1997 Avalon, 246K miles. Getting P0401 code insufficient EGR flow detected. The troubleshooting from the Haynes manual says to remove the vacuum tube from the EGR valve and apply vacuum. The engine should run poorly and the vacuum remain steady. If the vacuum does not remain steady and the engine does not run poorly replace the EGR valve. If the vacuum remains steady but the engine does not run poorly troubleshoot the EGR valve.
Naturally, what happens is that the engine runs poorly but the vacuum does not remain steady. I have taken off the valve and inspected it and cleaned it and can't find anything wrong but also can't find any moving parts.....suggestions???
