Old wall furnace
by Jarlaxle
08/26/16 02:55 PM
automatic side folding mirror squeak
by Grambo
08/26/16 02:11 PM
Anybody own a new Mazda 6?
by AirgunSavant
08/26/16 01:58 PM
Do Employees Of Car Companies Get New Cars Cheap ?
by crazyoildude
08/26/16 01:54 PM
Amsoil SVG 75W90, 50K, 04 Duramax 196K
by dhellman12
08/26/16 01:53 PM
When an orifice is needed & when it is not (long)
by ryaneirich
08/26/16 01:38 PM
UT-Austin Response to CC
by sleddriver
08/26/16 01:36 PM
Grease darkening quickly on bicycle bearings
by Wheel
08/26/16 12:54 PM
Just replaced valve cover gasket
by JeepWJ19
08/26/16 11:48 AM
You Got A Merv People!
by AirgunSavant
08/26/16 11:17 AM
Total Quartz 9000 Energy 0W30 - Synthetic or not?
by Seweryn
08/26/16 10:32 AM
Options for Cadillac DTS with the Northstar Leak
by Ddub
08/26/16 10:21 AM
rgmbedzi3, wildkid2008, dccode, dromonk, sledhead1
58930 Registered Users
96 registered (1JZ_E46, adamrc, Al, AirgunSavant, AlaskaMike, 2015_PSD, 10 invisible), 1760 Guests and 33 Spiders online.
58930 Members
66 Forums
253588 Topics
#3197628 - 11/25/13 12:14 PM Oil leak from head, Max Life can solve?
Giorgiz Offline
Loc: Italy
Hi, unfortunately my mechanic says that my Citroen C3 1.4 16V 90hp leaking oil from the head gasket before replacing the gasket, I wanted to know if you can with Valvoline MaxLife groped to solve the problem. I await your responses. thanks
#3197645 - 11/25/13 12:25 PM Re: Oil leak from head, Max Life can solve? [Re: Giorgiz]
shDK Offline
Loc: Denmark
I doubt it. A Thing like a head gasket should be fixed. Ain,t that difficult on that engine anyway.
Edited by shDK (11/25/13 12:31 PM)
#3197647 - 11/25/13 12:26 PM Re: Oil leak from head, Max Life can solve? [Re: shDK]
demarpaint Offline
Loc: NY
Originally Posted By: shDK
I doubt it. A Thing like a head gasket should be fixed. Ain,t that difficult on the engine anyway.
+1
God Bless Our Troops
#3197693 - 11/25/13 12:59 PM Re: Oil leak from head, Max Life can solve? [Re: Giorgiz]
actionstan Offline
Loc: Ohio
IMO Maxlife is good for something like an oil pan gasket, valve cover gasket, or any other gasket that is not "super critical". A head gasket should be replaced asap, the right way. It sucks, but my guess is if it is leaking oil it will eventually get worse and you could end up with a milkshake in your crank case, no one wants that. (could lead to a pretty badly damaged engine)
1999 Saturn SL1
2013 KIA Forte
#3197695 - 11/25/13 01:04 PM Re: Oil leak from head, Max Life can solve? [Re: Giorgiz]
Astro14 Offline
Loc: Virginia Beach
Generally, head gaskets are metal. Nothing to swell, treat, or "condition, like other seals. The only fix is the replace the gasket...preferably, before it starts leaking coolant too....
32 Packard 15W40
90 4Runner 10W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
16 Tundra 1794 TGMO
#3197699 - 11/25/13 01:09 PM Re: Oil leak from head, Max Life can solve? [Re: Astro14]
shDK Offline
Loc: Denmark
Though The gasket is steel. There still is rubber sealing for coolant and oil canals in the gasket.
#3197709 - 11/25/13 01:18 PM Re: Oil leak from head, Max Life can solve? [Re: Giorgiz]
Lubener Offline
Loc: Ohio
If it is leaking that bad, I would check for warpage or a crack. Head gaskets "usually" do not fail that way.
The "thinking" man's friend.
#3197718 - 11/25/13 01:28 PM Re: Oil leak from head, Max Life can solve? [Re: Lubener]
actionstan Offline
Loc: Ohio
+1 You will want to find out WHY its has failed.. unless these are a common issue for these cars, sometimes head gaskets just fail. You don't want to fix the problem, without addressing an underlying cause.
1999 Saturn SL1
2013 KIA Forte
#3197724 - 11/25/13 01:35 PM Re: Oil leak from head, Max Life can solve? [Re: Giorgiz]
Donald Offline
Loc: Upstate NY
Fix it.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3197766 - 11/25/13 02:10 PM Re: Oil leak from head, Max Life can solve? [Re: shDK]
Astro14 Offline
Loc: Virginia Beach
Depends on the gasket. I've seen many that are simply steel, and when crushed, the impressions in the steel seal oil and coolant passages...but I think that either way, the maxlife is unlikely to make any difference...
32 Packard 15W40
05 MB S600 0W40 M1
16 Tundra 1794 TGMO
#3197864 - 11/25/13 03:26 PM Re: Oil leak from head, Max Life can solve? [Re: Giorgiz]
Giorgiz Offline
Loc: Italy
in effect in the European small car, head gasket gives around 120/150 mila km, so in that case I have to do to perform the job to my mechanic
#3197938 - 11/25/13 05:03 PM Re: Oil leak from head, Max Life can solve? [Re: Giorgiz]
Richtrashman Offline
Loc: Cincinnati OH
In my opinion no oil is going to stop a head gasket leak. Also head gaskets do fail, the rest of the head could be just fine. I have put head gaskets on several 4cyl and not had to mill the head. The gasket just fails over time. Fix it, don't put any of that head gasket repair junk in the antifreeze either, asking for coolant system issues later IMO
2010 Optima 88k+ valv ML, ML ATF
1990 c2500 173k+ any
2005 Xterra 91k ML ATF
In the land of the blind the one eyed man is King
