Buying services for new vehicles?
by powayroger
02/07/16 05:44 PM
Hard to find QSUD 0w20
by chiefsfan1
02/07/16 04:58 PM
Small compressor advice + a story of stupidity
by dishdude
02/07/16 04:33 PM
w116 300sd Lower shock bolt type/size
by Gito
02/07/16 04:20 PM
FRAM XG7317 Cut Open
by HX520W
02/07/16 04:17 PM
weld leaking on transmission pan.
by motor_oil_madman
02/07/16 03:41 PM
PP and Honda CR-V
by klt1986
02/07/16 03:04 PM
113,800 miles on plugs w/ pics - 2009 F150 5.4 3V
by 04SE
02/07/16 02:59 PM
Sludged 1zz-fe pic... Ex-fleet car.
by SanProsan
02/07/16 02:53 PM
Autozone oil score today
by jdavis
02/07/16 01:12 PM
Valvoline V0-88, 5,000 miles, CUT OPEN
by car51
02/07/16 12:27 PM
Timken throwout bearings?
by buck91
02/07/16 12:17 PM
Compignite, pezman65, Wansu, DaleAZ, Nazmorgul
56846 Registered Users
82 registered (Al, amusing, 1foxracing, 440Magnum, 13Track38, 1989outlaw, 2 invisible), 1190 Guests and 205 Spiders online.
56846 Members
66 Forums
244380 Topics
#3197696 - 11/25/13 01:05 PM Nissan Altima 2000 model Overheating,Ash/milky oil
alfaga Offline
Loc: Lagos,Nigeria
My car just began overH. The temp gauge fail,I fix this the other day,the the radiator was replace with double cell from Maxima 90 since the single cell on the car is burst on top cover. Now the oil is ash / milky in colour on check. I fire it on a ride of about 12Km but oil not clean. Now it fails to start,water gush ou with bubble from radiator at starting.Im confused.Anyone to help me out in the house?
Ohhhh! Earlier i heard a strange noise from arround the engine cover near timming chain, but it stops after overheating problem. Ohhhhhhhh! What do i do?
Nissan Altima GLE 2000
#3197704 - 11/25/13 01:13 PM Re: Nissan Altima 2000 model Overheating,Ash/milky oil [Re: alfaga]
Astro14 Online   content
Loc: Virginia Beach
Milky oil means you have a head gasket failure. The coolant is getting in the oil. This explains your overheating.
If you're lucky, it's just the gasket. If you're not lucky, then the head itself has warped,. Both conditions explain the leak, the overheating and the bubbles....
Edited by Astro14 (11/25/13 01:14 PM)
32 Packard 15W40
90 4Runner 5W30 Edge
92 300E 5W40 LiquiMoly
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W30 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
#3197712 - 11/25/13 01:22 PM Re: Nissan Altima 2000 model Overheating,Ash/milky oil [Re: alfaga]
Donald Offline
Loc: Upstate NY
Depending upon mileage and $$, you might be better off with a reman head if the head is warped
Keep in mind the water and oil mix may be in the bearings which is no good.
I would drain the radiator. Drain and change the oil. Do not add any coolant. Run the engine for maybe 30 seconds. This will flush out and oil and coolant mix in the bearings.
Then deal with the head.
You cannot drive this vehicle.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3197732 - 11/25/13 01:40 PM Re: Nissan Altima 2000 model Overheating,Ash/milky oil [Re: alfaga]
tinmanSC Offline
Loc: Oswego, IL
I think the problems you were having before were not a radiator issue or a failed part, it was a head gasket issue from the start. Coolant is getting into the oil which explains the other issues you were having. I think Donald's advice is good. (especially the part about not driving it!)
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 5-spd@200K, 2000 GS300@125K both VML Full Syn+Purolator PSL20195(soon to be Wix)
#3197808 - 11/25/13 02:43 PM Re: Nissan Altima 2000 model Overheating,Ash/milky oil [Re: alfaga]
alfaga Offline
Loc: Lagos,Nigeria
Thanks u all for ur time.
I can't still understand the cause of strange soumd around timing chain side of the engine before I get overheating problem. And how would overheating of Engine stop the noise is still Another confussion.
The car is now at Mech shop but he told me the. Engine need to cool well before he can check detail in the engine.
#3197812 - 11/25/13 02:46 PM Re: Nissan Altima 2000 model Overheating,Ash/milky oil [Re: alfaga]
alfaga Offline
Loc: Lagos,Nigeria
#3198652 - 11/26/13 11:44 AM Re: Nissan Altima 2000 model Overheating,Ash/milky oil [Re: alfaga]
alfaga Offline
Loc: Lagos,Nigeria
Hello all,
The car is back live.
The gasket changed.oil changed and the fan connection now ok.
Surprise! The timming chain sprocket was not properly fixed by the mech guy that worked on the engine b4 i got it.sign of wear on it and this was corrected. The noise is gone.
Thank u all.
I took it to work today on a 25Km drive. No noise,no sound,no overheating!!!!!!!\
Waoooooo.
#3198707 - 11/26/13 12:42 PM Re: Nissan Altima 2000 model Overheating,Ash/milky oil [Re: alfaga]
ThirdeYe Offline
Loc: Walker, MI
The '98-'01 Altima engine was pretty tough. Did they use the 2.4L KA24DE in yours as well? I had one in a '98 and they originally came in a Nissan pick-up. Very stout engines... which is probably why it was able to survive a blown head gasket. Glad to hear it's back on the road! I miss my Altima all the time, and I wish I wouldn't have gotten rid of it. I do remember having some timing chain noise in the car, but that may have had to do with the car's questionable oil change history before I got it. I was told it was the tensioner, but I never ended up fixing it.
99 Pontiac Firebird - 91k - Pennzoil Platinum 5W-30/Fram Extended Guard XG3980
08 Scion tC - 112k - RP 0W-20/Fram Ultra XG4967
#3200286 - 11/28/13 06:33 AM Re: Nissan Altima 2000 model Overheating,Ash/milky oil [Re: alfaga]
Char Baby Offline
Loc: Western NY
Originally Posted By: alfaga
Hello all,
Thank u all.
Waoooooo.
Glad you're back on the road and doing well. Though it was probalby an expensive repair, I'm sure it was money well spent smile
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
