I replaced the catalytic converter in my S10 a little over 2 years ago. I checked and there were no oil or coolant leaks to dirty up the catalyst and it hadn't melted from fuel entering the exhaust. I replaced it with a magnaflow cat even though I strongly prefer OE, I was unemployed at the time and needed to re-register the thing in short order.
I had a P0420(catalyst below efficiency) code come up about 6 weeks ago, I cleared the code and it hasn't returned....yet
What do you all think about replacing the oxygen sensors before buying another cat? If it truly isn't doing it's job one would think the code would have been thrown again at some point in the last 6 weeks, but it hasn't. The o2 sensors are the ones GM installed in the factory so they've been in there for about 12 years and 140k miles, not exactly spring chickens...
Any o2 sensor recommendations? AC Delco or Delphi would be my first choice as they are oem equipment but I work part time and I'm also back in college so my budget is pretty tight. I can get Bosch for both the upstream and downstream and only be out $47. Are Bosch's o2 sensor better than their spark plugs?
