Originally Posted By: gregk24
I wish I understood it all, if they are all 2.6 2.7ish then they should perform almost identical in my eyes. But again I dont fully understand.
The ht/hs only gives you a single value and if that was the only important variable then you'd be looking for a mono grade lubricant.
Ht /hs is sorta like the viscosity at operating temp. So let's compare 2 oils.
German castrol and M1 0w-40
Now the German castrol so a 0w-30. Since we know euro spec oils need an ht/hs of 3.5 by your train of thought these oils should be the same,yet they are graded differently.
Now if you look a the kv-40 and kv-100 on both you'd see that the 0w-40 is slightly thicker which is defined by the higher kv value.
So now we need more values in order to measure viscosity in -30 weather.
Now we see that even though the GC is a 0w-30,and has a smaller viscosity spread the GC is actually thicker in sub-zero temps,yet once its exposed to heat its thinner than the 0w-40.
Knowing these values can help a consumer because in the brutal cold we experience where I live if I just looked at GC and the 0w-30 I would assume its thinner at start up than the 0w-40 from M1 based on what little most consumers know about oil.
Yes both oils meet for example a BMW spec however based on the fact the the 0w-40 is thinner when exposed to brutal cold than GC I feel its a better choice while operating under those ambient temps.
Now as the temps increase the GC is thicker at temps similar to spring and summer however at operating temp the GC is thinner than the M1,however based on the spread one can assume again that GC is more shear resistant which isn't always the case.
So yes I feel your pain. Be thankful for bitog.
