If you want an ogee, then you need a router. (There is another way but won't go into that here as it requires a specialized tool...).
With that decided and you plan on using pine, oak or chestnut, you'll need to choose an ogee profile and it'll probably come on an 1/2" shank, so a router with a 1/4" only collet won't work.
Regarding name-brand routers vs. HF-junk, the former will be much better made, have quality sealed bearings and be well-balanced & precision machined. Remember the shaft spins around 23,000 rpm with significant torque, while you're holding on to the body. A bit hairy when you're a beginner, but you'll get used to it. The tool demands respect!
IF you don't want to buy, you may be able to rent one for a few hours from a local HD...but you'll still have to buy the bit.
Sounds like your Grandfather lives too far away to borrow his, correct?
Another option is to inquire at a local Woodcraft or Rockler woodworking store and see if someone there will do it for some cash. You could also contact a local woodworkers club and ask them for assistance.
Thanksgiving is two days away though....also, don't forget your earplugs!
