- Joined
- Dec 30, 2006
- Messages
- 29,558
2007 4.0 V6 Mustang. I replaced the cracked leaking thermostat housing. Went back together perfectly. After a few days I noticed a tiny leak/seepage around the base of the coolant temp sensor which is attached to the upper cover of the thermostat housing. I reinstalled the sensor exactly the way it came out. It simply sits inside the hole,held in by a metal clip. Did I perhaps miss something? I don`t recall seeing any kind`ve gasket when I removed it,and the schematic of the cooling system for this car doesn`t show a gasket either. Here`s a pic. That gray plug with the wire attached is the sensor. It`s leaking from underneath the bronze nut at the bottom of it. The sensor is not threaded,therefore doesn`t screw into the housing,it just sits inside the hole held in by the small metal clip.
