Originally Posted By: JTK
Rock lath is something that looks like drywall with holes in it and then plastered over, much newer than wood lath. They also used wire lath as well.
I've owned two homes with that. Both built in the mid 1950's. Mine were built with 2'x4' sections of 'drywall' with two different coats of plaster material over the top of that. That stuff wouldn't de-laminate even when soaking wet!! Walls were hard as a rock, super thick in areas and a pain in the stones to ever have to patch an area with a standard piece of drywall.
I always marveled at the time/work they put into stuff back then.
Given a choice I'd take a nice rock lath job that didn't have Casein or Calcimine paint applied to it. In the perfect world a rock lath plaster job with an oil primer and latex top coat would be nice. Next in line would be drywall skim coated, oil primed, and top coated in latex paint.
