Both are very good good oils. You can look at the spec sheet and see they are very close. QSUD actually has a little better cold performance. Both 5w30's are HTO-6 approved and dexos approved. Flip a coin.
I suspect they're basically the same oil at this point. The additive packages are almost identical, though it does seem that PP has a hair more calcium in it, but not much.
