In the newest issue of Snow Tech magazine there are test results performed by the Michigan Tecnological University study that was funded by our DOE (Department of Energy) on E-15 fuel use. Snowmobile engines were chosen, because most are fuel injected, but do not have the sophistication to compensate for changing fuel trims (fixed fuel trims at various RPM's).
8 different models were used (4 new and 4 legacy).
4 tests were performed to evaluate cold start performance (20 degrees F, 0 degrees F, and -20 degrees F),emissions, durability and vehicle driveability.
Cold start performance: this evaluation included time to start, engine speed, exhaust gas temperature and start up emissions. Result: there were no significant differences observed.
Driveability: this was analyzed using a blind subjective evaluation using a controlled test course. Result: drivers could not discern which fuel was being used.
Durability: The vehicles were driven 5,000 miles and there were no engine failures on either E-0 or E-15.
Emissions: carbon monoxide emissions were reduced by 10% to 35% using E-15 relative to E-0. Formaldehyde emissions were increased by 35% consistently on E-15.
The EPA did not approve E-15 in snowmobiles for one reason only. At full throttle, the EGT's were obseved to be higher at sustained full throttle operations. This gave all the manufacturers concern. Too bad the fuel trims could not be added to limit this increase.
Overall, much better than I would have guessed.
