1994 Dakota v-6, ac,ps,at, has small bulb in "glow ring" around ignition key slot. How do you get in to reach the bulb?
also" got vehicle checked at AAP, said alt and battery OK, with 90 amp Nippon Denso alt. 220k on alt, I think. Sometime I would like to replace with 120 amp. They think it will probably be an exact fit but not sure. NEW REMY 120 alts (used to be called delco remy)are now sold as "tough one" units and with coupons aren't that different $$ from Rebuilds, and tough one rebuild 120 not that much more than 90's, which aren't much more than "drive works brand", which 2 AAP stores say have a high fail rate. Comments?
