Penrite 5W-30 Full Synthetic
by KL31
37 minutes 35 seconds ago
PP HM at Walmart
by dlundblad
Today at 04:55 AM
74/76mm x 15 Flutes
by Merkava_4
Today at 04:33 AM
Autozone - Pennzoil with the PP - Rebates
by Kwuality
Today at 03:29 AM
Old Toyota
by artbuc
Today at 03:18 AM
Shell Helix Ultra 5W-20 & 0W-20 in Australia
by SR5
Today at 03:03 AM
Little different lube regimen on my 454
by Alex_V
Today at 03:00 AM
REPCO oil sale this weekend in Australia
by SR5
Today at 02:58 AM
ALG Go-Juice
by Ws6
Today at 02:55 AM
Stupid ? 20hp Intek b&s
by southernjeeper
Today at 02:23 AM
Mouse Guns
by bobbob
Today at 02:14 AM
Grease for gun
by DARKSCOPE001
Today at 01:44 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
54 registered (akcooper9, beanoil, aquariuscsm, BigD1, Bandito440, 97K15004WD, 4 invisible), 1133 Guests and 11 Spiders online.
58332 Members
66 Forums
251080 Topics
Page 1 of 2 1 2 >
#3211183 - 12/09/13 12:09 PM 2001 Corolla - Why not 5w20 or 0w20?
sw99 Offline
Loc: Colorado
I have seen the "Unofficial" oil Toyota Chart that says 0w20 / 5w20 can be used in my Corolla (down to 1999). I have read the TSB (a while back) that showed the back spec to 5w20 down to 2006 IIRC. So... What is the reason Toyota did not back spec the 1999-2005 VVT-i 1ZZFE to 5w20? I know these year toyotas has small oil passages that would clog and result in oil burning. Seems to me that a thinner oil would flow better and reduce the clogging problem. As far as a timing chain, lots of new cars run chains and use 0w20.
Yes, the manual says 5w30 but my curiosity is getting the best of me. I want to maximize my fuel economy plain and simple. This new to me Corolla has some varnish that I am working to clean up. If all goes well, I plan to run 0w20 for 10k or so then send off an oil sample.
Am I crazy to even be thinking this. I guess my biggest question is why not?
2016 Nissan Versa S 1.6L
2012 Honda Civic EX 1.8L
2012 Ram CCLB 2500HD 5.7L
2014 LS G3038
#3211225 - 12/09/13 12:39 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
StevieBoy Offline
Loc: Central Florida
Your logic sounds good to me. I think you should try it. If you are nervous about it start with a mix of M1 0W-30 & 0W-20.
2016 Grand Cherokee Laredo
75th Anniversary Edition
#3211231 - 12/09/13 12:44 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
Miller88 Offline
Loc: Onondaga County
Were there any mechanical changes with the engine?
I would think that a 0/5w-20 would be better ... A 0w-20 would be a good quality oil that would help clean up, and prevent sludging of the passages in the future.
I'd run a mix of 0w30 and 0w-20, get a UOA and if it's good, go to 0w-20.
Originally Posted By: 01rangerxl
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3211234 - 12/09/13 12:47 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
Rolla07 Offline
Loc: MTL, CANADA
I understand your logic in thinking of going to a lighter oil, but I doubt you will notice much if any MPG gain by going to a lighter oil. These cars are known to burn oil, and I dont see how using a lighter oil will do anything different. I would use a quality 5W30 like PU and see how things go. Although, you can certainly put in 0w20 and see how it goes. Either way, the worst that will happen is that you will change the oil back again.
2007 Corolla Red Pearl 138k miles
Pennz Ultra 0w40 & Napa Proselect
#3211242 - 12/09/13 12:52 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
FutureDoc Offline
Loc: North Carolina
I am not sure on the Xw20 usage on the 1ZZ-FE engines (my MR2 has the same engine). I know some (1999/2000) had rod bearing issues but this was more common on Celica and MR2s... which also might be driver enthusiasm compounding the issue.
'15 Hyundai Genesis Coupe 3.8 - FF 5w-30
'14 Subaru Outback 2.5 - NAPA 0w-20 & Wix
'01 Toyota MR2 Spyder - Havoline Syn 5w-30 & Wix
#3211252 - 12/09/13 12:56 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
BillyTheKid Offline
Loc: ny
Three people I know have this same car and they all use oil. I would avoid the lighter weight oil if it were me. My father is one of the three and nothing I have used including Max Life have stopped it. Max Life slowed it the most, but not stopped it. PU it is sipping down as fast or faster than any other oil. This is all 5-30 weight. May try to start adding something thicker at top offs moving forward for him.
#3211260 - 12/09/13 01:04 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
2012AccentSE Offline
Loc: TX
5w20/0w20 has barely caught on as a trusted weight with most car makers. I bet in the late 90's car manufactures didn't ever think about 5w20 because it wasn't a popular choice at all or non existent in a lot of areas. As for specs, Toyota probably didn't back spec that far back because what's the point? A management perspective would be why try and support an old product? Most of these cars are probably gone or sold to their 3rd or 4th owners by now...Let's support the new stuff!
This is just a guess smile
Edited by 2012AccentSE (12/09/13 01:04 PM)
2008 F150 KR 5.4L
Oil-?
Filter-?
#3211275 - 12/09/13 01:15 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
tc1446 Offline
Loc: Lexington, NC
With the cold wx you have I'd say go with 5-20. Easier to find and should work well. Mobil Super comes to mind and readily avail at Walmart. Come summer, change to 5-30 if its convenient. Thats all I ever used on my '04, mostly M1, and ran it 10K each oci. At 160K it used very little, perhaps a pint between changes.
'13 Accord EX-L (60K)
'00 Ford Ranger {56K}
'14 Can Am SE6 (23K)
'12 Yam Majesty (5K)
'16 Polaris Slingshot (three wheeler)
#3211287 - 12/09/13 01:24 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
quint Offline
Loc: Cincinnati
I have been using either M1 or PP 0w-20 in my '97 Corolla (4AFE engine), even though it was not back spec'd for 0w-20 or 5w-20 either, I suspect due to the reputation it shares for oil burning due to the insufficient piston oil drain holes/gunk'd up oil ring, but after using it for about 7,000 miles now the horrific oil consumption it has been experiencing for the last umpteen years at first got even more horrific, but then went back to where it was, and is now DOWN about 20-30%, if the numbers on my Excel tracking sheet are to be believed. Its still bad, but its noticeably and numerically less bad than it was....
It also had a slight oil drip, maybe 2-3 drops a week, from between the engine and trans. When I first went to the 0w-20, that increased some... a few more oil spots here and there. Then it stopped completely. I havent seen any new, wet oil spots on the driveway in 3-4 months at least. The last time I was under the car, about 3 weeks ago, it looked pretty good. No impending drips that I could see.
I dont track the gas mileage the way I track the oil useage so I cant really say if its changed at all. It seems to get great mpg no matter what (low 30's). If you do change to 5w- or 0w-20, I wouldnt expect much of a gain, if any.
I think you are plenty safe in experimenting with it though. So far it seems to be doing pretty well in own my case.
My neighbor/friend has an '01 and his gulps down whatever oil we use in it (I do most of his maintenance). Mostly maxlife 5w-30 or whatever else is on sale.
Edited by quint (12/09/13 01:27 PM)
1993 240sx convertible (238,000)
2001 Toyota Sequoia (146,000)
2012 Mazda3 (71,000)
2012 Mazda2 (53,000)
1997 Corolla (356,000+)
#3211290 - 12/09/13 01:26 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
SOHCman Offline
Loc: USA
I wouldnt do it on the 1zz engine. The reason its probably not backspeced is the 1zz has a documened ring coking issue where the rings run hotter than spec and cook the oil, clog up, and burn oil. My Vibe has the same engine.
I would not skimp on oil quality or grade or do extended OCIs, and if your engine qualifies for the TSB, you can get a new dipstick with higher marks to increase oil splash on the pistons to help control the ring temps. Or you can just fill 10mm over like me so you dont have to get the new dipstick.
Cheers.
Do or do not, there is no try. USA
#3211376 - 12/09/13 02:59 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: SOHCman]
bepperb Offline
Loc: Milwaukee, WI
Originally Posted By: SOHCman
.... you can get a new dipstick with higher marks to increase oil splash on the pistons to help control the ring temps. Or you can just fill 10mm over like me so you dont have to get the new dipstick.
Cheers.
I was going to say, I think the 0w-20 is ok when the engine has the new dipstick with increased oil capacity and/or a change to the piston rings.
If you plain and simple wanted better fuel economy you could overfill a half quart with 0w-20 and check it every gas fill up. There's probably a dozen better ways to increase fuel economy, though.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#3211423 - 12/09/13 03:35 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
rrguy Offline
Loc: MN
I would guess it had to do with motor tolerrances & if too loose maybe concerned with, not keeping enough flow to get adequate oil to all passages?
"This post is uselesss without pics"
Royal Purple
Semper Fi
#3211442 - 12/09/13 03:57 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
cheesepuffs Offline
Loc: Connecticut
A family member of mine has the same car and I found that even M1 5w-30 burned very quickly. Like others said, thinner oil is just gonna burn off even faster. So far believe it or not, GTX burns off the slowest of what I've tried out.
Not to get off topic but I might try GTX SynBlend next. You guys think is has as good or better cleaning ability than PYB?
2002 Honda Accord Coupe
Mobil Special 5W-20, Honda filter
#3211448 - 12/09/13 04:05 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
Smokescreen Offline
Loc: Alberta, Canada
There were some reported oil consumption issues even on the 2009+ models using 5w20. I wouldn't use it on the new ones either. Remember 5w20 is a CAFE initiative. Around the other parts of the world there is no call to use anything lighter than 5w30 in the older engines. They barely get a mention for the new engines. They specify all the way up to a 40wt in the world owners manuals.
I have been using 5w30 since 600 miles and I have zero consumption.
09 Corolla 1.8L-300Kkms(187Kmi)-PP,Denso
05 LeSabre 3.8L-235Kkms(146Kmi)-F1,Delco
03 Sierra 6.0L-194Kkms(121Kmi)-F1,Delco
All with mpg > EPA
#3211523 - 12/09/13 05:36 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: Smokescreen]
wag123 Offline
Loc: Texas
Just use M1 AFE 0w30 and be done with it. It is a direct replacement for 5w30 in all 5w30 applications and it will get you 95% of what you are trying to accomplish.
Edited by wag123 (12/09/13 05:37 PM)
#3211539 - 12/09/13 05:46 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
default Offline
Loc: Michigan
I run M1 0w40 in mine, it doesn't burn much(qt every 4k or so on 10w30). Feels a lot smoother too.
Edited by default (12/09/13 05:47 PM)
#3211550 - 12/09/13 05:55 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: rrguy]
OVERKILL Offline
Loc: Ontario, Canada
Clearances, not tolerances are what you are thinking about. And no, they aren't looser.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3211584 - 12/09/13 06:32 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
kschachn Offline
Loc: Upper Midwest
I run 5W-20 in my Sienna and 0W-20 in the ECHO. Both start much better with the thinner oil, and I do see more consumption than with 5W-30. It isn't a lot and considering the easier startups I'm more than willing to put up with having to add oil between OCIs.
1994 BMW 530i, 206K
1996 Honda Accord, 217K
1999 Toyota Sienna, 348K
2000 Toyota ECHO, 254K
#3212318 - 12/10/13 12:55 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: SOHCman]
sw99 Offline
Loc: Colorado
Cheers.
Thanks for that info. If thats the real issue, I would think a good quality full synthetic with keep things cleaner in the engine while holding up to the heat cycles better. I will probably just overfill a tad anyway just to be safe.
2014 LS G3038
#3213929 - 12/11/13 09:45 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
sw99 Offline
Loc: Colorado
Quick little background for my relationship with this car. Got it about a 5 weeks or so ago from a family member. Service records showed pretty regular oil changes at the local quick lube place. Oil fill cap showed light varnish on the top end. Oil in the car at the time had some life left so I have been driving it for the 5 weeks after adding about 6-8 ounces of MMO to start the clean up.
Well today I whipped up a franken brew today for sure... I added 1 qt of ST 5w20 left over from the Civic's oil change, 2 qt's of Mobil Super 5000 5w20, 3/4 qt of MMO and about 6 ounces of Rotella 15w40.
I am going to give the thinner oil a shot. This car cost me $1500 so I am ok with trying the not so recommended. I'll run this for at least 5K see if it helped clean up the varnish.
2014 LS G3038
#3213953 - 12/11/13 10:14 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
FutureDoc Offline
Loc: North Carolina
Following... gotta keep track of those 1ZZ engines.
#3215433 - 12/13/13 11:12 AM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
SOHCman Offline
Loc: USA
No problem, another trick us to use a small file and make a light mark above the full mark on the dipstick, for ease of filling and tracking consumption.
My 1zz was pretty varnished as well, you may want to inspect and clean out the PCV system if needed, i did this in conjunction with checking valve specs. Completely soaked and flushed the valve cover/baffel system that was very gummed up with carbon and varnished. I believe that, along with using a quality high milage synthetic at conservative intervals has greatly helped the consumption and de-coked the rings. The cieling of the valve cover baffel plate seems to get zero oil sling from the cams somehow and had a dry brownish tarnish that resisted removal. Basically i think this engine destroys oil that cant hold up to the temps, and clogs the pcv loop and intake with the burning oil. You just have to keep up on the maintenance.
#3215560 - 12/13/13 01:23 PM Re: 2001 Corolla - Why not 5w20 or 0w20? [Re: sw99]
stchman Offline
Loc: St. Louis, MO
I don't think the OP will get an appreciable fuel economy gain from running 0W-20 or 5W-20 over 5W-30.
Just stick with what the manufacturer recommends.
2013 Chevrolet Silverado LTZ 2WD 5.3L
Amsoil Signature Series 5W-30
Amsoil Ea15K50
Page 1 of 2 1 2 >
