Subaru V-twin engines
by oil pan 4
06/01/16 12:25 AM
Napa June 2016 sale 6/1-6/30
by slacktide_bitog
05/31/16 11:42 PM
Castrol SAF Carbon Modified SAE 75W/85
by ABomb369
05/31/16 10:44 PM
any harm done to Ranger?
by mobilaltima
05/31/16 10:17 PM
Obsolete Freeway on ramps
by jimbrewer
05/31/16 10:14 PM
Ideal-Tridon Hose Clamp Display
by Merkava_4
05/31/16 08:52 PM
Want to hear from turbo owners that go 10k + oci
by Sw296inchblue
05/31/16 08:31 PM
When you have found the right combo
by bbhero
05/31/16 08:25 PM
High Mileage diesel oil?
by Hysilver
05/31/16 08:23 PM
Barium
by Hullthumper
05/31/16 07:25 PM
Oil filters suggestions for a 10' Hyundai .......
by Oregoonian
05/31/16 06:32 PM
Is the spin-on filter's days numbered?
by jongies3
05/31/16 06:28 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
40 registered (bvance554, bbhero, bdcardinal, ABomb369, 3 invisible), 849 Guests and 145 Spiders online.
58031 Members
66 Forums
249650 Topics
#3202763 - 12/01/13 10:43 AM 98 Malibu 3.1 o2 sensor relocated
Fitter30 Offline
Loc: Peace valley, Missouri
After soaking the o2 sensor in kroil oil for three days , it's nots coming out. Wanting to weld a bung on the exhaust pipe before the the cat and relocate the sensor . Any thoughts on this would be helpful.
#3202767 - 12/01/13 10:46 AM Re: 98 Malibu 3.1 o2 sensor relocated [Re: Fitter30]
eljefino Offline
Loc: ME
Are you talking about the rear o2 sensor? It has to stay where it is.
Kroil isn't going to help you. Heat and a cheater pipe might. Some combination of running the car to heat up the pipe but not the sensor...
#3202843 - 12/01/13 12:04 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: eljefino]
yonyon Offline
Loc: NJ, USA
On a Honda it might. What is the car?
#3202863 - 12/01/13 12:38 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: yonyon]
earlyre Offline
Loc: Lima, Ohio, USA
look @ the thread title, 98 malibu 3.1
Mine:
09 Mercury Sable : 6qts QSAD 5w20,WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts QSAD 5w30,WIX 51394
#3202992 - 12/01/13 02:47 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: Fitter30]
The_Eric Offline
Loc: Iowa
Can you get it to turn at all? Usually if they turn really hard after they're broken loose, then you're doomed to damaged threads. If you simply can't budge it, then there may be hope. Many times, if you can crack them loose, they'll spin out by hand.
Which sensor is it?
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#3203153 - 12/01/13 05:10 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: The_Eric]
Fitter30 Offline
It's the first sensor the one in the cast exhaust manifold , I didn't want to cut the wires , the car is still running and if the sensor has striped threads I'm afraid the engine would have to be pulled to replace the manifold
#3203203 - 12/01/13 06:09 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: Fitter30]
The_Eric Offline
Loc: Iowa
You may have to bite the bullet and nip the wire to get on the o2. Usually the threads in the fitting are not damaged, just the o2 itself. Many times the threads from the o2 will stay in the threads of the exhaust and you will need run a tap down through it get rid of them.
