills
by RN89
07/27/16 08:43 PM
Supercharged Subaru BRZ
by clinebarger
07/27/16 07:52 PM
Side can opener ?
by ST2008
07/27/16 07:48 PM
Pennsoil ULTRA not available
by JXW
07/27/16 07:41 PM
2005 Civic randomly stalls when taking off from a
by Avery4
07/27/16 07:36 PM
2003 Saturn L200 oil choice
by car51
07/27/16 07:30 PM
Good hour meter for small engines?
by motor_oil_madman
07/27/16 07:07 PM
2001 Chevy S10 V6 misfire...
by Blang
07/27/16 07:02 PM
Oil level and rpm
by mjoekingz28
07/27/16 06:59 PM
donsladek, rummy, OILGEEK27, pinjc, Lee_C
58627 Registered Users
28 registered (Chewie, Brad_C, chrisri, carlprop, ajchien, bvance554, 1 invisible), 911 Guests and 10 Spiders online.
58627 Members
66 Forums
252339 Topics
Page 2 of 2 < 1 2
#3211539 - 12/09/13 05:46 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
default Offline
Loc: Michigan
I run M1 0w40 in mine, it doesn't burn much(qt every 4k or so on 10w30). Feels a lot smoother too.
Edited by default (12/09/13 05:47 PM)
#3211550 - 12/09/13 05:55 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: rrguy]
OVERKILL Offline
Loc: Ontario, Canada
Originally Posted By: rrguy
I would guess it had to do with motor tolerrances & if too loose maybe concerned with, not keeping enough flow to get adequate oil to all passages?
Clearances, not tolerances are what you are thinking about. And no, they aren't looser.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3211584 - 12/09/13 06:32 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
kschachn Offline
Loc: Upper Midwest
I run 5W-20 in my Sienna and 0W-20 in the ECHO. Both start much better with the thinner oil, and I do see more consumption than with 5W-30. It isn't a lot and considering the easier startups I'm more than willing to put up with having to add oil between OCIs.
1994 BMW 530i, 206K
1996 Honda Accord, 218K
1999 Toyota Sienna, 350K
2000 Toyota ECHO, 255K
#3212318 - 12/10/13 12:55 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: SOHCman]
sw99 Offline
Loc: Colorado
Originally Posted By: SOHCman
I wouldnt do it on the 1zz engine. The reason its probably not backspeced is the 1zz has a documened ring coking issue where the rings run hotter than spec and cook the oil, clog up, and burn oil. My Vibe has the same engine.
I would not skimp on oil quality or grade or do extended OCIs, and if your engine qualifies for the TSB, you can get a new dipstick with higher marks to increase oil splash on the pistons to help control the ring temps. Or you can just fill 10mm over like me so you dont have to get the new dipstick.
Cheers.
Thanks for that info. If thats the real issue, I would think a good quality full synthetic with keep things cleaner in the engine while holding up to the heat cycles better. I will probably just overfill a tad anyway just to be safe.
2016 Nissan Versa S 1.6L
2012 Honda Civic EX 1.8L
2012 Ram CCLB 2500HD 5.7L
2014 LS G3038
#3213929 - 12/11/13 09:45 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
sw99 Offline
Loc: Colorado
Quick little background for my relationship with this car. Got it about a 5 weeks or so ago from a family member. Service records showed pretty regular oil changes at the local quick lube place. Oil fill cap showed light varnish on the top end. Oil in the car at the time had some life left so I have been driving it for the 5 weeks after adding about 6-8 ounces of MMO to start the clean up.
Well today I whipped up a franken brew today for sure... I added 1 qt of ST 5w20 left over from the Civic's oil change, 2 qt's of Mobil Super 5000 5w20, 3/4 qt of MMO and about 6 ounces of Rotella 15w40.
I am going to give the thinner oil a shot. This car cost me $1500 so I am ok with trying the not so recommended. I'll run this for at least 5K see if it helped clean up the varnish.
2014 LS G3038
#3213953 - 12/11/13 10:14 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
FutureDoc Offline
Loc: North Carolina
Following... gotta keep track of those 1ZZ engines.
'15 Hyundai Genesis Coupe 3.8 - FF 5w-30
'14 Subaru Outback 2.5 - NAPA 0w-20 & Wix
'01 Toyota MR2 Spyder - Havoline Syn 5w-30 & Wix
#3215433 - 12/13/13 11:12 AM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
SOHCman Offline
Loc: USA
No problem, another trick us to use a small file and make a light mark above the full mark on the dipstick, for ease of filling and tracking consumption.
My 1zz was pretty varnished as well, you may want to inspect and clean out the PCV system if needed, i did this in conjunction with checking valve specs. Completely soaked and flushed the valve cover/baffel system that was very gummed up with carbon and varnished. I believe that, along with using a quality high milage synthetic at conservative intervals has greatly helped the consumption and de-coked the rings. The cieling of the valve cover baffel plate seems to get zero oil sling from the cams somehow and had a dry brownish tarnish that resisted removal. Basically i think this engine destroys oil that cant hold up to the temps, and clogs the pcv loop and intake with the burning oil. You just have to keep up on the maintenance.
Do or do not, there is no try. USA
#3215560 - 12/13/13 01:23 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
stchman Offline
Loc: St. Louis, MO
I don't think the OP will get an appreciable fuel economy gain from running 0W-20 or 5W-20 over 5W-30.
Just stick with what the manufacturer recommends.
2013 Chevrolet Silverado LTZ 2WD 5.3L
Amsoil Signature Series 5W-30
Amsoil Ea15K50
Page 2 of 2 < 1 2
