2016 Volkswagen Tiguan Oil filter - Weird Design?
by FordBroncoVWJeta
07/26/16 02:21 AM
New old ride
by SEBZX79
07/25/16 11:25 PM
Motor Trend Visit with Valvoline
by tenderloin
07/25/16 10:46 PM
Fixing Tractors a no-no, Are cars next?
by user52165
07/25/16 10:38 PM
Cosmetic only or replace
by ram_man
07/25/16 09:55 PM
Wooden Motorcycle Piston from Vietnam
by KeithS_NW_Ohio
07/25/16 09:49 PM
Castrol Edge for hard-driven turbo + DI
by Atomic
07/25/16 09:27 PM
2001 Camry LE V6 - Synthetic ATF Recommendation
by 01CAMRY
07/25/16 08:39 PM
Delo 400?
by Sealbilly
07/25/16 07:17 PM
Noob question about chain maintenance
by JeepWJ19
07/25/16 07:00 PM
Rural King Full Synthetic Oil Sale...
by AnthemBassMan
07/25/16 05:16 PM
Mobil 1 EP oil filter - Cross Reference
by Kung_Faux
07/25/16 05:08 PM
rfabrocini, Tobin28, r0k, KNA, Roanoke6370
58598 Registered Users
56 registered (2009Edge, 4WD, aquariuscsm, 09_GXP, AlienBug, 4 invisible), 1086 Guests and 18 Spiders online.
58598 Members
66 Forums
252249 Topics
Page 1 of 2 1 2 >
#3211095 - 12/09/13 10:05 AM What oil to help quiet aan engine noise
callbay Offline
Loc: Ozark Mountains
2005 3.8 V/6 Doge mini van. 156,000 miles. We just got it for free because of the engine noise.
We had the oil pan off to change the very loose timing chain. It did not help the noise. About an inch of sludge in the pan but the rest of the engine looked amazingly clean,like new.
My theroy is that the block leaked coolant/water into the engine and created the sludge. I put stopleak in the coolant and it stopped the leak.
Not worth doing much else to the engine. We have driven it about 1,200 miles and it has got not gotten worse. Have Napa Gold filter and high milage Mobil 5-30 semi synthetic in it now.
Thnking of trying 10-40 synthetic or 20-50 dyno to quiet help quit it down.
Any thoughts? Thanks!
#3211120 - 12/09/13 10:36 AM Re: What oil to help quiet aan engine noise [Re: callbay]
Roob Offline
Loc: Ontario,Canada
Can you offer any description of the noise? When it occurs? At idle, when driving, only at startup? Was the oil milky/off color when you changed it?
The sludge in the pan will be from not changing the oil/regular maintenance and guaranteed it's elsewhere in the engine.
If it's had a coolant leak combined with no oil changes, then you could be dealing with bearing damage and that's a possible source of noise.
Unless you have to have this car;
Do the next person a favor who might get it for free and donate it to a scrapyard. crush
2007 Accord Coupe 2.4 Vtec.
QSGB 5w20 with Fram TG
HDW1+ LG Platinum
Toyo Versado Noir-V
#3211124 - 12/09/13 10:39 AM Re: What oil to help quiet aan engine noise [Re: callbay]
Miller88 Offline
Loc: Onondaga County
Surprised someone would give away an 8 year old vehicle!
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3211129 - 12/09/13 10:45 AM Re: What oil to help quiet aan engine noise [Re: callbay]
Corvette Owner Offline
Loc: Waldorf, Maryland
Try penzoil ultra, one of best cleaning oils.
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
#3211142 - 12/09/13 11:01 AM Re: What oil to help quiet aan engine noise [Re: callbay]
chubbs1 Offline
Loc: Merritt Island FL, USA
Keep doing what you are doing. You got the thing for free so you have to expect something wrong with it. No oil will stop the noise, don't go too thick because that can cause unnecessary drag on the engine especially in the cold months. You can try 10w40 but I dont think it will give you the results you are looking for. Just drive that thing into the ground.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#3211150 - 12/09/13 11:13 AM Re: What oil to help quiet aan engine noise [Re: callbay]
racer12306 Offline
Loc: Baltimore, MD
Just run it til it dies. I probably wouldn't trust it for any long haul stuff where a tow would be costly.
04 Dodge Neon SXT/2.0/MTX/MaxLife 5w30/Fram Ultra/7500
12 Chrysler T&C/3.6/6A/5w30PU/PureONE/OLM
#3211153 - 12/09/13 11:17 AM Re: What oil to help quiet aan engine noise [Re: callbay]
NHGUY Offline
Loc: USA
Is that noise a metallic rattling sound that occurs a few minutes after startup,when the oil starts thinning?
#3211162 - 12/09/13 11:30 AM Re: What oil to help quiet aan engine noise [Re: callbay]
440Magnum Offline
Loc: Texas
IF coolant got in the oil on that iron block engine, it was probably through a head gasket. Worth fixing, if the bottom end hasn't actually been trashed- what's the actual noise, I didn't see any description of what it sounded like? Early (as in pre-95) 3.8 engines had a problem with cracking the rocker shaft saddles in the heads and it would create a very loud top-end "ticking" sound. That wasn't a common problem later on, but if a saddle is cracked it could explain both the coolant in the oil and the noise... maybe.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3211167 - 12/09/13 11:42 AM Re: What oil to help quiet aan engine noise [Re: callbay]
Rand Offline
Loc: NE,Ohio
just throw some 15w40 in it.. maybe get a uoa after 1000miles to see if there is coolant. otherwise just drive it till she blows.
2015 Forester I-Premium 6MT
#3211169 - 12/09/13 11:43 AM Re: What oil to help quiet aan engine noise [Re: callbay]
Boss302fan Offline
Loc: Oconomowoc Wi
All the above and try QSUD...
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
#3211176 - 12/09/13 11:53 AM Re: What oil to help quiet aan engine noise [Re: callbay]
Clevy Offline
Loc: Saskatoon canada
Liqui-moly makes a product called mos2. A member here used some form of sound metering device on his engines before using mos2 and after and he noted a decrease in noise output with the addition of mos2.
Its cheap and in my experience lessens fuel consumption. Its a friction modifier. They also make a product called motor oil saver. It may help too. It's an ester fortified with boron so it re-condition gaskets helping eliminate leaks.
2006 Charger RT
Miles x 2 per oil filter
#3211182 - 12/09/13 12:06 PM Re: What oil to help quiet aan engine noise [Re: callbay]
callbay Offline
Thanks, Guys. I forgot to say that we changed out the rod bearing when we had the pan off. A couple of them were almost not there anymore.All had some damage.
It has a loud ticking sound on start up that quiets down quickly and then you don't hear much driving till about 2,500 rpm and then you can hear it again.
#3211191 - 12/09/13 12:17 PM Re: What oil to help quiet aan engine noise [Re: callbay]
TFB1 Offline
Loc: VA
If the rod bearings were that bad it no doubt has bad main bearings as well and probably a damaged crankshaft... No oil will fix those issues...
#3211286 - 12/09/13 01:23 PM Re: What oil to help quiet aan engine noise [Re: callbay]
Kuato Offline
Loc: In transit...
IMO, sounds like there is an oil blockage somewhere. Keep using a good cleaning oil on short intervals and cross your fingers.
At the worst you will get the van for the cost of a new engine.
Your oil's condition is speculation until you get a UOA done.
2013 F150, 5.0 4x4, 52k Schaeffer 9000
#3211402 - 12/09/13 03:19 PM Re: What oil to help quiet aan engine noise [Re: callbay]
rrguy Offline
Loc: MN
Wow you got it free? lucky thats a good van & motor normally good for 225,000 plus.
I have heard of a few guys with a jeep chyrsler ticking & royal purple quieted there engine I do not recall the weight or sereies they tried, but calling RP customer servie & they would be able to help you. I chuckle at those engine rebuilds in a can so don't know what oil will really help, but you can even dump in a couple quarts?
"This post is uselesss without pics"
Royal Purple
Semper Fi
#3211444 - 12/09/13 04:01 PM Re: What oil to help quiet aan engine noise [Re: callbay]
clintonhutson Offline
Loc: Austin, TX
If it were me, I'd throw some HDEO (Delo, Delvac, Rotella) in her for a few short OCI's, then see if you've made any progress. If not, then you're looking at either fixing the cause of the problem, or just run it til' it quits. Just up to you whether its worth the time/effort/money at that point.
All IMHO of course...
2008 Dodge Ram 2500 4x4 w/Cummins
2014 Ram 1500 5.7 Hemi
98 Dodge Ram 2500 4x4 w/Cummins
#3211795 - 12/09/13 10:33 PM Re: What oil to help quiet aan engine noise [Re: callbay]
Merkava_4 Offline
Loc: Clovis, CA
20W-50 Mobil Super 5000 should quiet it down nicely.
#3212507 - 12/10/13 03:20 PM Re: What oil to help quiet aan engine noise [Re: callbay]
slug_bug Offline
Loc: Michigan
The tick at 2500rpm might be fixed with a PCV valve change. My 2007 seems to run quieter on QS Defy 5w-30. I wouldn't go thicker or spend the extra bucks for full syn.
2013 Ford Fusion 2.5l (55k)
2010 Lincoln MKX 3.5l (69k)
2007 Dodge Caravan 3.8l (145k)
2003 Merc. Mountaineer 4.6l (90k)
2011 Yamaha Vstar 650 (1k)
#3212597 - 12/10/13 05:11 PM Re: What oil to help quiet aan engine noise [Re: callbay]
andyd Offline
Loc: Marshfield , MA
The engine has been abused. If the rod bearings were showing lots of copper, chances are the mains are trashed, possibly the cam bearings too. Anti freeze will mess up bearings if there is enough of it in the sump. I would test the oil pressure with a mechanical .gauge. If the engine doesnt miss, than it cant be a very bad headgasket. What does the oil on the dipstick look like? I've had a few engines that would rap until the oil pressure came up. It was a bad thrust main in both cases. By no means an immediate death noise. Same with a bad hydraulic lifter or a wrist pin.
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3217660 - 12/15/13 06:16 PM Re: What oil to help quiet aan engine noise [Re: callbay]
Red91 Offline
Loc: Alabama, United States
If you got it for free, I'd say it's worth putting an engine in.
'15 Chevy Cruze LS
1.8 4 Cyl, 6 Speed Auto
QSUD 5/30, STP XL Filter
'92 Buick Roadmaster Wagon
5.7 V8, Auto
QS 20/50, LMMoS2, Napa Gold Filter
Page 1 of 2 1 2 >
