microGreen Memorial Day Sale
by DBMaster
05/25/16 03:18 PM
Biomed Tech internship - Osceola, FL
by Mr Nice
05/25/16 03:06 PM
New Car - First OCI Subaru Outback
by Oldswagon
05/25/16 02:43 PM
using many cans of crc intake cleaner good?
by ziggy
05/25/16 02:37 PM
Mazda's RX Vision with rotary engine won't happen
by HTSS_TR
05/25/16 01:45 PM
Oil shearing vs fuel dilution
by Popsy
05/25/16 01:31 PM
Told SiriusXM to Pound Sand
by Garak
05/25/16 01:22 PM
CB install '98 F250ld
by asand1
05/25/16 12:53 PM
Kohler K532 Engine John Deere 400
by Bighorn2500
05/25/16 12:41 PM
Champion C165 cut open, 9000km
by turboseize
05/25/16 12:30 PM
F1 - 2016 Monaco Grand Prix
by gofast182
05/25/16 11:39 AM
Mazda 3 drain and fill
by jay929
05/25/16 11:38 AM
Hokie_Dave, ant3a, afterburnerbg, SupraSaiyan, Bighorn2500
57973 Registered Users
84 registered (2010Civic, another Todd, 2009Edge, 97f150, asand1, 9 invisible), 1991 Guests and 351 Spiders online.
57973 Members
66 Forums
249394 Topics
Page 1 of 2 1 2 >
#3202662 - 12/01/13 07:59 AM delo 400 for race use?
ericsiewkk Offline
Loc: Malaysia
greeting guys, this is my first post. been lurking in forums for sometimes.
i have a new cam ground for a honda D16 1.6L motor with aggressive ramp rate. the cam company call for rotella T but it is not sold in the country. only available is shell rimula 3x which i am not sure if it is the same.
however i can get delo 400 15w-40 and delo silver 20w-50 for decent price. does this oil give enough high rpm protection to the main/rod bearings?
delo silver 20w-50 vs the delo 400 which is better? i live in tropical country so 20w is not a concern here.
#3202696 - 12/01/13 09:02 AM Re: delo 400 for race use? [Re: ericsiewkk]
GutsyGecko Offline
Loc: Youngstown, OH
Is it possible to get synthetic 5w-40 diesel anything? Or even valvoline vr1 racing oil? The valvoline is a 20w-50 that would suit your needs.
#3202857 - 12/01/13 12:25 PM Re: delo 400 for race use? [Re: ericsiewkk]
cronk Offline
Loc: Watertown, New York
I don't know if its the same oil in your country, but here it is an excellent oil.
Over 1400 ppm zinc, about the highest I have seen in anything but race oil.
Check out this
http://www.pqiamerica.com/March2013PCMO/HDEO%20SUMMARY.html
1998 GMC C1500
1999 Saturn SL2
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
#3202881 - 12/01/13 12:50 PM Re: delo 400 for race use? [Re: ericsiewkk]
SteveSRT8 Offline
Loc: Sunny Florida
I have been around a spell and no one who ran big trucks can say bad stuff about Delo! That is some fine oil...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3203375 - 12/01/13 09:29 PM Re: delo 400 for race use? [Re: ericsiewkk]
ericsiewkk Offline
Loc: Malaysia
i understand it offer high film strength from the zddp. since it is a diesel oil i am a bit worried about the high rpm protection to the main and rod bearings. this engine will be running on 28-30psi rev to 9krpm making close to 450whp so the bottom end see lots of stress.
#3203379 - 12/01/13 09:37 PM Re: delo 400 for race use? [Re: ericsiewkk]
ericsiewkk Offline
Loc: Malaysia
motor used to run on the black colored liqui moly MoS2 15w-40 before the aggressive cam install.
rod/main bearings look great after 2 years of race and street use.
#3203416 - 12/01/13 10:05 PM Re: delo 400 for race use? [Re: ericsiewkk]
Clevy Offline
Loc: Saskatoon canada
I think the liqui-moly oil you are referring to was a 10w-40.
As far as present choice is concerned and your concern about rpm lets consider that a 0w-40,a 5w-40,a 10w-40 and a 15w-40 are all 40 grades when the oil is at operating temp.
So considering that the last oil used was a 40 grade when hot,and there was a recommendation of using rotella t 15w-40 is a 40 grade when hot you should be fine using any oil with the second value on the bottle being 40.
I suspect the 40 grade recommendation is due to oil temps getting pretty high when spinning at 9000rpm however I'd look at a 30 grade hdeo.
Less parasitic loss and you may get that little bit more "oomph" up top if the oil doesn't require as much power to pump.
And today's 30 grade hdeo's are proving to be very capable and not showing any elevation in wear.
I'd try a 30 grade hdeo personality.
2006 Charger RT
Miles x 2 per oil filter
#3203483 - 12/01/13 11:49 PM Re: delo 400 for race use? [Re: ericsiewkk]
rrounds Offline
Loc: SACRAMENTO, CA
I'll take your 9000 rpm and raise it to 15500 rpm in my Yamaha R6.
It(Delo 15/40) will do the rpm's just fine.
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
#3203496 - 12/02/13 12:13 AM Re: delo 400 for race use? [Re: rrounds]
ericsiewkk Offline
Loc: Malaysia
thanks man! you give me the confident in the delo 400.
#3204077 - 12/02/13 03:44 PM Re: delo 400 for race use? [Re: ericsiewkk]
KenO Offline
Loc: Auburn, GA
Whats the deal with people all of a sudden saying the diesels oils don't work well in high revving engines lately? We run T6 in nearly all of the local tracked NA & turbo'd BMW's making in excess of 500 whp and I've NEVER seena n oil related failure on these engines.
It's starting to sound like AVSForums, where people just make stuff up to make themselves feel better, and to scare other people into thinking how they think.
Edited by KenO (12/02/13 03:46 PM)
1995 Volvo 960 ShagginWagon
1995 BMW 328ti
1997 Chevy C2500 5.7l V8
1998 BMW 528i
#3204370 - 12/02/13 08:47 PM Re: delo 400 for race use? [Re: ericsiewkk]
vssjim Offline
Loc: McLean, Va.
We have used Delo 400 15-40 in our sprint car engines for many years, both dry and wet sump applications.Flat tappet cams and rollers and no trouble at all.
#3204381 - 12/02/13 08:55 PM Re: delo 400 for race use? [Re: vssjim]
KenO Offline
Loc: Auburn, GA
Joe Gibbs people told an automotive engineer friend of mine at the PRI show that before they developed their oils - they broke everything in on Rotella dino. IDK where this 'HDEO is not for performance cars' myth came about all of a sudden, but it needs to disappear.
1995 BMW 328ti
1998 BMW 528i
#3204474 - 12/02/13 10:28 PM Re: delo 400 for race use? [Re: KenO]
OVERKILL Online   content
Loc: Ontario, Canada
Agreed. Engine builder I know used to use Kendall 15w-40 in his circle and oval track SBC builds and it held up very well. It was what he recommended the guys run in them and it worked. HDEO's are generally extremely robust and handle that kind of abuse very well. thumbsup
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3204487 - 12/02/13 10:41 PM Re: delo 400 for race use? [Re: KenO]
Garak Offline
Loc: Regina, Saskatchewan, Canada
I know, it is kind of silly. For guys wanting higher ZDDP, 10w-40 or 20w-50 is no guarantee. So, you have boutiques, VR-1, or HDEOs. And there's nothing wrong with HDEOs. Heck, Mobil specifically recommends Delvac 1 ESP 5w-40 for "high performance gasoline applications."
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3204599 - 12/03/13 06:00 AM Re: delo 400 for race use? [Re: ericsiewkk]
bullwinkle Online   confused
Loc: Cincinnati, OH, USA
If HDEO can stand up to the 22.5-1 compression ratio of my IDIs, it can handle hi-perf gas motors!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
Page 1 of 2 1 2 >
