Out with the old, in with the new F150
by MNgopher
06/30/16 12:14 PM
Hard Workers
by AirgunSavant
06/30/16 10:55 AM
which kind of vinegar to use?
by bmwjohn
06/30/16 10:53 AM
0% ethanol gas please
by yvon_la
06/30/16 10:17 AM
Motorex Legend 4T
by Junkie
06/30/16 09:56 AM
2ZR-FE Oil filter Comparison
by Tech819
06/30/16 09:45 AM
Andrews AFB
by AirgunSavant
06/30/16 08:55 AM
Luber Finer cut open
by Tech819
06/30/16 08:42 AM
Meguiars wax
by whip
06/30/16 08:02 AM
Weird problem with laptop. Thoughts?
by d00df00d
06/30/16 07:42 AM
Silverado 6.2L Fram TG 3 years and ~45,000 miles
by DriveHard
06/30/16 07:15 AM
Old bike, new engine -synth or dino oil?
by mr_blackstock
06/30/16 06:56 AM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
80 registered (901Memphis, AirgunSavant, 97f150, 97K15004WD, 87sammy, 3 invisible), 1885 Guests and 8 Spiders online.
58322 Members
66 Forums
251033 Topics
Page 1 of 3 1 2 3 >
#2416248 - 10/25/11 07:28 PM Mobil 5w50 SN VOA
Matt_N Offline
Loc: Akron, OH
I recently picked up four cases of M1 5w50 for the wholesale distributor near my work (Petroalliance / Cleveland). All four cases were API SN, so I sent in a sample to see what (if anything) changed in this formulation.
Good news -- Not much changed! Below is a link to a VOA I had done with API SM M1 5w50 exactly a year ago: API SM M1 5w50 VOA
Below is the VOA for the new SN 5w50:
AL, CHRM, FE, CU, PB, TIN = ALL 0 PPM. Trace of Potassium, Sodium, Silicon.
MOLY = 91
BORON = 242
CALCIUM = 3127
MAGNESIUM = 24
PHOS = 951
ZINC = 1132
kV @ 100C = 16.43 cSt
Flashpoint = 435F
I had them re-test the kV @ 100C, seemed thinner than M1 spec'd -- they verified the 16.43 cSt measurement.
Continue to use the Mobil 1 5w50 SN with confidence!
Matt
#2416388 - 10/25/11 09:32 PM Re: Mobil 5w50 SN VOA [Re: Matt_N]
HTSS_TR Offline
Loc: Lake Forest, CA
The add pack seem to be a little better with SN.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2416454 - 10/25/11 10:53 PM Re: Mobil 5w50 SN VOA [Re: Matt_N]
SIXSPEED Offline
Loc: Arizona
Looks just like the API SM sample I had tested earlier in the year. Did you have it tested for TBN? BTW what were the trace levels for the Potassium, Sodium, and Silicon?
Thanks for sharing the VOA results. I'll continue to use this oil; wish it was available locally.
Edited by SIXSPEED (10/25/11 10:54 PM)
#2416639 - 10/26/11 07:52 AM Re: Mobil 5w50 SN VOA [Re: Matt_N]
buickmaster Offline
Loc: Cleveland, OH
WOOT!!! Thanks Matt for this. I'm now satisfied with running my 50/50 mix of M1 SN 0w40 and 5w50.
I also don't feel too bad now driving to Petroalliance to pick up my case now either. I was feeling a bit crazy, but seeing as you came up from Akron I don't feel too bad. I'm in Shaker.
Edited by buickmaster (10/26/11 07:56 AM)
1991 Mitsubishi Galant VR4 - 2.0L 4G63T/4WD/4WS (me)
196k mi - M1 0W40/5W50 Mix
2012 Kia Forte - 2.0L Theta II (wife)
2500 mi - OEM
#2419495 - 10/29/11 09:32 AM Re: Mobil 5w50 SN VOA [Re: Matt_N]
virginoil Offline
Loc: western australia
kV @ 100C = 16.43c St is less than 16.5 and is this a 5w40 weight ?
Zn is about 140ppm more for the SN version. ie 14% more.
Edited by virginoil (10/29/11 09:36 AM)
Arriverdici e buona sera
#2419516 - 10/29/11 10:03 AM Re: Mobil 5w50 SN VOA [Re: virginoil]
SIXSPEED Offline
Loc: Arizona
It's > 16.3 cSt, which qualifies for being a 50 grade oil.
Edited by SIXSPEED (10/29/11 10:05 AM)
#3209446 - 12/07/13 12:49 PM Re: Mobil 5w50 SN VOA [Re: Matt_N]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
A KV100 of 16.43cSt is still a fair bit lower than the published figure of 17.5cSt.
Is not uncommon with heavier oil grades in particular to err on the low side when additizing the required amount of polymer thickener.
The result is an oil that is somewhat lighter, has a lower VI but is a more shear stable oil.
With a given HTHSV of 4.4cP it's really probably closer to 4.2cP which still a whole lot heavier than M1 0W-40.
I'd be interested to see a UOA on this oil to how well it stands up. My guess is pretty well.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3231771 - 12/30/13 10:51 AM Re: Mobil 5w50 SN VOA [Re: CATERHAM]
Matt_N Offline
Loc: Akron, OH
It has done an outstanding job for my application. I have a 2007 Porsche Cayman S that sees considerable track use in the warmer months, and is stored winters. My UOAs are based on # of track events, not mileage. I change after every two events (4-6 total days of track time, which could be anywhere from 400-700mi of operation under track conditions, plus whatever freeway miles are required to commute to/from the track)
My wear metals are always in the single digits, lowest TBN was 7.7, and kV @ 100C readings have been (most to least recent) = 15.94, 16.09, 14.90, 14.41, 14.43. NOTE -- I had an additional radiator installed two OCIs ago. The purpose of the radiator is to provide additional cooling capacity for the water cooling system, which in turn will help better manage oil temps. Judging from the improvement in [email protected] measurements (from 14.9 to 16+)in the UOAs, it seems like that investment is doing it's job.
I know I could leave the oil in longer, but it's cheap insurance. If you can score this stuff from NAPA during their annual M1 sale, it ends up being really really cheap insurance.
#3234055 - 01/01/14 07:49 PM Re: Mobil 5w50 SN VOA [Re: Matt_N]
Clevy Offline
Loc: Saskatoon canada
I know I could leave the oil in longer, but it's cheap insurance. If you ocan score this stuff from NAPA during their annual M1 sale, it ends up being really really cheap insurance.
How exactly is dumping oil that isn't depleted and replacing it with oil that isn't depleted "cheap insurance"
Sounds more like expensive insurance considering if the tbn is at 7 and starts at 9 or 10 you've effectively thrown money out the window.
Cheap insurance,right,because the oil is some kind of risk.
2006 Charger RT
Miles x 2 per oil filter
#3237538 - 01/04/14 07:07 PM Re: Mobil 5w50 SN VOA [Re: Matt_N]
CATERHAM Offline
Have you installed an oil pressure gauge in your Cayman?
The KV100 values in a UOA won't tell you if you actually need to run anything heavier the the spec' M1 0W-40. For M1 0W-50 to possibly be considered worthwhile you're going to have to routinely get your oil temp's over 120C.
What are your maximum oil temp's and minimum OP values at 5,000 rpm?.
#3238423 - 01/05/14 03:00 PM Re: Mobil 5w50 SN VOA [Re: Matt_N]
A_Harman Offline
Loc: Michigan
MOLY = 91
BORON = 242
CALCIUM = 3127
MAGNESIUM = 24
PHOS = 951
ZINC = 1132
From a recent VOA for M1 0w40:
Mo = 74
B = 221
Ca = 3003
Mg = 19
P = 893
Zn = 1023
Could it be that M1 5w50 is just a thicker version of M1 0w40?
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3238790 - 01/05/14 08:58 PM Re: Mobil 5w50 SN VOA [Re: Matt_N]
dailydriver Offline
Loc: Bucks County, Pa.
Does this product have Ford's actual approval yet for the Coyote (boosted or otherwise) specs which call for a 5W-50??
IT SHOULD!! wink
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3239517 - 01/06/14 02:28 PM Re: Mobil 5w50 SN VOA [Re: A_Harman]
CATERHAM Offline
MOLY = 91
BORON = 242
CALCIUM = 3127
MAGNESIUM = 24
PHOS = 951
ZINC = 1132
Mo = 74
B = 221
Ca = 3003
Mg = 19
P = 893
Zn = 1023
As far as the add' pac' is concerned I'd say yes.
Since M1 5W-50 is the only 50 grade oil on the Porsche A40 list it would be an ideal choice to thicken up M1 0W-40 if required (based on OP/OT). I can't see the need in most applications to running the pretty heavy M1 5W-50 straight with it's HTHSV of 4.4cP.
#3261527 - 01/27/14 12:50 PM Re: Mobil 5w50 SN VOA [Re: A_Harman]
zoli Offline
Loc: Hungary
MOLY = 91
BORON = 242
CALCIUM = 3127
MAGNESIUM = 24
PHOS = 951
ZINC = 1132
Mo = 74
B = 221
Ca = 3003
Mg = 19
P = 893
Zn = 1023
This is the BEST info I have ever seen on my screen!!! Thx a lot for these!
I like a lot M1 5w50 in my flat tappet MY98 SAAB 9-5, but I have never compared it against the 0w40 has SAAB approval - and makes me valve noise at idling by fully warmed up engine. smile
'01 VOLVO S60 2t L5 A/T (Shell HU 5W40, Mann O/F, 5K OCI)
'98 SAAB 9-5 (M1 0W40 - retired)
'71 VW 1302 L (Castrol 15W40, 3K OCI - retired)
#3271123 - 02/05/14 09:31 AM Re: Mobil 5w50 SN VOA [Re: Matt_N]
LoneRanger Offline
Loc: Midwest
Nice but how might it hold up in a shared sump motorcycle with wet clutch? There's your test for sheer stability! wink
'09 Subaru Forester .........(Quaker State Syn Blend 5W30)
'16 Ducati Multistrada DVT 1200S (Spectro Platinum 15W50)
Page 1 of 3 1 2 3 >
