1991 Sierra rear brake squeel
by sr17
05/27/16 12:57 AM
2015 Silverado Diff Fluid Change
by Realtech214
05/27/16 12:25 AM
Undercarriage Rust Management
by OpenClose
05/26/16 11:31 PM
New used tires
by gfh77665
05/26/16 11:29 PM
Hybrid and ROI (Return Of Invesment)
by HTSS_TR
05/26/16 11:14 PM
Best Walmart stocked wiper blades?
by aquariuscsm
05/26/16 10:54 PM
What Ohm antenna wire to use?
by daves66nova
05/26/16 10:46 PM
Turtle Wax Passed The Test
by RevRider
05/26/16 10:46 PM
Total FLUIDMATIC G6 SYN ATF, 13.7k mi OCI, 34k mi
by Emperors6
05/26/16 10:17 PM
Honda NC700X Red Line 10W30, ~5,000 miles
by bulwnkl
05/26/16 10:13 PM
If you liked the Fram AirHog Filters
by rrounds
05/26/16 10:07 PM
Most advanced oil on the shelf?
by Jetstreamz06
05/26/16 09:41 PM
Timmytimmy, Peakboy91, TimingBeltKing, watergate528, iamtheanimal
57996 Registered Users
21 registered (bbhero, chrisri, Bandito440, c502cid, 3 invisible), 490 Guests and 324 Spiders online.
57996 Members
66 Forums
249469 Topics
Page 1 of 2 1 2 >
#3182825 - 11/09/13 08:49 AM Did lugging my Insight hybrid damage engine?
blackman777 Offline
Loc: Santa Ana, California
While doing some hill driving I mis-shifted to 5th gear (instead of 3rd) and the engine started shaking violently (700 rpm). However the electric motor accelerated the car & the problem went away.
Or so I thought. After driving another hour, the check engine' light came on. :-| The engine sounds okay when driving and idling, so I hope it was just a misfire.
#3182830 - 11/09/13 08:58 AM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
d00df00d Offline
Loc: PA
Most big chain auto stores will pull your codes for free. Do that and see what comes up. It's probably fine.
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#3182840 - 11/09/13 09:09 AM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
GutsyGecko Offline
Loc: Youngstown, OH
Don't worry about it. Happens all the time. Lugging wont hurt anything so long as its not done all the time (like you try to drive like that)
#3182865 - 11/09/13 09:51 AM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
LargeCarManX2 Offline
Loc: Up here in the NorthWest
Sometimes my check engine lights up too. Most cars have reset procedures i.e. turn the key on and off 6 times etc....Most likely, your engine was just running super rich and the computer called you on it.
"Success is the ability to go from one failure to another with no loss of enthusiasm."
Sir Winston Churchill
#3182901 - 11/09/13 11:06 AM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
nitehawk55 Offline
Loc: Ontario , Canada
O2 may have picked up on some rich fuel mixture due to lugging it or maybe a knock ?
Doubtful you have anything to worry about , just get the code checked and clear it .
05 Ford Five Hundred AWD 3.0 DOHC V6 CVT tranny
#3182976 - 11/09/13 12:59 PM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
NMBurb02 Offline
Loc: Crowntown, CA
Auto parts stores in California can't pull codes for you. I don't know why, but on AutoZone's and others' advertising where they offer to do such have astericks and say that the service is not available in California. Maybe see if a friend has a scanner.
2002 Chevy Suburban 1500, G-Oil 5W-30, Fram TG3675
2006 Pontiac Grand Prix GT, M1 0W-40, Fram TG3387A
#3183032 - 11/09/13 02:24 PM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
fdcg27 Offline
Loc: OH
Every stick car ever made has had at least one episode where the driver hit fifth when he intended to get third.
Since this a pretty unmistakable error, the obvious solution is to try again and select third.
I wouldn't have continued in fifth, electric motor assist or not.
Still, I doubt that you did any real harm.
The CEL may be just coincidental.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#3183283 - 11/09/13 07:22 PM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
Cujet Offline
Loc: Jupiter, Florida
I was always of the opinion that lugging was bad for an engine.
Then after spending time in Europe, where many commercial drivers lug engines mercilessly, without apparent ill effect, I'm just no longer sure. These guys lug on every shift, start out in 2nd gear regularly, lug up hills and so on. It feels awful.
And the odometers read very high Kilometers. All on the original engine.
I, on the other hand, like to see the tach needle near redline as much as possible. More fun that way. My engines last forever too.
Edited by Cujet (11/09/13 07:23 PM)
Turbo's rule.
#3184735 - 11/11/13 12:42 PM Re: Did lugging my Insight hybrid damage engine? [Re: Cujet]
blackman777 Offline
The definition I heard is, "Lugging happens when the engine loses speed," so I guess as long as the European truck is climbing the hill at constant velocity, then it is okay.
My hybrid CEL went off after 4 starts. The computer advises me when to shift, and if I follow it, I would be shifting at 1100 rpm! I usually prefer at least 1500 minimum.
In the CVT version the engine just sits at 1500-1600 the whole time.
#3184776 - 11/11/13 01:40 PM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
PandaBear Offline
Loc: Silicon Valley
If I remember correctly, Honda has a service connector that you can plug a paper clip to and read the blinking frequency in the CEL for their own diagnostic code (not OBDII), that is usually an even better information than OBD can tell you.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#3185216 - 11/11/13 09:04 PM Re: Did lugging my Insight hybrid damage engine? [Re: PandaBear]
strat81 Offline
Loc: Nebraska
http://www.amazon.com/Autel-MaxiScan-MS3...011&sr=1-10
It's a basic diagnostic tool everyone should own.
If you have an Android phone, get this instead:
https://play.google.com/store/apps/details?id=org.prowl.torque&hl=en
Molon Labe
#3185833 - 11/12/13 02:56 PM Re: Did lugging my Insight hybrid damage engine? [Re: strat81]
blackman777 Offline
Will either of those show me the amount of Turbo boost I'm getting in my 2005 TDI?
#3185845 - 11/12/13 03:08 PM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
jayg Offline
Loc: Anchorage, AK
Yes.
'15 Toyota Prius C TGMO 0w20
'91 Toyota Land Cruiser VWB 5w30
'73 Datsun 240Z 4sp Vintage QS 10w40 from '73 in the sump
#3185851 - 11/12/13 03:16 PM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
camelCase Offline
Loc: Southeastern, USA
The torque app will, along with log it, and overlay your log onto a google maps of the route you took.
It's an AMAZING app. I swear by it. I got it a couple years ago for my Mazda since I couldn't afford (more so I didn't want to pay $500 for) a data logger. I've gotten all the datalogging I need done with the Torque app for $20.
#3186642 - 11/13/13 01:01 PM Re: Did lugging my Insight hybrid damage engine? [Re: blackman777]
blackman777 Offline
On second thought what I really need is a permanent-mounted boost gauge, so I can see the TDI's turbo in action. Or an instant MPG meter (to reduce fuel consumption).
Page 1 of 2 1 2 >
