Originally Posted By: dave5358
Originally Posted By: ARCOgraphite
The colloidal particles may agglomerate and be trapped in the filter. Just BC they were 1-3microns at one point doesn't mean they will not agglomerate in situ. ADDS may treat them as soot and bind them for filtering.
It might happen, but I've never seen any evidence of this in personal use and I've never read that this was a problem or even a consideration. Even larger particles (8-10 micron size) do not seem to be trapped in an oil filter. I have used 8-10 micron sized powder when I could not find anything else, and it seemed to stay in the oil - not filtered, not settled - just as well as the smaller particles.
Since MoS2 doesn't dissolve, larger particles do tend to settle out, to the bottom of the pan. By the time the particles are sub-micron size, there is not much settling. Depending on the design of the engine sump, settling might not make much difference either - the oil flow in and out of the sump would keep things stirred up.
Have you ever used MoS2 in your engine? I'm asking because you have been very dismissive of this additive ("Waste of money"). You are dismissing the most common dry-film lubricant in industrial use today, dismissing a product which has been in widespread military and industrial use for almost a century, dismissing a product recommended and sold by Volkswagen (among others) for use in engine oil. Please share your experience or the source of your views on MoS2.
Here's my experience. It did nothing. And for daring to say that, I got a bunch of juvenile, inane, someone off their meds clap trap.
