Microgreen Oil Filter 50% Off Discount Code
by kohnen
05/26/16 11:24 AM
by kohnen
05/26/16 11:23 AM
Mobil Delvac 1 ESP 5w-40 for 2011 TDI?
by ruleof72
05/26/16 10:49 AM
Husquvarna YTH2046 riding mower
by Donald
05/26/16 10:47 AM
Any machinists?
by NavyVet88
05/26/16 09:28 AM
new XG750R flat-tracker
by Mik
05/26/16 08:55 AM
Walmart Supertech 5w20 full synthetic $8.12
by paulswagelock
05/26/16 08:51 AM
Thoughts on M1 V-Twin 20-50 Oil?
by ZZman
05/26/16 08:07 AM
Real Estate Rates
by AirgunSavant
05/26/16 06:30 AM
15w-40 in my boat, is diesel oil OK?
by chriscpmtmp
05/26/16 05:47 AM
20W-50 for a hydraulic pump in a hydrostatic trans
by ford46guy
05/26/16 03:48 AM
new castrol edge high mileage synthetic
by hiflo
05/26/16 03:32 AM
Rdyno, Darsahn, jerryg, 1971tr350, Mak712
57990 Registered Users
92 registered (AirgunSavant, ARCOgraphite, badtlc, 1JZ_E46, AZjeff, Atesz792, 7 invisible), 1789 Guests and 310 Spiders online.
57990 Members
66 Forums
249424 Topics
#3194925 - 11/22/13 02:40 PM Oil Pressure Requirements
twX Offline
Loc: Canada
I've heard the rule of thumb that an engine should have 10 psi of oil pressure for every 1000 rpm.
The manual for my Acura Integra GS-R indicates that normal oil pressure is 50psi at 3000rpm with a warm engine, or 17 psi per 1000 rpm.
What would be the reasons for the engineers to choose the oil pump / oil grade / tolerances that result in a higher oil pressure like this? If I experience lower oil pressures (say, 12 psi per 1000rpm) due to high oil temperature at the track or a thinner grade of oil, will this cause issues? Would there be a reason that this higher oil pressure would be required?
Note that above 5000rpm or so, the pressure is pegged at 80psi due to the bypass, yet the engine revs to 8000rpm, resulting in 10psi/1000rpm. It seems to me that the higher pressure at lower rpm is not really required. Thoughts?
#3194929 - 11/22/13 02:46 PM Re: Oil Pressure Requirements [Re: twX]
440Magnum Offline
Loc: Texas
That's what I call "the smallblock Chevy rule." Not applicable to all engines, and certainly not to modern ones where the computer intervenes in oil pressure by controlling a variable output oil pump, for example.
Many threads on this topic already. Many engines have a very nonlinear oil pressure/rpm curve indicating that, unlike the smallblock Chevy, they are intended to run with the bypass valve open over much of the RPM range, giving a much more constant oil pressure.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#3195004 - 11/22/13 04:32 PM Re: Oil Pressure Requirements [Re: 440Magnum]
Shannow Offline
Loc: Oz
Excellent, concise answer...
Look at all the "traditional" engines that it applied to...6-8 cylinders, 4-7 mains, 4-5 cam bearings, lifter lubricated top end, short timing chain and no squirters...oil pressure provdes a supply/reserve to them.
Throw in OHC, VVT, long chains, tensioners and squirters, and the manufacturer has a lot of different things that may need different oil pressures to achieve.
#3195023 - 11/22/13 05:00 PM Re: Oil Pressure Requirements [Re: twX]
Nederlander75 Offline
Loc: Behind you, move over so I can...
And to bake your noodle further my rotary powered RX8 runs about 75 PSI at 3KRPM, maybe 100 or so at 5KRPM, and at redline <9KRPM I can be sitting around 135-150 PSI. Barely less with 20wt and not readably higher with 50wt.
#3195039 - 11/22/13 05:20 PM Re: Oil Pressure Requirements [Re: twX]
Donald Online   content
Loc: Upstate NY
Its engine dependent. It may not be in owners manual but should be in shop manual.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3195071 - 11/22/13 06:01 PM Re: Oil Pressure Requirements [Re: twX]
ammolab Offline
Loc: Ruidoso, NM USA
My BMW K75C motorcycle hits 68psi at 2000 RPM and holds steady until 8000 RPM. Seems like it is set up to always pump a good bit of oil through the relief valve. For years I ran 20W-50, now running 15W-40....no, I will not try 0w-20!
2009 Honda CR-V
2002 BMW M Coupe
2011 BMW R1200R
1986 BMW K75C wrecked at 147,000 miles, RIP,
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
#3195089 - 11/22/13 06:20 PM Re: Oil Pressure Requirements [Re: twX]
jrustles Offline
Loc: Ontario, Canada
Being a GS-R, I'd venture to say that the pressure is required. VTEC, yo
"No matter how paranoid or conspiracy-minded you are, what the government is actually doing is worse than you imagine" W.Blum
#3195391 - 11/23/13 06:52 AM Re: Oil Pressure Requirements [Re: twX]
Garak Offline
Loc: Regina, Saskatchewan, Canada
No surprise. My G specifies more than 20 psi per 1000 rpm.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
