Fuel injector cleaner that will run the engine?
by Red00Jetta
42 seconds ago
Car's models of 1990 and now
by HTSS_TR
10 minutes 18 seconds ago
Another dealer oil change story
by mclasser
36 minutes 22 seconds ago
Diagnosing HEI ignition module and ignition system
by Fsharp
Today at 05:58 PM
Spark such way?
by yvon_la
Today at 05:48 PM
What's the best filter out of these?
by horse123
Today at 05:27 PM
AC vs. Evaporative Cooler.
by 3for3
Today at 04:40 PM
Rock auto wix specials
by HankMcMauser
Today at 04:03 PM
Hunk of junk air filter
by rickmeseke
Today at 03:41 PM
MicroGreen filter at 8,114 miles
by Rex
Today at 02:33 PM
Opinions on this 2006 Lincoln
by Milkman
Today at 01:40 PM
I'm sure these have been posted before but...
by Yup
Today at 01:24 PM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
99 registered (10WSmuckers, 4ever4d, 3800Series, 69GTX, 60ampfuse, 2015_PSD, 6 invisible), 1583 Guests and 260 Spiders online.
58023 Members
66 Forums
249608 Topics
#3196292 - 11/24/13 04:37 AM Gasoline diesel engines
Exhaustgases Offline
Loc: wa
I'd like to read some stories about this. Real stories that is.
#3196340 - 11/24/13 07:09 AM Re: Gasoline diesel engines [Re: Exhaustgases]
skyactiv Offline
Loc: The Midwest
You OK? http://www.steelsoldiers.com/showthread.php?30821-Are-all-Dueces-Multifuel/page2
Me: 13' VW GTI 3 door 6 speed manual
#3196376 - 11/24/13 08:09 AM Re: Gasoline diesel engines [Re: Exhaustgases]
fdcg27 Online   content
Loc: OH
There are two possible scenarios.
One would be using diesel in a spark ignition engine.
This is common in parts of the world where diesel is more readily available than gasoline, like Cuba.
You start the engine on gasoline and then switch to diesel after it warms up. This works with old, low compression engines.
It might not work as well with more modern engines, since diesel has very low octane.
The second possibility would be a compression ignition engine using gasoline as a fuel. This has been tried as well and there is some serious work going on to evaluate such designs for production.
Of which were you thinking?
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#3196450 - 11/24/13 09:08 AM Re: Gasoline diesel engines [Re: Exhaustgases]
Cardenio327 Offline
Loc: Oaxaca, Mexico
About 20 years ago a neighbor had a large antique Farmall that started on gasoline and ran on diesel. Had two levers that had to be moved at the same time to switch it over. If I understand right one of the levers closed off auxiliary combustion chambers with poppet valves increasing compression and shutting off vacuum flow through the carburetor. The other lever apparently started the direct injection of the diesel fuel.
One time he went by the house being towed. Every time he tried to start it, it veered for the ditch. He had mistakenly hooked the power steering hoses up backwards, and the electric starter didn't have enough force to turn the motor that way.
'08 Honda C90ST Super Cub 15w-40 Delvac 1300
'08 Honda NX4 Falcon 5w-40 Delo 400LE
'09 Honda Fit LX 5w-20 PP
'99 F-150 W/T 4.2L 10w-30 QSUD
#3319374 - 03/21/14 08:49 PM Re: Gasoline diesel engines [Re: Exhaustgases]
artificialist Online   content
Loc: Florida
In David's Farm, he operates an engine that can use gasoline and diesel fuel.
http://www.youtube.com/watch?v=Y81EUqzvbWc
Unfortunately, it appears that it can't be run at full power on gasoline.
The idea was that the compression could be lowered in gasoline mode, and that would make the starter do less work. Also, gasoline engines from back then would fire up more quickly than diesels.
2010 Lancer Ralliart Sportback
#3909899 - 11/06/15 11:04 PM Re: Gasoline diesel engines [Re: Exhaustgases]
jmaster Offline
Loc: ann arbor, mi
and then there were gasoline compression ignition engines.
here
01 Mustang Bullitt mobil5k 5w30-break-in, Redline zdp Bosch D+, AMS ATF, Torco 80w90 RGO
97 E350ext 7.3PS 4.10 gears|Mag 1 5w40 syn LM mos2, Bosch D+
