New S&W Shield 9
by funflyer
43 minutes 49 seconds ago
ecoboost 3.5
by boostnation
55 minutes 53 seconds ago
Meijer, Mobil and the joys of Labor Day stackation
by fdcg27
Today at 06:25 PM
BMW electrical system pretty good
by fdcg27
Today at 05:59 PM
The top makes the policy ...
by HTSS_TR
Today at 05:36 PM
Dodge 318 oil?
by chartrue2
Today at 05:04 PM
Fram Ultra XG3506 - 2 years/11,000 miles Cut Open
by Nick1994
Today at 04:39 PM
Genesis G70 spy photos
by HTSS_TR
Today at 04:17 PM
SAE 16. Set at a minimum of 2.3 mPa⋅s at 150C
by wemay
Today at 03:33 PM
1992 Surburban Big Block - M1 10W-30 - 5 year OCI
by bigt61
Today at 03:32 PM
2007 Civic Wiper Blade Contact Fix
by 4thstpositively
Today at 03:14 PM
Got me a new Stihl FS 56 trimmer today
by daddi
Today at 01:02 PM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
106 registered (007, 4WD, 01rangerxl, 8o8is, 2015_PSD, 11 invisible), 1683 Guests and 7 Spiders online.
58964 Members
66 Forums
253783 Topics
Page 2 of 2 < 1 2
#3128457 - 09/18/13 10:08 AM Re: Should I use Maxlife? [Re: TechnoLoGs]
jfking106 Offline
Loc: GA
Originally Posted By: TechnoLoGs
Originally Posted By: T4R
No, it won't hurt your vehicle to try Maxlife and its a great oil, but I don't see how it would help with your oil burning issue. I have used it in several vehicles that leaked oil and it worked great, but its designed to help with leaks (seal conditioners) If it were my car, I think I would try a 10w40 (like WM supertech) or maybe even a 5w40 as it would be better for cold winter starts.
Doesnt it "condition" those seals by "destroying" them?
I think that may be why so many dont use High Mileage oils...
Or, just a Group II like Castrol GTX? .. Does that help?
Who told you they destroy seals? I think that myth comes from the fact that high mileage oils are higher in detergents, and it cleaned out some gunk around old, cracked seals that was plugging the cracks. It's not the oils fault, it's a 15 year old seal or gasket that needs to be replaced. High Mileage oils are designed to make old, cracked hard baked seals soft again. In my experience, high mileage oils only work for external leaks (oil pan gaskets, cam and crank seals, etc.) They won't do anything for burning, unless you bump up the viscosity.
#3128692 - 09/18/13 02:30 PM Re: Should I use Maxlife? [Re: Lubener]
SteveSRT8 Offline
Loc: Sunny Florida
Sorry, but ML has helped many by cleaning ring packs and thus helping with oil burn. It is one of its premier features.
A terrific product.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3128923 - 09/18/13 06:42 PM Re: Should I use Maxlife? [Re: SteveSRT8]
jfking106 Offline
Loc: GA
A terrific product.
Good oil, no doubt, but like I said, Ive never seen an oil that will free stuck rings.
#3128965 - 09/18/13 07:28 PM Re: Should I use Maxlife? [Re: TechnoLoGs]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Some HM oils, notably MaxLife and Mobil Super 2000 (up here) are SN/GF-5 oils in the appropriate grade. Considering such certification requires seal compatibility, I can't see them destroying seals. Both products I mentioned are perfectly acceptable for use in a brand new vehicle that requires SN/GF-5 oils.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3129226 - 09/19/13 05:39 AM Re: Should I use Maxlife? [Re: jfking106]
SteveSRT8 Offline
Loc: Sunny Florida
A terrific product.
I have.
I will add my sincere condolences. But I am sure you understand that just because you have not witnessed it personally it could still happen!
#3129266 - 09/19/13 06:52 AM Re: Should I use Maxlife? [Re: SteveSRT8]
FZ1 Offline
Loc: Texas
A terrific product.
I have.
+1. It "happened" when I installed MSHM 5w-30 in my Accord. No more burning.
#3129450 - 09/19/13 10:25 AM Re: Should I use Maxlife? [Re: SteveSRT8]
jfking106 Offline
Loc: GA
A terrific product.
I have.
Glad it worked for you. Unfortunately, it hasn't for me. It did stop external seal and gasket leaks, though.
#3129456 - 09/19/13 10:30 AM Re: Should I use Maxlife? [Re: FZ1]
jfking106 Offline
Loc: GA
A terrific product.
I have.
Glad it worked. You are aware, though, that most high mileage oils are of higher viscosity than their normal counterparts, right?
#3129480 - 09/19/13 10:54 AM Re: Should I use Maxlife? [Re: Lubener]
KCJeep Offline
Loc: Mahzurrah!
Not anymore, it's pretty much 50/50. You have to know which ones are "thick" because a lot of HM oils have gone for "thin is in". Maxlife, Castrol and Mobil Super for example.
Defy, M1 HM and Pennzoil are still thick for grade though.
2004 Jeep Grand 4.0 @ 133k Pennzoil HM 10w30 w/ 1 qt 10w40
Fram PH8A
KIA Sedona 63k, Ford Focus 116k, Chrysler Sebring 186k, Chrysler Concorde 120k
#3129483 - 09/19/13 10:57 AM Re: Should I use Maxlife? [Re: Lubener]
KCJeep Offline
Loc: Mahzurrah!
I'm a big fan of Maxlife. It doesn't get a lot of play for cleaning around here, but it has as stout a detergent/dispersent add pack as Ultra does at around 2,600 ppm.
That's considerably more than PYB and even many HDEO's. Valvoline just doesn't push that very hard in their marketing like Pennzoil for example tends to do.
Fram PH8A
#3129663 - 09/19/13 01:27 PM Re: Should I use Maxlife? [Re: Lubener]
84zmyfavorite Offline
Loc: Wenatchee, W.A.
I will "Probably" put Valvoline Maxlife 10w-30 in my parents 2001 Jeep Cherokees 125,000 mile 4.0(When it gets to 125,000 which should be in the next week or so). That 4.0 just Loves MaxLife 10w-30. But,...Im Also tempted to install a New rear main seal in that 4.0(JeepOutpost has Crown rear main seals for $8.56 !) and then put a HIGH Quality European Synthetic like Motul 300V 0w-40 or maby LiquiMolys LeichtLauf 0w-40. That would be the Best way to go, I think. Today.
Edited by 84zmyfavorite (09/19/13 01:28 PM)
#3129687 - 09/19/13 01:55 PM Re: Should I use Maxlife? [Re: 84zmyfavorite]
KCJeep Offline
Loc: Mahzurrah!
crackmeup
Fram PH8A
#3129702 - 09/19/13 02:19 PM Re: Should I use Maxlife? [Re: TechnoLoGs]
kschachn Online   content
Loc: Upper Midwest
No.
1994 BMW 530i, 206K
1996 Honda Accord, 218K
1999 Toyota Sienna, 350K
2000 Toyota ECHO, 255K
#3187594 - 11/14/13 12:45 PM Re: Should I use Maxlife? [Re: Char Baby]
diver1972 Offline
Loc: US, Georgia
Originally Posted By: Char Baby
...In addition, with vehicles driven more often than a summer car, I'd expect to see results of HM oils much sooner than my particular 4 years. Several OCI(or a years worth) would be normal IMHO!
Thanks for mentioning this. smile
The Camry in the sig block is on its first fill of MaxLife (at least the first in the last 6 years that I've owned it). It's been in there for 10k miles and 9 months. In that time, I've added 5 quarts total as top-up. During the first 3 months, some of that 5 quart loss was due to oil leaking from 2 places (i.e. top end and bottom end). The top end leak was then patched and PCV was prematurely replaced as a proactive measure (i.e. prior valve appeared fully operational). During the next 4 months, some of that 5 quart loss was due to oil leaking from 1 place (i.e. bottom end: crankshaft seal). The bottom end leak was then patched. There have been no externally visible leaks for the last 2 months; however, I'm still observing loss at the rate of approximately 1 quart per 2k miles (extrapolated based on a 1k-mile sample).
While I didn't keep meticulous records of the pre-repair rate of loss for comparison to the post-repair rate of loss, I've concluded that patching those leaks doesn't appear to have helped much at all. confused I assume the current loss to be entirely internal consumption in the absence of any visible external leak.
Informed opinions please: Does anyone think I'd see a faster reduction in loss if I drain and fill it again with the same MaxLife now vs. just continuing to top-up and running the current fill another 4k miles before doing an actual OC with the same MaxLife? smile
As of 02/15:
01 Toyota Sienna; 1MZ-FE; 174k mi.
99 Toyota Camry; 5S-FE; 197k mi.; acquired 02/14
98 Toyota Camry; 5S-FE; 182k mi.; totaled 02/14
Page 2 of 2 < 1 2
