Originally Posted By: TrevorS
The Purolator filter I'm interested in is for Honda (14459) and is rated with reference to the 30001 filter which is measured at 20 microns.
The 14459 has an OD of 3.15 and Height of 2.95.
The 4 filters that are referenced at 40 microns all have OD of 2.69 but height of either 2.93 or 3.52.
I think OD has something to do with this difference specifically to do with media and / or pleat depth.
I just double checked the specs for the Honeywell furnace filter and they specify lower Merv and efficiency ratings and higher pressure drop for a 2 inch filter vs a 4 inch filter. The 2 inch filter is rated for half the life.
So as media depth decreases for the same airflow, pressure increases and efficiency drops. The 30001 filter has an OD of 3.78 and a height of 5.14. We know that larger filters are less likely to go into bypass hence there must be less pressure. Less pressure on the same media means greater efficiency.
Or greater efficiency could be related purely to media depth, in which cases most filters have less horizontal space and hence media depth room than the 30001.
Also for me the reasoning that only the 30001 has 99.9% efficiency at 20 microns is that all the filters apart from 4 reference it explicitly for the claim. If the rating was 99.9% at 20 microns for all of them, why would the reference on all of them refer to the 30001? Its easy enough for Purolator to test all the filters.
FRAM also make the statement that their efficiency is based on group testing on 3 or so filters. For both them and Purolator these are marketing led messaging because it's clearly not good marketing to put the actual efficiency at 20 microns on each filter box. That would be suicide marketing so the asterisk is how they create consistent messaging.
On the 4 smaller OD filters that they are transparent wrt 40 microns, I'm guessing that the efficiency at 20 microns is probably way off so it would be misleading. On all the others they must have made the judgement that with the asterisk caveat, it is not too much of a stretch.
This is why I reason that Pure Ones are 99.9% efficient between 20 and 40 microns with the 30001 leading the pack at 20 microns, the 4 narrowest ones trailing at 40 microns and the rest in between.
No, no, no! Efficiency is PURELY a component of the media... more precisely the size of the pores within it. Efficiency is the same for 1 square inch of a particular material with zero pleats as it is for 100 square inches with 30 pleats. Capacity and flow are vastly different according to the amount of media, but efficiency ... the minimum size of the particle the media will entrap... is the same no matter how much or little is installed in the filter.
Air and fluid filtration are two different animals, so I suggest you not try to draw too many conclusions on fluid filtration from info about furnace filters.
Overall, trying to draw conclusions from what very little you see on a box leads to connecting dots that are too widely spaced will lead you to the dead-end road of bad choices.
