Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
Troy Bilt Pony
by OSUFan86
02/10/16 06:43 PM
$1.33 for a GALLON of 87!
by Vern_in_IL
02/10/16 06:30 PM
Eating out, beware you all
by CourierDriver
02/10/16 06:13 PM
Best Sponge For Washing Cars
by George7941
02/10/16 06:08 PM
threeeightteen, TOADchunks, Longo9596, Roadrunner77z, rp5677
56888 Registered Users
94 registered (69GTX, AZjeff, bdcardinal, 901Memphis, 74DartSport, 2015_PSD, 5 invisible), 1236 Guests and 213 Spiders online.
56888 Members
66 Forums
244530 Topics
Page 2 of 2 < 1 2
#3211444 - 12/09/13 04:01 PM Re: What oil to help quiet aan engine noise [Re: callbay]
clintonhutson Offline
Loc: Austin, TX
If it were me, I'd throw some HDEO (Delo, Delvac, Rotella) in her for a few short OCI's, then see if you've made any progress. If not, then you're looking at either fixing the cause of the problem, or just run it til' it quits. Just up to you whether its worth the time/effort/money at that point.
All IMHO of course...
2008 Dodge Ram 2500 4x4 w/Cummins
2014 Ram 1500 5.7 Hemi
98 Dodge Ram 2500 4x4 w/Cummins
#3211795 - 12/09/13 10:33 PM Re: What oil to help quiet aan engine noise [Re: callbay]
Merkava_4 Offline
Loc: Clovis, CA
20W-50 Mobil Super 5000 should quiet it down nicely.
#3212507 - 12/10/13 03:20 PM Re: What oil to help quiet aan engine noise [Re: callbay]
slug_bug Offline
Loc: Michigan
The tick at 2500rpm might be fixed with a PCV valve change. My 2007 seems to run quieter on QS Defy 5w-30. I wouldn't go thicker or spend the extra bucks for full syn.
2013 Ford Fusion 2.5l (50k)
2010 Lincoln MKX 3.5l (66k)
2007 Dodge Caravan 3.8l (144k)
2003 Merc. Mountaineer 4.6l (82k)
2011 Yamaha Vstar 650 (< 1k)
#3212597 - 12/10/13 05:11 PM Re: What oil to help quiet aan engine noise [Re: callbay]
andyd Offline
Loc: Marshfield , MA
The engine has been abused. If the rod bearings were showing lots of copper, chances are the mains are trashed, possibly the cam bearings too. Anti freeze will mess up bearings if there is enough of it in the sump. I would test the oil pressure with a mechanical .gauge. If the engine doesnt miss, than it cant be a very bad headgasket. What does the oil on the dipstick look like? I've had a few engines that would rap until the oil pressure came up. It was a bad thrust main in both cases. By no means an immediate death noise. Same with a bad hydraulic lifter or a wrist pin.
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
#3217660 - 12/15/13 06:16 PM Re: What oil to help quiet aan engine noise [Re: callbay]
Red91 Offline
Loc: Alabama, United States
If you got it for free, I'd say it's worth putting an engine in.
'15 Chevrolet Cruze LS
1.8 4 Cyl, 6 Speed Auto
QSUD 5W-30, STP Extended Life S10246XL Filter
Page 2 of 2 < 1 2
