Brake fluid for '11 Buick Regal
by Benzadmiral
03/30/15 09:13 AM
Rounded bolt removal
by dlundblad
03/30/15 09:05 AM
53 inch RC helicopter.
by OtisBlkR1
03/30/15 08:06 AM
Honda Recommended Greases and Lubricants list
by ledslinger
03/30/15 07:58 AM
Stand by..................
by CourierDriver
03/30/15 07:20 AM
opinions on OBD lock device?
by ioci
03/30/15 06:45 AM
Milwaukee Twins Motorcycle Oil
by rccsofla
03/30/15 05:33 AM
Honda Pro Moly 60 Paste has been replaced
by ledslinger
03/30/15 04:18 AM
oil spec data
by SLATRON
03/30/15 01:37 AM
Honda 22 Year Old Lead Engineer !
by HTSS_TR
03/30/15 12:42 AM
full fluid replace + Lubegard. Results timeframe?
by henrys_dad
03/29/15 11:24 PM
My phone don't notice my sim card no mo'
by daves66nova
03/29/15 11:10 PM
fly4food84, 91er, Bear49, Dougsts, Gokatta
53365 Registered Users
90 registered (2002 Maxima SE, ABomb369, -SyN-, 55Test, andx0r, 01_celica_gt, 7 invisible), 1597 Guests and 165 Spiders online.
53365 Members
66 Forums
228902 Topics
Page 1 of 2 1 2 >
#3200963 - 11/29/13 03:53 AM Victory 20w-40, 4508 miles in a Cross Country Tour
Robster Offline
Loc: Central Pennsylvania
I've gotta say, this oil did better than I expected, and the wear metals were nominal considering the engine was still wearing in. The oil sheared, but with the miles on this OCI, it still wasn't that bad. I think I'll be sticking with the Victory oil for now.
Do you guys think a full syn would give better results?--doubtful in my opinion.
[img:center]https://dl.dropboxusercontent.com/u/14231719/13_VICTORY_XCT-110813_oil_analysis--Redacted.pdf[/img]
2014 Hyundai Santa Fe Sport 2.0T: Pennzoil Platinum w/PP 5w-30, & OEM filter
2013 Victory Cross Country Tour: Victory 20w-40, OEM filter
#3200998 - 11/29/13 07:05 AM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
tc1446 Offline
Loc: NC
Rob, Is the Victory oil a blend? Whatever it is, with that good of a report, I'd stick with it. A syn "might" provide you a longer OCI but that certainly isn't needed in your case.
If its a blend, it might be this one packaged for Victory:
http://www.powersportsuperstore.com/Castrol-20W40-Synthetic-Blend-1qt-06394-p/4599614.htm
I've been testing some of this brand in my Can Am, a 50-50 mix of 10-40 and 20-50. Was tempted to order the 20-40 but didn't.
Edited by tc1446 (11/29/13 07:17 AM)
'13 Accord EX-L
'00 Ford Ranger {46K}
'14 Can Am SE6 (13K)
#3201022 - 11/29/13 07:38 AM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
Robster Offline
tc1446. . .yeah. . .it's a syn-blend--the only oil offered by Victory for it's bikes. I'm not interested in extended OCIs--I just want the oil to last 5000 miles and give decent performance and it looks like it'll do that with no problem. The price for the oil change kit from my dealer is about $60 including an OEM filter, crush washer (and 4.5 quarts of oil)--not too bad for a motorcycle-specific oil in my opinion.
The Castrol oil you linked to is NOT used by Victory. Lubetech makes the Victory oil: http://www.lubetech.com/
Edited by Robster (11/29/13 07:41 AM)
#3201056 - 11/29/13 08:49 AM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
LoneRanger Offline
Loc: Midwest
That oil kicked butt, I would stick with it for sure. Dang, a syn blend yet it smokes the Amsoil 10W40 I had analyzed after a similar mileage run.
Do they offer the 20W40 in a full syn as well?
'09 Subaru Forester .. (Kendall GT-1 Syn Blend 5W30)
'13 Ducati MTS .......... (Silkolene Pro 4 Ester 15W50)
#3201060 - 11/29/13 08:51 AM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: LoneRanger]
Pablo Offline
Loc: Duvall WA - Pacific NW USA
I thought you had a Ducati?
This bike looks like it's easy on oil. Links to other UOA's on the same engine would be cool.
#3201897 - 11/30/13 08:56 AM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
LoneRanger Offline
Loc: Midwest
I do, however I'm afraid the results of the analysis I had done made a bad first impression... and we know what they say about first impressions. To have had such high hopes as a first time user only to see the lab mark viscosity as almost two clicks out of grade (while showing fuel as trace) cast a shadow over it for me.
#3201921 - 11/30/13 09:23 AM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
Robster Offline
Is it easy on oil or is the oil just better? Conventional wisdom around this forum is that my bike should be harsh on oil:
--It's an air / oil -cooled v-twin
--It has a shared sump design (should chew up the oil more)
--It has a geared primary drive (should chew up the oil more)
--It has a 4.5 quart sump capacity (not huge considering it's for engine and transmission).
Pablo, have you seen any UOAs on Vics using recent Amsoil formulations? Were the results similar? I've used Amsoil in past bikes and I always thought they ran good with it, but I never had any UOAs done. I'd consider running a OCI of Amsoil for sake of comparison at some point.
#3202002 - 11/30/13 10:34 AM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
Pablo Offline
A single UOA can be brutal. Especially on a new bike. But when Blackstone picks up a trace, you do have fuel in your oil. My God man, the flash point was 370F as I recall. Probably should read the comments on your UOA again, but my main point is, totally different engines. A comparison CAN be made however and I'll get to that below.
Agree on the general factors. That said this bike does seem to be easy on the oil given the total lack of break in material, or it's just a well made engine. How many years have we been at this? No oil stops break in material, and this one seems low. That's the only thing we can compare to the Ducati, with it's relatively high break in material.
I have said nothing at all against this oil (have I?) I didn't even bring up Amsoil, actually. Kinda why I post less on BITOG anymore and only really post when Amsoil has already been brought up.
I have never seen a UOA of this oil before, and haven't seen an Amsoil UOA on the Victory 1731cc engine. What is the starting vis of this Victory 20W-40? Data sheet?
#3202051 - 11/30/13 11:35 AM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
Robster Offline
Hey Pablo. . . It seems like you may have taken my comments the wrong way:
"I have said nothing at all against this oil (have I?) I didn't even bring up Amsoil, actually. Kinda why I post less on BITOG anymore and only really post when Amsoil has already been brought up."
I appreciate your comments, as you clearly have a lot of experience in the consumer oil biz--no disrespect intended. When I said the Vic oil was "better", I meant it in reference to no specific brand. I do think that semi-syn oils can fare better in air-cooled engines than pure syn, but it's just a hunch with no scientific support.
--Rob
#3202122 - 11/30/13 01:07 PM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
LoneRanger Offline
Loc: Midwest
And all I'm saying is that Amsoil didn't impress in my Ducati. I could go into more detail but I don't want to thread hijack.
#3202211 - 11/30/13 03:00 PM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: LoneRanger]
Pablo Offline
--Rob
Just trying to keep it apples to apples. One oil got "smoked" in another application isn't exactly relevant, or scientific especially when we get down to the details. A quick 370 vs 410F FP comparison shows very little fuel here.
I've certainly heard people say that certain conventional or blend oils are "better" with little objective evidence. And I will also continue to point out single point UOA's are just a beginning guide about engine health, not for oil selection.
#3205819 - 12/04/13 09:13 AM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: LoneRanger]
Robster Offline
Pablo. . .I haven't been able to find specs for the Victory oil (no surprise there). . .similar to H-D's policy of non-disclosure.
@LoneRanger. . . it would be interesting if you tried some Victory oil in the Ducati and re-tested.
#3206427 - 12/04/13 05:59 PM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
LoneRanger Offline
Loc: Midwest
I've gone back to Mobil 1 10W40 (4T) for now. Going to find out Blackstone's universal avg mileage for it and sample it at that mileage.
#3206444 - 12/04/13 06:16 PM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
Robster Offline
@LoneRanger. . . I looked at your Ducati test results. . .I don't think it's very abnormal, considering the fuel dilution and the break-in that's likely been going on. I've owned bikes in the past that consistently showed fuel dilution. . .some do, some don't. Are you running a stock fuel setup or have you added mods? I know next-to-nothing about Ducatis, but I have a friend that has one and he LOVES it--seems well-made.
#3206761 - 12/04/13 10:31 PM Re: Victory 20w-40, 4508 miles in a Cross Country Tour [Re: Robster]
LoneRanger Offline
Loc: Midwest
It's stock. It can't be fuel dilution. The sequence was thus that day: Ride just over 100 miles on highway to dealer, between 90 minutes to hour. Idle in a construction zone maybe 5 minutes. Another few minutes riding urban speed to dealership, pull up to overhead doors at dealer, shut down, rolled inside, up onto the workstand. Made factory rated mpg all the way there (@ 42mpg). Any fuel should have been removed from the oil by the trip. I think the Amsoil just sheared.
Page 1 of 2 1 2 >
