Nexen Tires?
by 2015_PSD
02/11/16 08:02 AM
Wishing for shut off and cold atf level checks-
by Lapham3
02/11/16 07:01 AM
1997 Gand Marquis
by fordman65
02/11/16 03:50 AM
Better micron rating than a 40u for a 4967/14476?
by ziggy
02/11/16 02:59 AM
Weapon Shield
by Ws6
02/11/16 12:33 AM
Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
biyogo, Jandry, BlueKelah, threeeightteen, TOADchunks
56891 Registered Users
71 registered (97K15004WD, ARCOgraphite, Andrei, 440Magnum, 2015_PSD, 4 invisible), 1405 Guests and 211 Spiders online.
56891 Members
66 Forums
244535 Topics
#3208565 - 12/06/13 01:41 PM Oil mix?
Keith_Stone Offline
Loc: NC
If wanting a little "boost" to a basic synthetic oil, i.e bumping up the moly and adding a little ester to the base stock, would adding a qt. of Redline be of any benefit to the mix?
NRA Lifer
#3208570 - 12/06/13 01:45 PM Re: Oil mix? [Re: Keith_Stone]
bigjl Offline
Loc: London, England
As oils are a mix of different things i would think it would have some benefit if the oil being added is a better quality than the stuff in the sump
Wether you or the engine would notice i am not so sure.
10 BMW 116D SE 110k miles Full BMW Hx
12 Jaguar XJL 3.0 D Luxury 132k 5w30 Shell AF-L
#3208571 - 12/06/13 01:45 PM Re: Oil mix? [Re: Keith_Stone]
bepperb Offline
Loc: Milwaukee, WI
For the price of a basic synthetic oil and a quart of redline you probably could have just bought a top of the line synthetic to begin with... ie... M1 EP, Castrol 0w-30, or Pennzoil Ultra.
2004 Highlander 2.4
2011 Toyota Sienna 3.5
Recently Gone:
2006 Accord 2.4l K24A8
1993 Kawi EX 500
#3208575 - 12/06/13 01:47 PM Re: Oil mix? [Re: Keith_Stone]
Clevy Offline
Loc: Saskatoon canada
One would think that mixing oils isn't complimentary to each oils strengths however there are quite a few frankenbrew used oil analysis posted here that are stellar,so with that knowledge I doubt it will hurt anything
2006 Charger RT
Miles x 2 per oil filter
#3208624 - 12/06/13 02:18 PM Re: Oil mix? [Re: Keith_Stone]
Donald Offline
Loc: Upstate NY
Why? Buy the best oil you can easily afford and forget mixing.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3208644 - 12/06/13 02:38 PM Re: Oil mix? [Re: Keith_Stone]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
RL oils are primarily PAO based and their current reformulated street oils probably contain no more than 15% POE.
All PAO based oils contain some esters.
Adding a quart of RL to a GP III synthetic isn't going to add much ester but as you pointed out you would be likely be increasing the moly level but what you will be really increasing is the ZDDP level which is very high in RL oils.
So the primary benefit I can see in adding some RL would be to increase the ZDDP level of an OTC GP III oil if you think the engine would benefit from a higher AW level, that primarily being increased ZDDP.
BTW, my favourite RL grades are 0W-20, 0W-40 and 5W-50 for blending purposes.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
