I didnt see this posted here so I'm reposting it from where I read it at subaruforester.org
(thank you to OP rescuer)
http://fram.com/sites/default/f/uploads/en/recall_notice_02052013_for_distribution.pdf
its for the subaru "blue can of death" that fram makes.
see above linky for details
SAFETY RELATED DEFECT NOTICE
To: Purchasers of Subaru Original Equipment Service Motor Oil Filters for certain Four Cylinder
Engine Applications
THIS NOTICE IS GIVEN IN ACCORDANCE WITH THE REQUIREMENTS OF
THE NATIONAL TRAFFIC AND MOTOR VEHICLE SAFETY ACT. FRAM Group
Operations, LLC (“Fram Group”) has decided that a defect exists which relates to motor vehicle
safety in certain Subaru replacement oil filters. Specifically, this Notice applies to motor oil filters
which meet each of the following criteria: a) Subaru Original Service motor oil filter model
15208AA12A used on certain Subaru four cylinder engines; b) purchased for purposes of either selfinstallation or installation by individuals or service centers not affiliated with Subaru of America
(these purposes are referred to as “Self-Installation); and c) manufactured on one of twenty three
dates, indicated by a date code. DO NOT INSTALL THESE FILTERS BECAUSE THEY MAY
LEAK AND POSE A RISK OF FIRE OR ENGINE DAMAGE. In this Notice, motor oil filters
meeting all three criteria are referred to as the “Affected Motor Oil Filters.” In Section D below, we
will describe how to identify the model number and the relevant date code.
IMPORTANT: FRAM GROUP IS RECALLING UNINSTALLED AFFECTED MOTOR
OIL FILTERS PURCHASED OVER THE COUNTER FOR SELF-INSTALLATION OR
RESALE. PLEASE EXCHANGE UNINSTALLED AFFECTED MOTOR OIL FILTERS AT
YOUR NEAREST SUBARU DEALERSHIP AT NO CHARGE.
A. Why is a Recall Being Conducted?
Fram Group identified a manufacturing process control issue resulting in a small number of
motor oil filters manufactured on certain dates that were produced in a manner which does not allow
the filter to fully contact with the engine block. In those instances, the gasket will either immediately
fail or fail within 300 miles of operation. A gasket failure results in rapid loss of motor oil. Since the
oil filter in your vehicle is in close proximity to the hot parts of the vehicle exhaust system, when
motor oil contacts the exhaust system, the motor oil can cause smoking and possibly an engine
compartment fire. Rapid oil loss may also cause engine damage.
B. What are we doing about the problem?
Fram Group is recalling all uninstalled inventory of Affected Motor Oil Filters to prevent
them from being installed in vehicles. Fram Group has already recovered Affected Motor Oil Filters
from Subaru Dealerships.
C. What You Should Do.
You should not install Affected Motor Oil Filters on your vehicle. Please return Affected
Motor Oil Filters to your nearest Subaru Dealership for exchange at no charge.
Engine Applications
