My car audio build thread
by dan_erickson
4 minutes 24 seconds ago
Pegasus PS737 Cut Open. Unknown Mileage / Oil
by Farmer
27 minutes 22 seconds ago
Napa Gold 1372, 4.5 Months, 8500KM.
by Farmer
34 minutes 9 seconds ago
lubriplate 1200-2
by buffalobob
Today at 02:49 AM
How do you politely say no to people?
by motor_oil_madman
Today at 12:39 AM
To change or not?
by ram_man
Yesterday at 11:55 PM
Nozzle Flow Versus Pressure/Viscosity
by Shannow
Yesterday at 11:20 PM
Camaro "How its Made" TV show Observations
by SumpChump
Yesterday at 11:08 PM
Wondering if sitting with few quick starts degrad
by corndogzombie
Yesterday at 10:51 PM
whole hog cook w/ pics
by 04SE
Yesterday at 10:12 PM
redo a/c in 1994 dakota 2wd
by bmwjohn
Yesterday at 09:37 PM
How to post UOA's on here?
by motor_oil_madman
Yesterday at 09:34 PM
jractk, LatitudeDancer, AKN, NickGB, Marcusd1979
58645 Registered Users
40 registered (B320i, billt460, BigCahuna, 1foxracing, 2010Civic, 6 invisible), 1020 Guests and 11 Spiders online.
58645 Members
66 Forums
252432 Topics
Page 3 of 3 < 1 2 3
#3206818 - 12/05/13 12:12 AM Re: Good oil for lightly driven '09 Passat? [Re: edyvw]
bigjl Offline
Loc: London, England
Originally Posted By: edyvw
Yeah I just saw I put A4.
Anyway, VW503.00, 506.00, 506.01, are long drain for PD engines.
Interestingly enough, same engines require VW 505.01! VW 506.00 and VW503.00 were used in ONLY best conditions possible. Any harder conditions required VW 505.01 (more sulfur in diesel fuel, dusty roads etc).
I know because I still own car in Europe with PD diesel engine. Those oils were used to improve gas mileage, but ONLY under certain conditions, which tells a lot. Still, I have not seen anyone using that oil in PD engines!
I would say you need more info on this matter!
Why would you want to use a low HTHS oil in a pd engine?
If you don't use a specific PD oil it will eat the cam.
I think you may need to look into why low HTHS oils were introduced, sulphur level in fuel wasn't a big issue when the Zetec engine came out in the mk1 Mondeo back in '92 and using the wrong oil caused valves to get sticky and caused misfires.
Not sure of the relevance of still owning a car in Europe though.
Europe is a big place with difference fuel specifications
I certainly wouldn't use the same oil and OCI if I lived and drove in say Spain or Portugal as I do in the UK
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#3206829 - 12/05/13 12:34 AM Re: Good oil for lightly driven '09 Passat? [Re: bigjl]
edyvw Offline
Loc: Colorado Springs
No, you misunderstood me. VW503.00 was used in first VW PD engines (1.9 101ps, 115ps) as long drain. later VW 506.00 and .01 were used in some engines, but in very few applications, and VW went back to HTHS 3.5 and above on all engines.
I said I own this engine still just to say I do have experience with this application.
However, I yet to see someone to use in PD engine oil that has HTHS less then 3.5cst.
My opinion is that VW played a little bit with these energy saving oils, and just abandoned it.
13' BMW X5 35d (Valvoline 5W40 MST+ OEM filter)
11' VW Tiguan 2.0T (Castrol 0W40+OEM filter)
#3206848 - 12/05/13 01:16 AM Re: Good oil for lightly driven '09 Passat? [Re: bigjl]
Garak Offline
Loc: Regina, Saskatchewan, Canada
By A5 I assume you mean A5/B5 as I have never seen an oil just meet the petrol standard
You may read that quirk from some of us in North America. Some synthetic oils here claim the A5 and ignore the B5, for whatever reason, in print on their sheets or the bottles. They're generally ILSAC rated oils anyhow, and see the insides of few if any diesels. wink Oddly enough, one of the Korean manufacturers has been listing A5 in their manuals, without the B5. I don't know if such wording is seen anywhere in Europe.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3207015 - 12/05/13 08:30 AM Re: Good oil for lightly driven '09 Passat? [Re: Garak]
bigjl Offline
I have seen mention of just one standard in the owners manual of my TX4 Taxi in that case it mentioned B4, B5 I seem to remember
It might be simply because diesels are still relatively uncommon in the US?
I have read about people using diesel spec oil in a petrol engine as they are considered more robust
I always thought the oil companies saw this and made oils that matched both specs as it was cheaper
#3207149 - 12/05/13 10:39 AM Re: Good oil for lightly driven '09 Passat? [Re: bigjl]
UG_Passat Offline
Loc: NJ
If you do use a PD specific oil, it will still eat the cam.
many of the PD owners here use a Heavy Duty Diesel Oil instead.
#3207160 - 12/05/13 10:50 AM Re: Good oil for lightly driven '09 Passat? [Re: UG_Passat]
edyvw Offline
I had several PD cars, always used Shell Helix, OMV or Castrol 505.01 5W40. Two of those engines hit 230,000 miles before they were sold. Current one is hitting 90,000, no issues also.
My cousin had Passat 1.9 130ps (which I think is best PD engine ever made) and sold it with 260,000 miles. Never single issue on engine.
#3207400 - 12/05/13 02:25 PM Re: Good oil for lightly driven '09 Passat? [Re: edyvw]
bigjl Offline
I already said that Volvo uses A5/B5 (same as in Eastern Europe), some Ford's, very few Opel's (which interestingly in Europe in 2.0T uses 5W40 A3, while in the U.S. uses A5, probably because of application).
Those VW specs that UG_Passat is mentioning are used in very, very good conditions. However, I did not see them using in PD engines even in Germany, because of well know reason.
What you said that few companies are sticking to W40, my point was not in SAE grades, but in HTHS and cst.
Most of European companies require ACEA A3/B3 with HTHS of minimum 3.5cst. Those could be heavy W30 oils or pretty much any W40.
You seemed to have missed my point.
All Fords use A5/B5 except the Ford Ka and Focus RS
That isn't some. Same for Volvo. Though since the involvement of Ford and platfrom sharing it may be all Volvos apart from maybe the original D5 engine. The new 2.0 is now 5 cylinder confusingly.
#3207479 - 12/05/13 03:24 PM Re: Good oil for lightly driven '09 Passat? [Re: bigjl]
Garak Offline
Yes, at least ones calling for a B spec or something derived from that. Aside from VW/Audi and Mercedes diesels, most call for CJ-4 or previous. That's usually combined with a spec like SM, too, for mixed fleet use. But, you just don't see the general trend of interchangeable use between gassers and diesels like you'd see with European specifications.
For example, GC and M1 0w-40 are first choices that meet the exact specifications of several European gassers and diesels. With North America, the difficulty arrives in that if it's a diesel, it'll call for a heavy CJ-4 HDEO (10w-30 or heavier with HTHS of 3.5 or more) versus the gasoline vehicle calling for an ILSAC rated oil, which is basically a spark only lubricant. Finding a newer gas vehicle here calling for a CJ-4/SM 5w-40 would be just about impossible.
#3207577 - 12/05/13 04:46 PM Re: Good oil for lightly driven '09 Passat? [Re: bigjl]
edyvw Offline
No I believe you. Since Volvo started to cooperate with Ford, I gave up on them, and stop following what they doing. 960's and 850's are last Volvo's I consider as true Volvo.
I also never been big fan of Ford, although I do have in household in Europe Jaguar S-Type 3.0 V6.
Page 3 of 3 < 1 2 3
