Got me a new Stihl FS 56 trimmer today
by daddi
08/30/16 01:02 PM
Truck cap lights.
by wolfehunter
08/30/16 12:12 PM
filters and oem specs
by mobilaltima
08/30/16 11:50 AM
H11 bulb options
by asiancivicmaniac
08/30/16 11:47 AM
Engine oil accidently added into transmission
by Mazatrol
08/30/16 09:51 AM
Oil for 1996 Mazda B4000 pickup
by schuylkill
08/30/16 09:16 AM
Shell gas $80 rewards cars for $52 Deal ends 9-1
by gojoneeded
08/30/16 09:12 AM
Cleaning a carpet stain....Help!
by mjk
08/30/16 07:39 AM
Windshield: can it be repaired?
by supton
08/30/16 07:12 AM
Sea foam for my car?
by NavyVet88
08/30/16 07:04 AM
Anyone have experience with Chinese stereos?
by 55Test
08/30/16 06:37 AM
A 14.5 billion dollar bill for Apple
by Pop_Rivit
08/30/16 05:58 AM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
81 registered (Alfred_B, asiancivicmaniac, ARCOgraphite, 87sammy, 74Scout, 09_GXP, 7 invisible), 1633 Guests and 9 Spiders online.
58964 Members
66 Forums
253772 Topics
Page 1 of 2 1 2 >
#3197898 - 11/25/13 03:56 PM What oil should I use? 2003 Honda Accord
Grkman00 Offline
Loc: FL, USA
Hello all! I'm new to the forum and am interested in learning more about what oil I should use in my vehicle. I took a look at the list of helpful information so I'll try to fill in as much as I can here.
-I have a 2003 Honda Accord Coupe w/ 4 cyl 2.4l engine
-I live in the Tampa area of Florida
-Most of the time I'm not too hard on the car since I plan on having it for a while, but occasionally I do like to give it a good run with quick accelerating and driving it hard.
-I work and go to school fairly close to home so a majority of my trips are short. Once in a while I do take it on long trips
-The only real issue I know about right now with my car is some issue with the clutch. A friend told me the master and/or slave cylinder may need some work.
As far as synthetic vs conventional, I myself don't have a preference, even though I've heard on many occasions to go synthetic. My mechanic swears up and down by full synthetic and tells me I should go full synthetic in my vehicle.
On my last oil change I put a synthetic blend, but I don't recall the brand.
Its almost time for another oil change and I have come to the boards of BITOG to find out what would be the best oil to put in my vehicle. I don't mind ordering or going to a store to buy my oil and I will change it as often as it needs. My main concern is to keep my car running well for as long as I possibly can since I will be doing a good bit of custom work on it.
#3197904 - 11/25/13 04:03 PM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
y_p_w Offline
Loc: SF Bay Area
I'd personally go Mobil Super 5000 5W-20 and call it a day. These engines aren't known for being terribly tough on motor oil. I would change the filter every time rather than every other change.
#3197906 - 11/25/13 04:04 PM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
davglt Offline
Loc: kansas
I would use PP either 5W20 or with your climate 5W30,should be good for 5000 miles in your cycle, 10,000 miles if fewer short trips. PU would also be a great oil for this engine.
#3197912 - 11/25/13 04:12 PM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
Voltmaster Offline
Loc: California
PP , Mobil super 500 , QSUD .
dont bother taking it out less than 6k/1yr interval.
any of these weights is good
0w-30 , 0w-20 , 5w-20 , 5w-30.
the W is winter, unless you live somewhere really cold it doesnt matter that much , lower number helps engine start easier.
Honda has speced all their cars to Xw-20 now because lower viscosity means more efficient engines. dont hesitate to use it!
I have 2000 accord , realistically anything half decent is good to go for these cars. Running longer interval simply makes sense.
You can also put mobil1 exteneded performance and go 10k with p1 filter for total of 31 something out of door. Walmart sells these for 27 ish, and p1 are available on amazon for 6 dollars.
I would just not exceed the 1year no matter how much you drive.
Happy oil changing, your car will loves you for it.
Edited by Voltmaster (11/25/13 04:18 PM)
#3197936 - 11/25/13 05:03 PM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
Roob Offline
Loc: Ontario,Canada
The benefits of a high VI oil in 0w20 will work best for you with that type of driving.
You will have much improved startup protection and maximized MPG for the short tripping.
TGMO 0w20 or MAZDA with moly 0w20 would be your best bet in that regard.
I use both and cannot believe the difference they have made in the car.
Enjoy...
2007 Accord Coupe 2.4 Vtec.
QSGB 5w20 with Fram TG
HDW1+ LG Platinum
Toyo Versado Noir-V
#3197969 - 11/25/13 05:39 PM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
fdcg27 Offline
Loc: OH
This is a K24.
It isn't picky about oil.
If you want to give it a treat, PP or M1 in 0W-20 would be a good choice, but given the moderate climate in which you live, probably any twenty or thirty grade oil would work well.
Does this year have an IOLM, or just the mileage based MM?
If this car has the same IOLM MM my '12 has, then you can trust it to guide you on change intervals.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#3198001 - 11/25/13 06:11 PM Re: What oil should I use? 2003 Honda Accord [Re: fdcg27]
chubbs1 Offline
Loc: Merritt Island FL, USA
Originally Posted By: fdcg27
This is a K24.
I agree to follow the oil life monitor, don't overthink this either. As new members we tend to want to run right out and buy the most expensive oil and change it out at 2k miles. Use major brands and you absolutely can't go wrong. Remember the OLM is calibrated for conventional oil. Go for the cheapest name brand you can find with sales etc. QSUD is a very good oil for a great price. 5w20 or 0w20 would work great. Read the Oil 101 article on the homepage by AEHaas. Knowledge is power. WELCOME!!
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#3198025 - 11/25/13 06:25 PM Re: What oil should I use? 2003 Honda Accord [Re: chubbs1]
y_p_w Offline
Loc: SF Bay Area
This is a K24.
A 2003 wouldn't have an OLM. That is the era of 10K/5K oil changes on 5W-20 though.
#3198033 - 11/25/13 06:40 PM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
tc1446 Offline
Loc: Lexington, NC
Mob Super 5000 5-30, leave it in 5-7K.
'13 Accord EX-L (60K) M1 & FU
'00 Ford Ranger {56K} M1 & FU
'14 Can Am SE6 (23K) Amsoil 10-40
'16 Polaris Slingshot M1 & ACDelco (Ecotec motor)
#3198048 - 11/25/13 06:59 PM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
gregk24 Offline
Loc: FL, USA
Welcome to BITOG! I have a 2006 Honda Accord with the K24. I have ran Castrol Edge w/ Titanium 5w20, Pennzoil Platinum 5w20 and 0w20, Pennzoil Ultra 5w20 and Toyota 0w20...So far I like the TGMO (Toyota) 0w20 best, it is the quietest running oil so far, expecially on cold start up. Seems like the K24 runs well on anything though. But since you are doing short trips I would recommend TGMO 0w20, PP 0w20, or M1 0w20. All are great choices for your car! Oh, and by the way, there is no need for a Xw30 weight oil, 0w20 is the recommended oil for your engine, and it spec'd 5w20 from the factory.
Edited by gregk24 (11/25/13 07:01 PM)
2012 Honda Accord EX-L
Taffeta White - Ivory
40,xxx miles
PPPP 0w20 / Fram Ultra
#3198331 - 11/26/13 01:15 AM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
Grkman00 Offline
Loc: FL, USA
Thank you all for all of your helpful knowledge! I will most likely go with PP 5W20 or 0W20 if they have it. What about for a nice filter? Or does the filter not matter as much as long as you get a decent one?
#3198532 - 11/26/13 09:33 AM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
Mauro Offline
Loc: Canada
I have the K24 engine in my 05 CRV and i always use PP 5W20 with a Purolator PureOne filter. Inexpensive filter and good quality.
#3198586 - 11/26/13 10:35 AM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
ThirdeYe Offline
Loc: Walker, MI
Nice car. The '03-'07 Coupe 4-cyl is exactly what I want for my next car, if I can actually find one in good shape. All of the ones I've looked at are pretty beat up. Sorry, I guess that wasn't much help to your original question... smile
99 Pontiac Firebird - 93k - Havoline 10W-30/Purolator PureOne PL10111
08 Scion tC - 122k - Pennzoil Platinum 5W-20/Fram XG4967
#3198706 - 11/26/13 12:42 PM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
Blue_Goose Offline
Loc: New Hampsha
I have an 03 Accord EX-L 5 spd that is a great car. Like yours, the clutch is a little wonky at times.....feels low and it creaks in warm weather.
I've used all sorts of oil since I've had it (about a year and about 138K on it) and right now it is running Maxlife 5w20. The car definitely sounds like a diesel when you first start it especially when cold. It drinks maybe a quart every 3 to 4 thousand miles....It could be a longer interval, I'll have to pay closer attention.
For the next change I will try the TGMO and see how it runs with that
2014 Dodge Charger SE 3.6L
2003 Honda Accord EX-L 2.4L 5MT
2011 Harley Davidson Road King
#3199168 - 11/26/13 09:44 PM Re: What oil should I use? 2003 Honda Accord [Re: Grkman00]
NO2 Offline
Loc: Michigan
I'd consider Mobil 1 5w-20 extended protection with a Fram Ultra or Mobil 1 filter. This oil is very quiet in our '07 Accord V6. You only need to change it annually/ 15K miles (Mobil guarantee). If you are an average driver (12-15K/yr) this is a great low cost per mile, full-synthetic option. Should be < $40 out the door w filter @ Wal-mart, plus labor.
Edited by NO2 (11/26/13 09:46 PM)
Page 1 of 2 1 2 >
