OVERKILL
$100 Site Donor 2021
Originally Posted By: fdcg27
I think that within the margin of error, a UOA will show whether any given grade is causing excessive wear.
It may. Though we've had cases where it hasn't.
Quote:
A UOA with particle counts would be even better and since it would only represent a one-time extra expense, it might be worth it to the OP just to assure himself that his engine really is wearing well on a non-complying oil.
Agreed.
Quote:
BMW probably recommends an LL-01 oil simply because they know without question that it will work and they don't intend to go to the expense of testing API SN oils, a standard which applies mainly to the North American market alone.
Doesn't mean that an API SN 5W-30 won't work well.
Just means that BMW doesn't have any evidence of whether it will or won't.
The OP has at least some evidence that it will and enough has been posted throughout this forum of the potential for using thinner oils in a variety of applications that there's really no reason to think that it wouldn't.
I'm sure that's part of BMW's reasoning. However they also have the LL-01 FE spec that denotes an oil of about the viscosity the OP is running. They could have chosen to spec that instead
My concern is that this being a forced induction application, there may be some solid reasoning behind the requirement of an oil with an HTHS >=3.5cP being spec'd.
Agreed.
