What happened to Anco wiper blades
by grampi
05/27/16 07:21 AM
Full brand oil filter
by RRLJR
05/27/16 05:31 AM
Half Price GTX 15W-40 @ REPCO in Oz
by SR5
05/27/16 03:27 AM
1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
85 registered (alarmguy, Astro14, 901Memphis, 69GTX, AirgunSavant, anthonym6, 6 invisible), 1605 Guests and 311 Spiders online.
57996 Members
66 Forums
249472 Topics
#3202763 - 12/01/13 10:43 AM 98 Malibu 3.1 o2 sensor relocated
Fitter30 Offline
Loc: Peace valley, Missouri
After soaking the o2 sensor in kroil oil for three days , it's nots coming out. Wanting to weld a bung on the exhaust pipe before the the cat and relocate the sensor . Any thoughts on this would be helpful.
#3202767 - 12/01/13 10:46 AM Re: 98 Malibu 3.1 o2 sensor relocated [Re: Fitter30]
eljefino Offline
Loc: ME
Are you talking about the rear o2 sensor? It has to stay where it is.
Kroil isn't going to help you. Heat and a cheater pipe might. Some combination of running the car to heat up the pipe but not the sensor...
#3202843 - 12/01/13 12:04 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: eljefino]
yonyon Offline
Loc: NJ, USA
On a Honda it might. What is the car?
#3202863 - 12/01/13 12:38 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: yonyon]
earlyre Offline
Loc: Lima, Ohio, USA
look @ the thread title, 98 malibu 3.1
Mine:
09 Mercury Sable : 6qts QSAD 5w20,WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts QSAD 5w30,WIX 51394
#3202992 - 12/01/13 02:47 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: Fitter30]
The_Eric Offline
Loc: Iowa
Can you get it to turn at all? Usually if they turn really hard after they're broken loose, then you're doomed to damaged threads. If you simply can't budge it, then there may be hope. Many times, if you can crack them loose, they'll spin out by hand.
Which sensor is it?
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#3203153 - 12/01/13 05:10 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: The_Eric]
Fitter30 Offline
It's the first sensor the one in the cast exhaust manifold , I didn't want to cut the wires , the car is still running and if the sensor has striped threads I'm afraid the engine would have to be pulled to replace the manifold
#3203203 - 12/01/13 06:09 PM Re: 98 Malibu 3.1 o2 sensor relocated [Re: Fitter30]
The_Eric Offline
Loc: Iowa
You may have to bite the bullet and nip the wire to get on the o2. Usually the threads in the fitting are not damaged, just the o2 itself. Many times the threads from the o2 will stay in the threads of the exhaust and you will need run a tap down through it get rid of them.
