Which Oil
by Jamn
06/29/16 02:11 AM
Oil for Binding Foundry Sand
by smw
06/29/16 01:38 AM
Found a good high zinc breakin oil
by 1977c10phxdriver
06/29/16 01:12 AM
What is this radio modulating sound?
by Pontual
06/29/16 01:00 AM
The reason brake fluid can be Dot 3&4 - Viscosity!
by CharlieBauer
06/29/16 12:56 AM
No injector pulse, '92 Prelude, F20B, GSR ECM
by redhat
06/29/16 12:02 AM
Finding #1 Cylinder
by motorguy222
06/28/16 11:31 PM
Sure Filter 2821A C&P
by funflyer
06/28/16 11:27 PM
Can Kies save multiple phone info?
by daves66nova
06/28/16 11:25 PM
Tie-Rod Brands? AcDelco, B&A, Mevotech, MOOG
by Mr_Accord
06/28/16 10:23 PM
Engineer and Frog
by Koop
06/28/16 09:05 PM
Chevy 6.2 Silverado, Shaffer's or Mobile 1
by Crobinson16
06/28/16 08:32 PM
dougsangster, CrazyCalvinW, mal86, smw, Crobinson16
58311 Registered Users
30 registered (c502cid, Boczech, Darris, BrianF, Chris B., carlprop, 3 invisible), 814 Guests and 21 Spiders online.
58311 Members
66 Forums
250964 Topics
Page 4 of 5 < 1 2 3 4 5 >
#3228083 - 12/26/13 08:28 AM Re: MoS2 testing - sound levels [Re: Clevy]
dave5358 Offline
Loc: North Bend
Originally Posted By: Clevy
Organic moly and mos2 don't work the same way. Organic moly can only leave a layer 1 molecule thick which is quickly worn off at start up. Mos2 layers and once cooled becomes very hard so at start up the layer is more durable.
That certainly makes an argument in favor of MoS2 over organic moly - more durable start-up lubrication.
Sadly, start-up lubrication may be a pretty low priority to the oil / automotive industry. Most engines easily last 100k+ miles with nothing extra done for start-up lubrication. Beyond that, the oil companies/car makers/etc. simply don't care.
2006 Forester XT
2008 Corolla LE
#3228436 - 12/26/13 03:52 PM Re: MoS2 testing - sound levels [Re: Injured_Again]
MrQuackers Offline
Loc: Oregon
LM2009 is $6.75 at my local Napa. Is there a cheaper source?
As iron sharpens iron, so one man sharpens another
coffee Brawndo's got electrolytes!
Change your oil every 3k-5k
-AEHaas
#3228820 - 12/27/13 12:32 AM Re: MoS2 testing - sound levels [Re: Injured_Again]
147_Grain Offline
Loc: USA
If you don't mind buying by the case, you can get the MoS2 for $5.70 per can (including delivery) from Amazon.
http://www.amazon.com/gp/offer-listing/B...ler=&sr=8-1
#3228972 - 12/27/13 08:09 AM Re: MoS2 testing - sound levels [Re: 147_Grain]
dave5358 Offline
Loc: North Bend
That's a good price at Amazon and the shipping is free. But you have to buy 20 cans - total $114.06. You will have enough MoS2 to weather the zombie apocalypse.
DubNutz has it for $5.75 per can. Shipping for 8 was $10.
2006 Forester XT
2008 Corolla LE
#3229150 - 12/27/13 01:09 PM Re: MoS2 testing - sound levels [Re: Injured_Again]
TurboJim Offline
Loc: Oregon
Discounts at some NAPA stores are available with you have AAA membership or are part of the NAPA Advantage program (which is free).
#3229334 - 12/27/13 06:07 PM Re: MoS2 testing - sound levels [Re: Injured_Again]
HTSS_TR Offline
Loc: Lake Forest, CA
MoS2 was $4.xx at Napa couple years ago, $6.xx isn't bad because it is more expensive on eBay.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#3229386 - 12/27/13 06:47 PM Re: MoS2 testing - sound levels [Re: Injured_Again]
MrQuackers Offline
Loc: Oregon
If I am using Mobil 1 products will there be any benefit by adding this supplement?
-AEHaas
#3229546 - 12/27/13 09:13 PM Re: MoS2 testing - sound levels [Re: MrQuackers]
dave5358 Offline
Loc: North Bend
Mobil-1 already has about 85ppm of moly - probably soluble moly - in the mix, so someone at Mobil thought it was worthwhile: Mobil-1 Analysis.
A few messages above, in this same thread, Clevy opined...
... <snip> Organic moly can only leave a layer 1 molecule thick which is quickly worn off at start up. Mos2 layers and once cooled becomes very hard so at start up the layer is more durable...
So, you should get better start-up lubrication with MoS2 in the soup.
Moly in any form reduces friction and heat. But, there already is some moly in Mobil-1, so adding more will not necessarily reduce friction more or reduce heat more. It might, but it might not.
If there's a chance of taking a bullet in your sump, then MoS2 might get you back home (or maybe back on the ground). MoS2 will probably do this better than soluble moly.
2006 Forester XT
2008 Corolla LE
#3229573 - 12/27/13 09:57 PM Re: MoS2 testing - sound levels [Re: Injured_Again]
Nebroch Offline
Loc: Finlandistan
I'm running with Mobil 3000 X1 5W-40 in those pictures, propably it doesn't matter too much what oil you use.
There is one exception though:
http://www.liqui-moly.de/liquimoly/produktdb.nsf/id/en_1091.html?OpenDocument&land=DE
#3229829 - 12/28/13 08:24 AM Re: MoS2 testing - sound levels [Re: Nebroch]
dave5358 Offline
Loc: North Bend
Originally Posted By: Nebroch
I'm running with Mobil 3000 X1 5W-40 in those pictures, propably it doesn't matter too much what oil you use. There is one exception though:
It may not matter too much, since many popular motor oils contain soluble moly. The German LiquiMoly folks are seriously into MoS2. Perhaps the largest consumer use of MoS2 was also sponsored by a German company - Volkswagen. Maybe they know something. Or maybe German consumers pay better attention to engineers.
As for the other oil companies, there are many reasons why an oil company might use or not use a particular additive in a mass marketed oil. MoS2 is a suspended solid and the settling properties might be an issue. Personally, I think it is the color - it makes the oil turn black and the public simply does not like the appearance!
Also from this thread...
Originally Posted By: Injured_Again
I also used Arco Graphite motor oil back in the early 80's. I remember my dad asking why I would put something that black into the crankcase. I went on and on about all of the supposed advantages, but never did get him to try it just from that perspective.
2006 Forester XT
2008 Corolla LE
#3229935 - 12/28/13 10:53 AM Re: MoS2 testing - sound levels [Re: dave5358]
Nebroch Offline
Loc: Finlandistan
Settling is a problem, and user should know it. The additive that I used was asked to be shaken well before adding it to a warm engine. And after applying engine should run for a while to distribute stuff evenly. Obiviously some would not follow these instructions, and blame the manufacturer for possible damages..
#3229962 - 12/28/13 11:17 AM Re: MoS2 testing - sound levels [Re: Nebroch]
dave5358 Offline
Loc: North Bend
I'm sure the Walmart shoppers would follow the instructions and shake well before using.
2006 Forester XT
2008 Corolla LE
#3230177 - 12/28/13 05:02 PM Re: MoS2 testing - sound levels [Re: dave5358]
Garak Online   content
Loc: Regina, Saskatchewan, Canada
Except that their oils don't have that additive. wink
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3230202 - 12/28/13 06:15 PM Re: MoS2 testing - sound levels [Re: Garak]
dave5358 Offline
Loc: North Bend
...The German LiquiMoly folks are seriously into MoS2.
Don't have moly or don't have MoS2? Do you have some secret inside information on the LiquiMoly product line? Please share it with us.
2006 Forester XT
2008 Corolla LE
#3230280 - 12/28/13 08:05 PM Re: MoS2 testing - sound levels [Re: Injured_Again]
wrcsixeight Offline
Loc: california
LA 318 Roller Cam
M1 0w-40
M1-301 Filter
