ATF as engine oil flush?
by Jabbo
Today at 04:17 AM
Delo 400 for transmissions?
by Jabbo
Today at 04:04 AM
ATF: Dexcon III?
by Jabbo
Today at 03:59 AM
List an oil Additive you'd use / No Comments
by SuperDave456
Today at 02:33 AM
Driving style doesn't change mpg?
by Nick1994
Today at 12:30 AM
Autozone 20% off + free shipping
by jmaster
Today at 12:20 AM
Beginners guide to external ATF filters?
by buck91
Yesterday at 11:27 PM
Good ADBV filter?
by asand1
Yesterday at 11:18 PM
my brigs hates synthetic
by meborder
Yesterday at 10:39 PM
Butcher factory cooler lines?
by buck91
Yesterday at 09:47 PM
Grease for marine davit crane
by davebe
Yesterday at 09:10 PM
2016 Traverse, which oil would you use?
by chevman4life
Yesterday at 09:08 PM
davebe, Logos, alphanumeric, koidragon1980, iliveonnitro
58961 Registered Users
54 registered (AirgunSavant, BobaLouie, alphanumeric, Bottom_Feeder, 1foxracing, 5 invisible), 808 Guests and 5 Spiders online.
58961 Members
66 Forums
253759 Topics
#3208439 - 12/06/13 11:42 AM 1994 DAKOTA QUESTIONS
bmwjohn Offline
Loc: indianapolis in
1994 Dakota v-6, ac,ps,at, has small bulb in "glow ring" around ignition key slot. How do you get in to reach the bulb?
also" got vehicle checked at AAP, said alt and battery OK, with 90 amp Nippon Denso alt. 220k on alt, I think. Sometime I would like to replace with 120 amp. They think it will probably be an exact fit but not sure. NEW REMY 120 alts (used to be called delco remy)are now sold as "tough one" units and with coupons aren't that different $$ from Rebuilds, and tough one rebuild 120 not that much more than 90's, which aren't much more than "drive works brand", which 2 AAP stores say have a high fail rate. Comments?
#3208489 - 12/06/13 12:23 PM Re: 1994 DAKOTA QUESTIONS [Re: bmwjohn]
Zaedock Offline
Loc: Massachusetts
I haven't purchased too many parts store alternators as I get great pricing at the boneyard my friend owns, but the AAP parts I typically get have been of decent quality. If you can get the Remy discounted though, I would go that route.
Regarding the Dakota's, I know the Jeep guys upgrade their 55/60 amp units to the 90+ units the 'Kota's came with. I'd have to search the net for more details.
2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2004 Malibu Maxx LT
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3208542 - 12/06/13 01:19 PM Re: 1994 DAKOTA QUESTIONS [Re: bmwjohn]
440Magnum Offline
Loc: Texas
I think the bigger alternator from something like a 5.2 or 5.9-powered Ram or Durango from that time period (say '93-98) with a tow package will be a bolt-in, or you might have to grind the mounting bracket a little (you do on Jeep XJs to fit the Durango alternator.) I'd search around for an alternator/starter rebuilding shop or even a junkyard alternator rather than the rebuilt crud or "new" stuff like that Remy made in China. I made the mistake of ordering a "new OEM" Jeep starter a few years ago. It arrived, I saw the 'made in China' printed on the box, and promptly slid it back across the counter and asked for my money back, then got the old one rebuilt at a starter shop.
But honestly, you don't need a 120 in that truck. 90 amps is plenty, especially since those Denso alternators are very good at giving you all that current at idle. If it were like older alternators that might be rated at 90 amps, but only give 30 at idle, then you might need an upgrade.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3212858 - 12/10/13 09:02 PM Re: 1994 DAKOTA QUESTIONS [Re: bmwjohn]
artificialist Offline
Loc: Florida
Are the higher amp alternators equipped with heavier gauge cables to handle the extra current? If they are, I would not want to install a higher amp alternator without cables that match.
2010 Lancer Ralliart Sportback
#3213060 - 12/11/13 05:39 AM Re: 1994 DAKOTA QUESTIONS [Re: bmwjohn]
eljefino Offline
Loc: ME
You could keep the stock cable but rewire the headlights with a relay off the alt lug. That would take some of the current and result in brighter lights.
#3213249 - 12/11/13 09:40 AM Re: 1994 DAKOTA QUESTIONS [Re: bmwjohn]
Oldmoparguy1 Online   content
Loc: Charlotte, NC
Here you go.
From Rockauto.com
1994 DODGE DAKOTA 3.9L V6 OHV : Electrical : Alternator / Generator
REMY Part # 94604 New; Remy Gold
w/ 137mm (5 3/8") dia Alternator Case; 120 Amps. $116.79
1994 DODGE GRAND CARAVAN 3.3L V6 OHV : Electrical : Alternator / Generator
w/ 137mm (5 3/8") dia Alternator Case; 120 Amps; Can Use, Requires Reuse Of Original Pulley. $116.79
You won't need heaver wiring, it's already rated for the 120 amp unit.
Same exact part, same price....
Use my discount code:187525125834338 5% good til 1/26/2014
BTW: my local re-builder can't get parts to rebuild them. I have a perfectly good one that just needs a new brush.
Good luck,
Wayne
What has happened to polite conservation? Refrain from pointless posts. Try not to criticize others for silly mistakes.
