businesses charging extra sales tax?
by motor_oil_madman
02/11/16 10:51 AM
Why do many WEST states have MAX of 91 Octane?
by tempnexus
02/11/16 10:47 AM
CERATEC in a newishing eninge (7k miles)?
by tempnexus
02/11/16 10:42 AM
Penzoil synthetic 5w 30 in my 06 4.6 Mustang
by gmh101357
02/11/16 10:26 AM
recomendations for sub $10k used hatch?
by earlyre
02/11/16 10:26 AM
How to handle dangerously bad work by a shop
by Mykl
02/11/16 10:13 AM
Is ATF an oil?
by skaughtz
02/11/16 09:59 AM
Nexen Tires?
by 2015_PSD
02/11/16 08:02 AM
Wishing for shut off and cold atf level checks-
by Lapham3
02/11/16 07:01 AM
1997 Gand Marquis
by fordman65
02/11/16 03:50 AM
Better micron rating than a 40u for a 4967/14476?
by ziggy
02/11/16 02:59 AM
Weapon Shield
by Ws6
02/11/16 12:33 AM
tempnexus, cobra1616z, meyer, biyogo, Jandry
56894 Registered Users
102 registered (440Magnum, Andrei, AlaskaMike, akela, A310, 10 invisible), 1597 Guests and 202 Spiders online.
56894 Members
66 Forums
244542 Topics
#3198158 - 11/25/13 09:00 PM could i have a problem with a new thermostat
locksmith Offline
Loc: North Jersey
on my 96 oldsmobile ciera 3.1 v6 i bought a new napa # 222 thermostat and installed it now it seems when i start it cold i get no heat sometimes and my temp gauge swings up to 3/4 semi fast then after some time it comes back down and then a few minutes later i get heat then sometimes the heat turns cold and the gauge starts going up again after running for over 25 minutes everything is good. the system is bled correctly could the brand new napa thermostat be bad? I changed the thermostat because the original was stuck open, i also replaced the water pump because it was starting to leak and there is a new radiator cap also.
#3198184 - 11/25/13 09:19 PM Re: could i have a problem with a new thermostat [Re: locksmith]
actionstan Offline
Loc: Ohio
I suppose anything is possible, but what you describe are classic symptoms of the system having air in it.. How did you verify the system has been bled correctly?
These 3.1s can be a real booger to get bled.. Believe me. Do a search on the web there are several recommendations on bleeding these, and mods that can help your cause.. Off the top of my head one that stuck out to me was drilling a small hole in the lip of the thermostat to allow easier bleeding.
Edited by actionstan (11/25/13 09:23 PM)
1999 Saturn SL1
2013 KIA Forte
#3198189 - 11/25/13 09:26 PM Re: could i have a problem with a new thermostat [Re: locksmith]
Chris142 Offline
Loc: apple valley, ca
Ya theres 2bleeders on that car.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3198194 - 11/25/13 09:28 PM Re: could i have a problem with a new thermostat [Re: locksmith]
ram_man Offline
Loc: southern mo
sounds like you have air in the system. I would drain the fluid remove bleeder and then with car off pour fluid back in and when it pours out of the bleeder you are done, reinstall bleeder and top off let run till warm with heater on and make sure its full and its al done.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3198220 - 11/25/13 09:54 PM Re: could i have a problem with a new thermostat [Re: locksmith]
oldhp Offline
Loc: Southern Illinois
Back the car in a ditch or jack up front of the car, gets the front of the engine tilted upwards to help bleed out the air. There should be two air bleeds. Don't worry about making a mess when bleeding system, doesn't hurt a thing.
Edited by oldhp (11/25/13 09:55 PM)
2014 RAM Express 3.6/8 speed work truck.
2012 Equinox 2.4-Wife's Ride
#3198468 - 11/26/13 08:01 AM Re: could i have a problem with a new thermostat [Re: locksmith]
eljefino Offline
Loc: ME
If this trouble continues, drill a tiny hole in the flange of the thermostat. If you get an air bubble behind the pellet, it never sees heat and never opens.
Also, that hole will help generate a slight water current behind the stat, which will help tickle the pellet and keep it up to date with what's going on, temp wise. If, heaven forbid, you get a tiny amount of exhaust in your coolant due to a HG leak this hole will let that gas find its way out, too, and not cause future problems the next cold start. (Not saying you have this)
#3198998 - 11/26/13 06:57 PM Re: could i have a problem with a new thermostat [Re: locksmith]
oldhp Offline
...and locate the drilled hole at the 12 o'clock position.
