Originally Posted By: crazyoildude
that had nothing to do with towing that was melted
I disagree as the relationship to EGTs, under hood heat, and towing high in the RPM range for extended periods of time and what it does to plug wires and other under hood components has discussed in depth on the RV board.
At any rate. The heat shield that is normally found on the GM plugs did not fit over these like the MSDs that I have run before. Taylor stated they were good for 600 degrees. I won't run the Taylors again. Maybe the MSDs as they are cheaper than the stock GM ones.
