Motorkote ??
by Moondawg
07/29/16 08:53 AM
Windows 10 For Free Last Day
by NHHEMI
07/29/16 08:24 AM
HD Truck Maintenance Costs - Wow!
by Miller88
07/29/16 08:10 AM
1,000,000 mile Tundra
by Hokiefyd
07/29/16 07:34 AM
Choosing oil with both CJ4 and SN specs
by devarshi84
07/29/16 07:11 AM
Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
77 registered (2015_PSD, 09_GXP, 2009Edge, 87sammy, 2010Civic, 2002 Maxima SE, 6 invisible), 1775 Guests and 11 Spiders online.
58632 Members
66 Forums
252390 Topics
#3197784 - 11/25/13 02:29 PM Anyone heat there garage with Pex tubing under the
callbay Offline
Loc: Ozark Mountains
concrete? If so how do you like it?
What do you heat the liquid in the pex with?
How long does it take to heat up?
Is it expensive to operate?
Any advice?
Thanks a lot!
#3197848 - 11/25/13 03:16 PM Re: Anyone heat there garage with Pex tubing under the [Re: callbay]
rrguy Offline
Loc: MN
I just poured some concrete with pex in it cause working on a warm floor is much better than a freezing one. Everyone I know likes it. It does take a day or more to heat up it will retain the heat also. So no turning on the heat and presto. Yet a concrete floor in a heated shop will never get as warm nor near as fast as in floor heat will.
I am looking at a waste oil or wood boiler to heat it with. I have heard some using a gas water heater usually to heat in floor heat in thier house also & liked it.
"This post is uselesss without pics"
Royal Purple
Semper Fi
#3197889 - 11/25/13 03:48 PM Re: Anyone heat there garage with Pex tubing under the [Re: callbay]
Clevy Offline
Loc: Saskatoon canada
Radiant floor heat is my favorite form of heating.
Here we'll add 1 1/2 to the wall height and pour gypcrete on the entire floor then zone each room.
You use a type of glycol to carry the heat from the boiler to the zones.
Make sure you insulate the ground with extruded polystyrene.
I recommend at least 8-10 inches under the concrete. It will save you money down the road. The extra couple hundred in insulation will pay for itself.
And look into wood fired boilers to supplement the main boiler.
We built a house where the entire home was radiant floor heat that had a gas fired primary and a wood secondary.
The wood secondary was a shed with the boiler inside. The sheds roof flipped open. To expose a boiler large enough to drop tree stumps into. They would burn for a week at a time.
The owner of the home had a tree pruning,tree removal and stump removal business so in the winter basically the customer paid for him to remove their stumps and dispose of them to which he disposed of in his boiler which heated his home and 5000 square foot shop.
We also build 4 storey walk ups here(apartments) that heat with radiant floor heat using a wet system,not an electric type.
My first house I built for myself had a gas boiler for the house. In my detached garage I had a wood burning boiler.
I could open a valve which pumped heated fluid to my shop(gas fired) but I could also turn of the gas fired boiler and run straight from my wood burner.
My gas bills in that house cost me more in the summer than in the winter because in the summer I didn't start the wood fired boiler but in winter the gas burner never ran at all.
My natural gas bills annually never exceeded 600 dollars.
The wood was free because I'd bring it home from work.
I charged the builder for site clean up and disposal which was 1000 dollars per house to be completed after shingles were installed.
So the shingles went to the dump which cost me 50 bucks. The lumber came to my house.
My men know that nothing larger than 24 inches goes into the garbage until the house is 100% complete and it passed inspection.
So my wood burner always had easily handled and stacked pieces ready for burning. The customer paid me to remove and dispose,I paid my men to do the clean up,and stack everything and at the end of the day in our cold sask winters my heat actually paid me to use it because once it was all said and done it was stacked ready to burn and I turned a profit.
Yeah wet radiant floor heat costs about 20% more for in labour however because there were no bulkhead drops in my basement as well as less framing problems going around various ducts.
And in my cantilevers I had hear right to the end of wall therefore no cold spots anywhere.
I also used spray foam wall insulation adding further weather tightness.
The only thing I will say about building that right is venting for fresh air movement. I had fans in all the bathrooms and kitchen but if I had to do it again I'd have bigger fans that moved more air.
And the garage got so hot and melted the snow,evaporating very fast it created a sauna that was just unreal so I suggest mechanical fans such as used in bathrooms and I'd use a moisture type sensor to actuate the fans to exhaust it in a hurry,otherwise the paint will come off the walls in a big sheet.
2006 Charger RT
Miles x 2 per oil filter
#3197893 - 11/25/13 03:50 PM Re: Anyone heat there garage with Pex tubing under the [Re: callbay]
DoiInthanon Offline
Loc: Missouri
We put it in our house over 20 years ago. Put it in the concrete about 1/3 slab thickness from the bottom. A standard 40 gallon, 40,000 BTU/hour gas water heater heats the house and provides all of our domestic hot water. We have 3800 square foot of concrete slab weighting 72 tons. The key is insulation. Peak heating demand at zero exterior and 70F interior is 23,000 BTU/hour in cloudy windless conditions. Of course 0F occurs rarely. Here in south central Missouri, the system idles. The cost is very low since the house is super well insulated and the heating load is super low. My system is very homemade. No fancy headers, valves, or controls. It has one small 80 watt circulator. For example the headers are simple soldered together copper pipe with tubing connectors. The tubes are held by regular hose clamps to the connectors. There are no balancing valves etc.
There is an great amount of free design help on Build-it-Solar: http://www.builditsolar.com/ For a garage, you most definitely can do it yourself. It is very forgiving of mistakes. Much more important is careful design and construction of the floor. Good drainage of the sub-grade. Careful compaction of the sub-grade. Vapor barrier and insulation well done. Tubing in accordance with your plan. Pea gravel concrete from the local ready-mix. Pressurize the system during concrete placement. That will keep the flatwork guy from cutting the tubes because he knows the gage will go to zero if he does. The concrete guy who did mine learned well and now puts in a floor or two every year.
Respectfully, Jim
