I went to my mechanic because my coolant reservoir had brown in it with the coolant so the mechanic cleaned the reservoir out and told me to come back if u see brown in it again so i went back cause the brown stuff came back and the mechanic said well it could be your coolant was never changed which i think is true considering the car runs perfect and doesn't over heat so he said flush it and see if the reservoir comes back dirty again if it does u have a big issue head gasket but anyway the mechanic said we recommend changing the thermostat as well when doing the flush thing is its hard as [censored] to remove it on my 1995 Buick century 3.1 v6 and im sure there gonna charge me alot of labor what do you guys think should i just get the flush and skip the thermostat?
1995 Buick Century 3.1 v6 91k miles and i have no idea when the thermostat or coolant was last replaced.
