OVERKILL
$100 Site Donor 2021
Anybody have experience with this product?
My M5 has two washer fluid containers, a concentrated one and the regular fluid one.
We don't have a local BMW dealer, the closest is a 45 minute drive.
We do however have an MB dealer, and being German, I figured they'd probably have something similar. They have a product called SummerFit which you mix with water and then put in for summer use (as the name implies) and then they have a much larger bottle called WinterFit, which is a winter fluid concentrate, supposed to be mixed in a similar manner. Though the dealership stated that they mix with with conventional washer fluid.
Since my car has two reservoirs, I filled the "concentrate" reservoir with the WinterFit fluid and then put regular winter washer fluid in the main reservoir.
It is supposed to be good for the headlight washers from what I've read, which is good I suppose.
