Avoiding short trips like the plague
by FordCapriDriver
06/25/16 03:11 AM
API CK-4
by JustPlainFolks
06/25/16 02:37 AM
Rotella T
by momo
06/25/16 01:51 AM
3,000 mile OCI/severe service/newspaper delivery?
by Aurora09
06/24/16 11:46 PM
move over esters...time for alkylated napthenes
by Shannow
06/24/16 10:46 PM
ear wax and ear plugs
by motor_oil_madman
06/24/16 09:26 PM
Discount Tire Direct 4th of July Sale
by sopususer
06/24/16 08:37 PM
What kind of oil drain plug gasket is this?
by Chris B.
06/24/16 07:36 PM
by Chris B.
06/24/16 07:34 PM
First time changing oil what to use ?
by sshazam
06/24/16 07:13 PM
toshiba 720p 28" TV hdmi to thinkpad vga cable?
by bmwjohn
06/24/16 06:48 PM
1988 Brougham
by momo
06/24/16 06:38 PM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
18 registered (bbhero, 285south, asand1, ChristianReske, 2 invisible), 527 Guests and 13 Spiders online.
58257 Members
66 Forums
250769 Topics
#3202763 - 12/01/13 10:43 AM 98 Malibu 3.1 o2 sensor relocated
Fitter30 Offline
Loc: Peace valley, Missouri
After soaking the o2 sensor in kroil oil for three days , it's nots coming out. Wanting to weld a bung on the exhaust pipe before the the cat and relocate the sensor . Any thoughts on this would be helpful.
#3202767 - 12/01/13 10:46 AM Re: 98 Malibu 3.1 o2 sensor relocated [Re: Fitter30]
eljefino Offline
Loc: ME
Are you talking about the rear o2 sensor? It has to stay where it is.
Kroil isn't going to help you. Heat and a cheater pipe might. Some combination of running the car to heat up the pipe but not the sensor...
#3202843 - 12/01/13 12:04 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: eljefino]
yonyon Offline
Loc: NJ, USA
On a Honda it might. What is the car?
#3202863 - 12/01/13 12:38 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: yonyon]
earlyre Offline
Loc: Lima, Ohio, USA
look @ the thread title, 98 malibu 3.1
Mine:
09 Mercury Sable : 6qts QSAD 5w20,WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts QSAD 5w30,WIX 51394
#3202992 - 12/01/13 02:47 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: Fitter30]
The_Eric Offline
Loc: Iowa
Can you get it to turn at all? Usually if they turn really hard after they're broken loose, then you're doomed to damaged threads. If you simply can't budge it, then there may be hope. Many times, if you can crack them loose, they'll spin out by hand.
Which sensor is it?
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#3203153 - 12/01/13 05:10 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: The_Eric]
Fitter30 Offline
It's the first sensor the one in the cast exhaust manifold , I didn't want to cut the wires , the car is still running and if the sensor has striped threads I'm afraid the engine would have to be pulled to replace the manifold
#3203203 - 12/01/13 06:09 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: Fitter30]
The_Eric Offline
Loc: Iowa
You may have to bite the bullet and nip the wire to get on the o2. Usually the threads in the fitting are not damaged, just the o2 itself. Many times the threads from the o2 will stay in the threads of the exhaust and you will need run a tap down through it get rid of them.
