Wishing for shut off and cold atf level checks-
by Lapham3
02/11/16 07:01 AM
1997 Gand Marquis
by fordman65
02/11/16 03:50 AM
Better micron rating than a 40u for a 4967/14476?
by ziggy
02/11/16 02:59 AM
Weapon Shield
by Ws6
02/11/16 12:33 AM
Amsoil Euro 5W-40 92Benz 190E 2.3L 8V 3889 miles
by IllinoisSparky
02/10/16 09:11 PM
Which oil?
by SEMI_287
02/10/16 09:05 PM
Fluid change on my 2015 Accord
by dan_erickson
02/10/16 08:56 PM
Upgrading brakes
by ram_man
02/10/16 08:49 PM
Rear end sounds like an airplane
by mclasser
02/10/16 07:49 PM
GDI engine's and motor oils
by gabriel9766
02/10/16 07:42 PM
Old toyota Need shocks?
by ceast
02/10/16 07:27 PM
How to do a clean install
by Oldmoparguy1
02/10/16 07:21 PM
biyogo, Jandry, BlueKelah, threeeightteen, TOADchunks
56891 Registered Users
56 registered (aquariuscsm, Atesz792, 2009Edge, B767capt, AlienBug, 04SE, 6 invisible), 839 Guests and 147 Spiders online.
56891 Members
66 Forums
244533 Topics
Page 1 of 2 1 2 >
#3194941 - 11/22/13 03:04 PM T6 in my BMW??
StuDawg Offline
Loc: South Carolina
Ok, ive spent hours researching this and trying to come to a conclusion. Ive got a 7.3l that does great with T6. Ive got a 540 that the wife DDs, and I recently got an 88 325i that I DD. M1 0w40 in the 540, trying to figure what to put in the 325; M1, GC, which weight etc....Now im wondering if I cant just put T6 in all three.
Can I just run T6 across the board? I appreciate any feedback on this. Thanks,
(I didnt even know which section to post this in, the passenger car oils, the heavy duty oils or the euro oils!!)
2002 Ford Excursion Limited 4x4 7.3L PSD, Rotella T6 5w-40
2005 Toyota Land Cruiser UZJ100, Mobil 1 5w-30
1988 Toyota Land Cruiser FJ62, Castrol 20w-50
#3194946 - 11/22/13 03:09 PM Re: T6 in my BMW?? [Re: StuDawg]
JHZR2 Offline
Loc: New Jersey
Absolutely! My 318i loves T6!
#3194949 - 11/22/13 03:10 PM Re: T6 in my BMW?? [Re: StuDawg]
dparm Offline
Loc: Chicago, IL
I don't see why not. A touch thicker than what is necessary but I don't think it will complain.
2011.5 BMW M3 saloon ZCP
Castrol Edge Professional TWS 10w60 + Mahle OX 254D3
#3195024 - 11/22/13 05:00 PM Re: T6 in my BMW?? [Re: StuDawg]
OVERKILL Offline
Loc: Ontario, Canada
I wouldn't run the T6 in the 540, I'd stick with the M1 0w-40 in that. Maybe use that in the 325 and the 540?
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3195028 - 11/22/13 05:04 PM Re: T6 in my BMW?? [Re: StuDawg]
Quattro Pete Offline
Loc: Great Lakes
Or you could put M1 0w-40 in all three. smile
The M1 is actually slightly cheaper.
'02 530i (PPE 5W-40)
'15 Q5 3.0T (Edge 5W-40)
#3195034 - 11/22/13 05:09 PM Re: T6 in my BMW?? [Re: JHZR2]
fdcg27 Offline
Loc: OH
My 318i loves Maxlife 10W-40 and I have the UOA to prove it:
http://www.bobistheoilguy.com/forums/ubb...rue#Post2710907
If I were in your position, I'd use Maxlife.
Why pay more for Rotella?
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 152K Defy 10W-40
#3195074 - 11/22/13 06:06 PM Re: T6 in my BMW?? [Re: StuDawg]
Russell Offline
Loc: Lexington, KY
My most recent fill was with Penzoil 10w40 HM in my old 525i with 233,000 miles. Car seems to like it fine. Mobil 1 0w40 was very noisy.
Russell Casey
1995 BMW 525i M50TU 2.5L-6, abt 236K miles. Rebuilt trany.
1998 Ford Explorer Eddie Bauer 154k miles, 4L-SOHC V6. timing chains replaced
#3195146 - 11/22/13 07:17 PM Re: T6 in my BMW?? [Re: OVERKILL]
StuDawg Offline
Loc: South Carolina
Why wouldnt you use T6 in the 540? (M62TU) Because its not LL01 approved? I did think about using the 0w40 in both bimmers. But T6 is only $20/gallon, and it would make my life easier if I could use it in all 3. My 7.3 likes T6 and I certainly wont be changing that.
#3195149 - 11/22/13 07:18 PM Re: T6 in my BMW?? [Re: Quattro Pete]
StuDawg Offline
Loc: South Carolina
I dont think the 0w40 is rated CJ4 for diesel or heavy duty is it? Where is 0w40 cheaper than $20-$21 a gallon?
#3195150 - 11/22/13 07:19 PM Re: T6 in my BMW?? [Re: OVERKILL]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
OVERKILL - I agree with your advice to the OP
Regards
Doug
#3195226 - 11/22/13 08:43 PM Re: T6 in my BMW?? [Re: StuDawg]
Loc: Great Lakes
Correct, it isn't. If CJ4 is a requirement, then yes, M1 0w-40 may not be the best fit. Although, I believe M1 0w-40 has a stronger add pack than T6. T6 add pack had to be reduced to be more friendly to DPF. Not sure if the OP's truck is DPF equipped...
Interestingly enough, in Europe, XOM sells a product called M1 0w-40 Turbo Diesel, and it's the exact same oil as the regular M1 0w-40.
Walmart. M1 0w-40 is $25 for 5qts. T6 is $21.50 for 4qts.
#3195755 - 11/23/13 02:07 PM Re: T6 in my BMW?? [Re: StuDawg]
OVERKILL Offline
Yes. It is also heavier than the LL-01 spec oils that the M62 calls for.
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3195757 - 11/23/13 02:08 PM Re: T6 in my BMW?? [Re: Doug Hillary]
OVERKILL Offline
Originally Posted By: Doug Hillary
Hi,
Thank you Doug cheers
02 Expedition
06 Charger R/T
14 Charger SRT-8
#3195890 - 11/23/13 05:21 PM Re: T6 in my BMW?? [Re: StuDawg]
KenO Offline
Loc: Auburn, GA
Yes. T6 will work great in all of those. I'm sure there are 'better' choices, but the T6 works great in all of them, especially if it makes your life simpler smile
1995 Volvo 960 ShagginWagon
1995 BMW 328ti
1997 Chevy C2500 5.7l V8
1998 BMW 528i
#3196283 - 11/24/13 04:08 AM Re: T6 in my BMW?? [Re: KenO]
Garak Offline
Loc: Regina, Saskatchewan, Canada
True, but it's hard to get simpler (or cheaper) than the availability and package sizing of M1 0w-40 down in the States!
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
Page 1 of 2 1 2 >
