2015 Silverado - Put some chrome
by Realtech214
05/02/16 10:22 PM
Ticks!
by spasm3
05/02/16 09:54 PM
shop didn't replace clamps on steering rack
by motor_oil_madman
05/02/16 09:46 PM
First SSD on Xubuntu 16.04
by Eric Smith
05/02/16 09:20 PM
Purolator Boss PBL25277
by Quattro Pete
05/02/16 09:11 PM
Pan w/ drain plug for 62TE
by JTK
05/02/16 09:04 PM
2007 Explorer 4.0 upper and lower intake gaskets.
by ls1mike
05/02/16 08:55 PM
Cars... where they belong: On the road!!!
by Spillips
05/02/16 08:29 PM
I got 'spoofed' !
by Geauxtiger
05/02/16 07:57 PM
2013 Camry DIY Brake Fluid Replacement Experience
by windeye
05/02/16 07:26 PM
Pics Husky 525LS ran on XP oil
by Buzzsaw
05/02/16 07:09 PM
Brake Pad and Rotor opinions
by oilstudent24
05/02/16 07:02 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
22 registered (Farmer, 01_celica_gt, ajchien, carlprop, Atesz792, Dykkerdahl, 1 invisible), 631 Guests and 320 Spiders online.
57779 Members
66 Forums
248388 Topics
Page 1 of 3 1 2 3 >
#3185462 - 11/12/13 06:44 AM Suggestions for a '13 Civic Si
climhazzard Offline
Loc: Virginia
I hate to create one of these threads, but I did search and there's not much info regarding the 2012+ Civic Si smile. I just traded my GTI in over the weekend, since I was missing..having some sort of reliability. Anyway, spent some time searching and there's quite a bit of discussion regarding 0W20 oils, but none I could find that were focussed on the K24Z7, which is the "performance oriented" K24 in the Civic Si.
Toyota oils seem well thought of, and I'm not quite clear on if the new Conoco Phillips made Honda Synthetic is as good as the prior version made by Idemitsu. The Honda stuff seems expensive (around $9/qt shipped) so if Pennzoil Platinum or Mobile 1 AFE are just as good, I'm happy to go with those.
I live in Virginia so we see all sorts of weather, and I plan on changing the oil out every ~5k, unless the maintenance minder tells me to do so sooner. Your thoughts are most appreciated!
#3185479 - 11/12/13 07:11 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
Char Baby Offline
Loc: Western NY
I've thrown any oil that met the spec in my Honda's. Most other engines too! They're not picky though with some trial & error, you will find the one that you and the engine like in particular.
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3185481 - 11/12/13 07:14 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
tc1446 Offline
Loc: Lexington, NC
Don't think you can go wrong with either PP or M1 and they're readily avail anywhere, often on sale. I've used M1 and filters regularly in my Altima for 10K each change, but just for heck of it I put PP and a Fram Ultra in the Accord (same basic engine as yours?)the other day on the 10K mark. I had previously changed the oil at 5K, being of the old school and wanting to get things "cleaned out", but will now run the PP 10K unless the MM tells me otherwise. FYI, the MM read 60% just before the last change.
I've got a bunch of PU in 5W-20 when Walmart had it on clearance and will prob use that next summer. I'm not hung up on the 0W..thing.
'13 Accord EX-L (60K)
'00 Ford Ranger {56K}
'14 Can Am SE6 (23K)
'12 Yam Majesty (5K)
'16 Polaris Slingshot (three wheeler)
#3185528 - 11/12/13 08:19 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
gregk24 Offline
Loc: FL, USA
PP, TGMO, M1, all good choices.
2012 Honda Accord EX-L
Taffeta White - Ivory
38,xxx miles
PPPP 0w20 / Fram Ultra
#3185532 - 11/12/13 08:26 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
Durango Offline
Loc: Los Angeles, California
climhazzard,
Over here in California everything from Conoco Phillipps is expensive but well made oil/gasolines.
If Mobil 1 is less expensive for your pocket book then I'd go for it in a heart beat. I admit I never tried any oil products from Honda cuz in the past the dealerships only offered dealership contracted sources which never included any oils with the labels from Honda nor Toyota.
Durango
#3185556 - 11/12/13 08:53 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
Roob Offline
Loc: Ontario,Canada
Easy decision to make if you want the advantages of a high VI oil with great add pack, TGMO 0w20.
2007 Accord Coupe 2.4 Vtec.
QSGB 5w20 with Fram TG
HDW1+ LG Platinum
Toyo Versado Noir-V
#3185560 - 11/12/13 08:54 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
ARCOgraphite Offline
Loc: N.H, U.S.A.
My Honda runs best on Valvoline 0w20 and using a better than factory service wix filter. see below VVVVVVV
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#4 24596mi-PP 0W20+Subaru Filter
#3185571 - 11/12/13 09:08 AM Re: Suggestions for a '13 Civic Si [Re: Durango]
Thugzy Offline
Loc: Canada
I agree with everyone that the K-series Honda engines are not picky at all. I have a 2011 Si Sedan with the K20Z3 and Im running GC 0W30. I drive mine quite hard, burns a bit of oil. I just added about 1/2 liter to top it off after 6000kms....
Almost all K-series engines burn oil when drivin hard with lots of high rpms. Im not sure what your oil consumption is going to be like with 0W20 and if driven hard.
Pre '12 Si's had a TSB for oil consumption issues, i believe there was an update on the piston rings. You should be ok. It would be interesting to know.
Edited by Thugzy (11/12/13 09:09 AM)
#3185576 - 11/12/13 09:13 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
climhazzard Offline
Loc: Virginia
Thanks for the great feedback everyone! I have to stick with 0w20 for warranty purposes, so my options are a bit more limited than if I could use a 5w20.
Based on the respones, it looks like almost any of the 0w20 options would be great. My only concern was I read that the Toyota (and possibly Honda?) variants are a bit thinner at startup than M1 and PP, but I'm not sure if that truly makes a real world difference.
#3185583 - 11/12/13 09:23 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
Thugzy Offline
Loc: Canada
climhazzard,
I just looked at your sig...we have similar tastes
My '11 Si is my daily driver
I also have a'01 S2000 as my Summer Toy....
only 40,000kms, never sees rain...also using GC
Cheers!
#3185584 - 11/12/13 09:25 AM Re: Suggestions for a '13 Civic Si [Re: Thugzy]
SatinSilver Offline
Loc: Ohio
^ Needs another layer of wax. Come on, you know you want to. laugh
2012 Toyota Camry 60k miles- PP 0w20, oem filter (TGMO all prior)
2005 Toyota Matrix 98k miles- MC 0w20 syn-blend, MC filter
#3185587 - 11/12/13 09:35 AM Re: Suggestions for a '13 Civic Si [Re: SatinSilver]
Thugzy Offline
Loc: Canada
dont tempt me...lol laugh
#3185597 - 11/12/13 09:46 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
Ayrton Offline
Loc: Washington State, U.S.
The Toyota oil is strong.
However, with your 5k mile oil changes, I'd go the easy and easy to find at good price route, Mobil 1 0w20.
#3185604 - 11/12/13 09:51 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
climhazzard Offline
Loc: Virginia
Thugzy, very nice!! I was running Mobil 1 10W30 in the S2 since I bought it and recently switched over to Castrol Edge w/ Ti this year. M1 seemed to burn a slight amount even with the low number of miles I put on it (apparently common for M1 and the F20C), but Castrol seems to be holding up quite well. I'm guessing GC runs great in our engines also.
Nice job on the wax too smile. What are you putting on there?
#3185629 - 11/12/13 10:18 AM Re: Suggestions for a '13 Civic Si [Re: climhazzard]
tommygunn Offline
Loc: usa
Napa Synthetic is still on sale this week for $3.49/qt. It is rebranded Synpower, and usually goes on sale a few times per year.
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
Page 1 of 3 1 2 3 >
