small update to % fuel in oil
past few weeks its been cold and g/f been saying the heat doesn't seem to be what it use to be.
first though was heater core but I noticed that her temp gauge was not working properly. only came up to the middle after sitting in traffic for a while and then would drop like a rock at highway speed.
went and found my OBD2 scanner this weekend and found that the coolant temp is not coming up to where it should be and it kept going open loop. I suspect an open thermostat is causing this.
thoughts............
